Novi firmware za TS590S v2.0
OdgovorNapisal/-a s55o » 29 Jan 2015, 12:54
Novi firmware je zunaj za TS590S
Dobite ga tukaj:
http://www.kenwood.com/i/products/info/ ... nload.html
Updates the following feature.
1. Enables use of the new Split function for quick split operations.
Hold down the [SPLIT] key, and the “SPLIT” indicator blinks. When the [5] key is pressed, for example, the split setting will be completed as “5kHz Up”.
2. Enables the XIT frequency to be set while pressing [TF-SET] key when RIT is OFF in simplex mode.
3. Enables FINE function to be set to ON/OFF in each mode.
4. Enables display of the 1Hz frequency digit when the FINE function is turned on below 1MHz (except in transverter mode).
5. Enables the status of FIL A/B to be set separately for VFO A/B.
6. Enables use of the RX ANT in 50MHz band. The status can be set separately in HF and 50MHz band.
7. Enables the setting of RF output power independently in DATA mode. (RF output power in HF SSB-DATA/ FM-DATA, 50M SSB-DATA/ FM-DATA, HF AM-DATA, and 50M AM-DATA can be set independently).
8. Enables setting of the voice message’s PROC level and MIC gain separately from the setting of usual microphone input’s PROC level and MIC gain. (The optional VGS-1 is required)
9. Enables setting the RX equalizer / TX equalizer in each mode.
10. Enables deleting CW message memories by each memory channel.
11. Enables announcement of the type of the transmission meter.(The optional VGS-1 is required)
12. Enables announcement of the DRV OUT function ON / OFF status.(The optional VGS-1 is required)
13. Enables announcement of the RIT/XIT frequency.(The optional VGS-1 is required)
14. Enables reading the status of the optional VGS-1 (if installed in the TS-590S).
15. Enables back up of the status of the AI function ON/OFF.
16. Enables deleting Voice messages from a PC.
(Details of the above-mentioned PC commands are described in the revised "PC CONTROL COMMAND Reference Guide")
17. Revises the band memory [GENE] 2nd setting to 472kHz / CW.
18. Enables output of the 475kHz band (472~479kHz) signal from the rear panel DRV (drive output) connector as well as 135kHz band.
19. Reduces the minimum volume of the CW side tone and TX monitor.
(Please also update both of the Radio Control Program ARCP-590 and the Radio Host Program ARHP-590 to Ver.2.00 for functional compatibility.)
Revises the following symptoms.
1. After changing operation mode, DATA VOX might not work correctly.
2. While transmitting in SSB or CW mode, the SWR meter level might become high for a moment.
Splača se zadevo posodobit.
Prispevkov: 2598
