73 de S56IUA - Ognjen
tcp s56lsi.ampr.org:62539 240-goc-2.acn.waw.pl:10609 ESTABLISHED
tcp s56lsi.ampr.org:62207 host81-153-42-100.range81-153.btce:20919 ESTABLISHED
tcp s56lsi.ampr.org:61673 78.215.216.81.or.siw.siwnet.net:26925 ESTABLISHED
tcp s56lsi.ampr.org:65067 adsl-69-105-139-21.dsl.sndg02.pacb:49253 ESTABLISHED
tcp s56lsi.ampr.org:61987 cmb47-143.dial-up.arnes.si:16881 ESTABLISHED
tcp s56lsi.ampr.org:65061 64.126.44.173:52430 ESTABLISHED
tcp s56lsi.ampr.org:61320 dsl-207-112-49-55.tor.primus.ca:17161 ESTABLISHED
tcp s56lsi.ampr.org:63745 mail.demonoid.com:90 ESTABLISHED
tcp s56lsi.ampr.org:65013 211.144.97.115:8098 ESTABLISHED
tcp s56lsi.ampr.org:64276 d149-67-118-51.nap.wideopenwest.com:1337 ESTABLISHED
tcp s56lsi.ampr.org:62088 dmw128.neoplus.adsl.tpnet.pl:9325 ESTABLISHED
tcp s56lsi.ampr.org:61189 cmb47-143.dial-up.arnes.si:16881 ESTABLISHED
tcp s56lsi.ampr.org:61123 baym-cs163.msgr.hotmail.com:1863 ESTABLISHED
tcp s56lsi.ampr.org:63840 host81-153-42-100.range81-153.btce:20919 ESTABLISHED
tcp s56lsi.ampr.org:64663 jemmapes-4-82-67-191-63.fbx.proxad.:9678 ESTABLISHED
tcp s56lsi.ampr.org:61452 203-217-38-29.dyn.iinet.net.au:50032 ESTABLISHED
tcp s56lsi.ampr.org:61234 coa108.neoplus.adsl.tpnet.pl:50000 ESTABLISHED
tcp s56lsi.ampr.org:63736 221.127.196.76:9615 ESTABLISHED
tcp s56lsi.ampr.org:61836 rdu168-188-201.nc.rr.com:26491 ESTABLISHED
tcp s56lsi.ampr.org:63895 143.44.223.82.arsystel.com:6669 ESTABLISHED
tcp s56lsi.ampr.org:64789 cmb47-143.dial-up.arnes.si:16881 ESTABLISHED
tcp s56lsi.ampr.org:61653 81.168.54.218:10256 ESTABLISHED
tcp s56lsi.ampr.org:63639 pD9543BA2.dip.t-dialin.net:6908 ESTABLISHED
tcp s56lsi.ampr.org:64261 d149-67-118-51.nap.wideopenwest.com:1337 ESTABLISHED
tcp s56lsi.ampr.org:64492 i252080.upc-i.chello.nl:56822 ESTABLISHED
tcp s56lsi.ampr.org:62450 84-107-16-107.dsl.quicknet.nl:10027 ESTABLISHED
tcp s56lsi.ampr.org:62413 MTL-HSE-ppp188695.qc.sympatico.ca:9994 ESTABLISHED
tcp s56lsi.ampr.org:61235 200-122-44-21.dsl.prima.net.ar:15590 ESTABLISHED
tcp s56lsi.ampr.org:62606 64.126.44.173:52430 ESTABLISHED
tcp s56lsi.ampr.org:64118 i252080.upc-i.chello.nl:56822 ESTABLISHED
tcp s56lsi.ampr.org:63018 38.119.106.84:www ESTABLISHED
tcp s56lsi.ampr.org:63246 143.44.223.82.arsystel.com:6669 ESTABLISHED
tcp s56lsi.ampr.org:64935 user-5776.l5.c1.dsl.pol.co.uk:6346 ESTABLISHED
tcp s56lsi.ampr.org:62672 ACCBC062.ipt.aol.com:8582 ESTABLISHED
tcp s56lsi.ampr.org:61953 host217-42-177-120.range217-42.btc:16039 ESTABLISHED
tcp s56lsi.ampr.org:62618 l196113.upc-l.chello.nl:48907 ESTABLISHED
tcp s56lsi.ampr.org:62925 n218250089177.netvigator.com:21144 ESTABLISHED
tcp s56lsi.ampr.org:63538 c-66-176-87-148.se.client2.attbi.c:15193 ESTABLISHED
tcp s56lsi.ampr.org:62051 c-67-171-44-6.client.comcast.net:57820 ESTABLISHED
tcp s56lsi.ampr.org:62802 cm-200-75-252-33.cableonda.net:9518 ESTABLISHED
tcp s56lsi.ampr.org:61588 24.86.128.61:1988 ESTABLISHED
tcp s56lsi.ampr.org:61205 d205-250-166-125.bchsia.telus.net:18777 ESTABLISHED
tcp s56lsi.ampr.org:64280 d154-5-67-110.bchsia.telus.net:6901 ESTABLISHED
tcp s56lsi.ampr.org:61662 S010600e018859479.vn.shawcable.net:44081 ESTABLISHED
tcp s56lsi.ampr.org:63129 c529d31da.cable.wanadoo.nl:38751 ESTABLISHED
tcp s56lsi.ampr.org:62720 cpc2-cove2-3-0-cust240.brhm.cable.:17052 ESTABLISHED
tcp s56lsi.ampr.org:61246 d198-166-216-156.abhsia.telus.net:7882 ESTABLISHED
tcp s56lsi.ampr.org:63387 CM600-lcis1-2-253.cm.vtr.net:13627 ESTABLISHED
tcp s56lsi.ampr.org:62053 rdu168-188-201.nc.rr.com:26491 ESTABLISHED
tcp s56lsi.ampr.org:64239 ACBD7124.ipt.aol.com:6409 ESTABLISHED
tcp s56lsi.ampr.org:64987 CPE-69-76-44-57.wi.rr.com:46112 ESTABLISHED
tcp s56lsi.ampr.org:61210 pcp01103824pcs.aubrnh01.mi.comcast.:6346 ESTABLISHED
tcp s56lsi.ampr.org:62461 d198-166-216-156.abhsia.telus.net:7882 ESTABLISHED
tcp s56lsi.ampr.org:62940 dne32.neoplus.adsl.tpnet.pl:9325 ESTABLISHED
tcp s56lsi.ampr.org:63585 ti400720a080-3440.bb.online.no:16881 ESTABLISHED
tcp s56lsi.ampr.org:61474 38.117.175.30:www ESTABLISHED
tcp s56lsi.ampr.org:63979 81-86-114-157.dsl.pipex.com:50001 ESTABLISHED
tcp s56lsi.ampr.org:61437 rescomp-04-38230.Stanford.EDU:6346 ESTABLISHED
tcp s56lsi.ampr.org:64012 c-67-171-44-6.client.comcast.net:57820 ESTABLISHED
tcp s56lsi.ampr.org:64488 adsl-66-218-36-41.dslextreme.com:9688 ESTABLISHED
tcp s56lsi.ampr.org:63323 d198-166-216-156.abhsia.telus.net:7882 ESTABLISHED
tcp s56lsi.ampr.org:62093 d149-67-118-51.nap.wideopenwest.com:1337 ESTABLISHED
tcp s56lsi.ampr.org:62404 143.44.223.82.arsystel.com:6669 ESTABLISHED
tcp s56lsi.ampr.org:62219 203-217-38-29.dyn.iinet.net.au:50032 ESTABLISHED
tcp s56lsi.ampr.org:63342 pD9543BA2.dip.t-dialin.net:6908 ESTABLISHED
tcp s56lsi.ampr.org:63628 200-122-44-21.dsl.prima.net.ar:15590 ESTABLISHED
tcp s56lsi.ampr.org:61627 d149-67-118-51.nap.wideopenwest.com:1337 ESTABLISHED
tcp s56lsi.ampr.org:61358 cpc1-darl2-3-0-cust7.midd.cable.nt:50008 ESTABLISHED
tcp s56lsi.ampr.org:61560 d198-166-216-156.abhsia.telus.net:7882 ESTABLISHED
tcp s56lsi.ampr.org:64419 200-122-44-21.dsl.prima.net.ar:15590 ESTABLISHED
tcp s56lsi.ampr.org:62619 c529d31da.cable.wanadoo.nl:38751 ESTABLISHED
tcp s56lsi.ampr.org:64455 pD9543BA2.dip.t-dialin.net:6908 ESTABLISHED
tcp s56lsi.ampr.org:64390 ar56.lsanca1-4.16.254.5.lsanca1.el:6346 ESTABLISHED
tcp s56lsi.ampr.org:63916 d154-5-67-110.bchsia.telus.net:6901 ESTABLISHED
tcp s56lsi.ampr.org:61587 pD9543BA2.dip.t-dialin.net:6908 ESTABLISHED
tcp s56lsi.ampr.org:62884 d149-67-118-51.nap.wideopenwest.com:1337 ESTABLISHED
tcp s56lsi.ampr.org:61865 z159.219-121-80.ppp.wakwak.ne.jp:7345 ESTABLISHED
tcp s56lsi.ampr.org:61618 143.44.223.82.arsystel.com:6669 ESTABLISHED
tcp s56lsi.ampr.org:63036 cpc1-broo2-3-0-cust203.renf.cable.:43074 ESTABLISHED
tcp s56lsi.ampr.org:63368 n218250089177.netvigator.com:21144 ESTABLISHED
tcp s56lsi.ampr.org:61742 ip-69-22-158-74.trymedia.com:www ESTABLISHED
tcp s56lsi.ampr.org:64411 203-217-38-29.dyn.iinet.net.au:50032 ESTABLISHED
tcp s56lsi.ampr.org:63914 203-217-38-29.dyn.iinet.net.au:50032 ESTABLISHED
tcp s56lsi.ampr.org:62528 cpc1-darl2-3-0-cust7.midd.cable.nt:50008 ESTABLISHED
tcp s56lsi.ampr.org:62922 host81-153-42-100.range81-153.btce:20919 ESTABLISHED
tcp s56lsi.ampr.org:64017 Toronto-HSE-ppp3946819.sympatico.c:10000 ESTABLISHED
tcp s56lsi.ampr.org:61159 HSE-Ottawa-ppp239722.sympatico.ca:1200 ESTABLISHED
tcp s56lsi.ampr.org:62382 d198-166-216-156.abhsia.telus.net:7882 ESTABLISHED
tcp s56lsi.ampr.org:64953 cmb47-143.dial-up.arnes.si:16881 ESTABLISHED
tcp s56lsi.ampr.org:61651 host81-130-115-158.in-addr.btopenwo:6891 ESTABLISHED
tcp s56lsi.ampr.org:61622 200-122-44-21.dsl.prima.net.ar:15590 ESTABLISHED
tcp s56lsi.ampr.org:63782 c529d31da.cable.wanadoo.nl:38751 ESTABLISHED
tcp s56lsi.ampr.org:61728 ip-69-22-158-74.trymedia.com:www ESTABLISHED
tcp s56lsi.ampr.org:61830 wbar1.sjo1-4-4-013-244.sjo1.dsl-ve:32064 ESTABLISHED
tcp s56lsi.ampr.org:61185 cmb47-143.dial-up.arnes.si:16881 ESTABLISHED
tcp s56lsi.ampr.org:62869 d149-67-118-51.nap.wideopenwest.com:1337 ESTABLISHED
tcp s56lsi.ampr.org:62203 chello080109147253.tirol.surfer.at:25643 ESTABLISHED
tcp s56lsi.ampr.org:63788 pcp01552750pcs.11thav01.fl.comcast:39623 ESTABLISHED
tcp s56lsi.ampr.org:62103 CPE-69-76-44-57.wi.rr.com:46112 ESTABLISHED
tcp s56lsi.ampr.org:65009 38.119.106.84:www ESTABLISHED
tcp s56lsi.ampr.org:63856 pD9543958.dip.t-dialin.net:6898 ESTABLISHED
tcp s56lsi.ampr.org:61608 240-goc-2.acn.waw.pl:10609 ESTABLISHED
tcp s56lsi.ampr.org:61032 pD9E59CCD.dip.t-dialin.net:12300 ESTABLISHED
tcp s56lsi.ampr.org:65058 217.169.13.253:15371 ESTABLISHED
tcp s56lsi.ampr.org:61070 adsl-69-108-70-166.dsl.irvnca.pacb:18558 ESTABLISHED
tcp s56lsi.ampr.org:63973 pD954FCE5.dip.t-dialin.net:6400 ESTABLISHED
tcp s56lsi.ampr.org:63835 host81-153-42-100.range81-153.btce:20919 ESTABLISHED
tcp s56lsi.ampr.org:61740 c14-gdl-software-deliv-lb.cnet.com:www ESTABLISHED
tcp s56lsi.ampr.org:61296 l196113.upc-l.chello.nl:48907 ESTABLISHED
tcp s56lsi.ampr.org:63677 d154-5-67-110.bchsia.telus.net:6901 ESTABLISHED
tcp s56lsi.ampr.org:63223 ppp4-adsl-139.ath.forthnet.gr:49153 ESTABLISHED
tcp s56lsi.ampr.org:61477 pD9543958.dip.t-dialin.net:6898 ESTABLISHED
tcp s56lsi.ampr.org:64457 ip503c2e75.speed.planet.nl:27380 ESTABLISHED
tcp s56lsi.ampr.org:64240 pcd312020.netvigator.com:8630 ESTABLISHED
tcp s56lsi.ampr.org:61353 d198-166-216-156.abhsia.telus.net:7882 ESTABLISHED
tcp s56lsi.ampr.org:64889 cpe-24-92-104-21.elp.rr.com:39503 ESTABLISHED
tcp s56lsi.ampr.org:62476 CPE-69-76-44-57.wi.rr.com:46112 ESTABLISHED
tcp s56lsi.ampr.org:61012 n219079049238.netvigator.com:7881 ESTABLISHED
tcp s56lsi.ampr.org:63850 cmb47-143.dial-up.arnes.si:16881 ESTABLISHED
tcp s56lsi.ampr.org:62808 dsl-80-42-148-111.access.uk.tiscal:51515 ESTABLISHED
tcp s56lsi.ampr.org:63556 ACA2FF2D.ipt.aol.com:58804 ESTABLISHED
tcp s56lsi.ampr.org:63494 84-107-16-107.dsl.quicknet.nl:10027 ESTABLISHED
tcp s56lsi.ampr.org:61440 203-217-38-29.dyn.iinet.net.au:50032 ESTABLISHED
tcp s56lsi.ampr.org:64819 user-24-214-64-44.knology.net:29734 ESTABLISHED
tcp s56lsi.ampr.org:63596 pD954FCE5.dip.t-dialin.net:6400 ESTABLISHED
tcp s56lsi.ampr.org:63200 pD9543BA2.dip.t-dialin.net:6908 ESTABLISHED
tcp s56lsi.ampr.org:63777 h52207.upc-h.chello.nl:10110 ESTABLISHED
tcp s56lsi.ampr.org:61063 host81-153-42-100.range81-153.btce:20919 ESTABLISHED
tcp s56lsi.ampr.org:63386 81-178-212-217.dsl.pipex.com:6346 ESTABLISHED
tcp s56lsi.ampr.org:64053 pD9E596FA.dip.t-dialin.net:12300 ESTABLISHED
tcp s56lsi.ampr.org:62608 user-2854.l4.c5.dsl.pol.co.uk:6346 ESTABLISHED
tcp s56lsi.ampr.org:64749 222-152-205-222.jetstream.xtra.co.n:6896 ESTABLISHED
tcp s56lsi.ampr.org:64610 host81-153-42-100.range81-153.btce:20919 ESTABLISHED
tcp s56lsi.ampr.org:63031 n218103182177.netvigator.com:16881 ESTABLISHED
tcp s56lsi.ampr.org:61475 alfortville-5-82-66-248-90.fbx.pro:24798 ESTABLISHED
tcp s56lsi.ampr.org:62526 68-235-87-178.miamfl.adelphia.net:12142 ESTABLISHED
tcp s56lsi.ampr.org:63477 user-12hdlmm.cable.mindspring.com:27751 ESTABLISHED
tcp s56lsi.ampr.org:63550 221.127.215.254:20825 ESTABLISHED
tcp s56lsi.ampr.org:64938 user-24-214-64-44.knology.net:29734 ESTABLISHED
tcp s56lsi.ampr.org:61364 u82-197-91-151.user.oc.cust.vaioni:58856 ESTABLISHED
tcp s56lsi.ampr.org:61728 baym-cs85.msgr.hotmail.com:1863 ESTABLISHED
tcp s56lsi.ampr.org:64199 209.11.67.28:www ESTABLISHED
tcp s56lsi.ampr.org:62909 stjh1-1117.nl.aliant.net:3000 ESTABLISHED
s51fu napisal/-a:Ali je nekaj lahko prekrsek, ce ni predpisa ?
PeterP napisal/-a:Jaz bi zadevo drugače rešil:
Nisi član ZRS (oziroma nisi plačal članarine) ne moreš uporabljati PR omrežja. Zato ker se z članarine financira tudi izgradnja in vzdrževanje le tega. Če pa fantje hočjo samo PR uporablat pa naj članarino tut plačajo in za to zahtevajo tudi izbolšanje povezav.
Uporaba frekvenc je tako ali tako zagotovljena vsem, ki imajo opravljen izpit, ampak to še ne pomeni da je samoumevna uporaba PR za internet in maile.
Torej ne plača članarine ZRS ne more dostopat do interneta in maila preko PR lahko pa cluster voz.
PR: Packet Radio
