Najave tujih aktivacij
OdgovorNapisal/-a s50v » 27 Mar 2012, 07:10
____OCTOBER 2012_____________________________________________________________________________________
06/10/2012 - WCA & DCFP & DMHP pedition CS5NRA from Fortress S. Bruno!
- The members of Portuguese Navy Hamradio Club - CS5NRA will be active on the 6th of October 2012 from Fortress S. Bruno, WCA: CT-00205, DCFP: F-029, DMHP: LX-35. They plans to work on all bands, the team leader CT1CZT, Antonio Gamito. 73 & 11! [tnx info CT1CZT].
____JULY 2012__________________________________________________________________________________________
06/07/2012 - WCA pedition ES2012ABCS and ES3/RN1CW from Castle Haapsalu!
- Eddie ES2TT and Andrew RN1CW will be active from the 6th of July till 8th of July 2012 from Castle Haapsalu, WCA: ES-00003. They plan to work as ES2012ABCS and ES3/RN1CW on all bands CW, SSB and BPSK. QSL for ES2012ABCS via ES2TT, ES3/RN1CW via RN1CW. Log will be uploaded to WCA E-Log. 73 & 11! [tnx info ES2TT].
____JUNE 2012__________________________________________________________________________________________
10/06/2012 - WCA & BCA pedition OP0P/P from Castle Saint Fontaine!
- Robert ON4LRG, Janny ON5PO, Paul ON6DP, Didier ON6YH, Pierre ON7PC and Jean ON7ZM will be active on the 10th of June 2012 from Castle Saint Fontaine, WCA: ON-00496, BCA: LG-095. They plan to work from 06:00 till 10:00 UTC on all bands as OP0P/P or Home Callsign/P. QSL for OP0P via ON6DP, bureau, direct, LOTW or E-QSL. 73 & 11! [tnx info ON6DP].
____MAY 2012___________________________________________________________________________________________
31/05/2012 - WCA & COTA-YL pedition YL/ES2TT and YL2012USCARS from Castle Krimulda!
- Eddie ES2TT will be active from the 31st of May till 4th of June 2012 from Castle Krimulda, WCA: YL-00039 located in Park Gauja, YLFF-001. He plans to work on the 31st of May 2012 as YL/ES2TT from 1st of June 2012 as YL2012USCARS on all bands CW, SSB possible BPSK. QSL via ES2TT. Log will be uploaded to WCA E-Log. 73 & 11! [tnx info ES2TT].
18/05/2012 - WCA & BCA pedition OT7G/P from Castle de Ghellinck!
- The members of UBA section ODE is planned activate on Friday 18th of May at 14:00 UTC till Sunday 20th of May 2012 at 14:00 UTC from Castle de Ghellinck, WCA: ON-00364, BCA: OV-032, WW Loc. JO10ST. They plan to work as OT7G/P on all HF bands CW and SSB and on 2 meters FM. QSL via ON5MA, bureau or direct. 73 & 11! [tnx info I.C.P.O. & VA3RJ].
____APRIL 2012_________________________________________________________________________________________
29/04/2012 - WCA & BCA pedition OP0P/P from Castle of Hoyoux!
- Robert ON4LRG, Janny ON5PO, Paul ON6DP, Didier ON6YH, Pierre ON7PC and Jean ON7ZM will be active on the 29th of April 2012 from Castle of Hoyoux, WCA: ON-00497, BCA: LG-096. They plan to work from 06:00 till 10:00 UTC on all bands as OP0P/P or Home Callsign/P. QSL for OP0P via ON6DP, bureau, direct, LOTW or E-QSL. 73 & 11! [tnx info ON6DP].
01/04/2012 - WCA & DCI pedition IZ0QPO/P from Torre Flavia!
- Fabio IZ0QPO will be active on the 01st of April 2012 from Torre Flavia located in the town of Ladispoli-Roma, WCA: I- 08603 , DCI: RM - 291. He plans to work as IZ0QPO/P on 40 and 20 meters. QSL via IZ 0QPO , bureau or direct. 73 & 11! [tnx info IZ0QPO].
01/04/2012 - WCA & BCA pedition ON4BB/P from Castle of Skeuvre!
- Luk ON4BB, Willy ON5JE, Janny ON5PO, Paul ON6DP, Fred ON6QR, Didier ON6YH, Pierre ON7PC and Jean ON7ZM will be active on the 1st of April 2012 from Castle of Skeuvre, WCA: ON-00492, BCA: NM-060. They plan to work from 06:00 till 10:00 UTC on all bands as ON4BB/P. QSL bureau, direct. 73 & 11! [tnx info ON6DP].
____MARCH 2012________________________________________________________________________________________
31/03/2012 - WCA & ZWP pedition SP9YFFP from Castle Naklo Slaskie!
- The members of Silesia Radioamateur Group SP9YFF Team and guests operator's will be active on the 31st of March 2012 as SP9YFF/P from Castle Naklo Slaskie, WCA: SP-00509, ZWP:GTG-01. They plan to work on 80 - 10 meters SSB, DIGI and CW, 100 watts and GP/Wire antenna. Possible to run several transmitters. For detail informations, please visit at: http://www.sp9yff.pl. QSL information on the QRZ.COM. Log will be uploaded to WCA E-Log, ZWP and LoTW. 73 & 11! [tnx info SP9UPK].
http://wca.hamradio.si/
http://wcagroup.org/ENG/main.html
s50v
Prispevkov: 263
Pridružen: 25 Feb 2009, 13:43
Kraj: LJ/SG
Re: Najave tujih aktivacij
OdgovorNapisal/-a s52o » 14 Maj 2012, 17:50
Tudi v JA aktivacija gradu !
Info from: Nobi - JA1JCF
Hello,
I am planning a trial activation of a Japanese castle this week.
The activity will be on Thursday, May 17, from 06:00 UTC through 09:00 UTC,
from Hachigata Castle, Yorii, Saitama, WCA JA-00023. 15 meter band CW will
be used mainly, but 17 or 12 meter CW may be used depending on conditions.
The call-sign will be JA1JCF/p.
The signals may be weak as my portable station will be running 50 watts with
a loop or a vertical antenna.
The forecast for Thursday is cloudy, but the plan may be cancelled due to
bad weather.
73,
Nobi, JA1JCF
s52o
Prispevkov: 406
Pridružen: 02 Sep 2004, 21:04
Kraj: Hotavlje JN76BC
OdgovorNapisal/-a s52o » 22 Jun 2012, 12:45
Ivica 9A6CW, will be active on the 23th and 24th of June from fort St. Nikola on Island Vis (place Komiža), WCA: 9A-00233.
Ivica will be active in afternoon hours, QRP 4 wats, on 40m i 20m.
s52o
Prispevkov: 406
OdgovorNapisal/-a s50v » 23 Jun 2012, 08:50
Pietro IW3RUA je že v luftu:
In date 23/06/2012 Peter IW3RUA will be active WCA S5-00138 GRAD KLUŽE (THALBERG) BOVEC .
I want work on 7 Mhz after work in 21 or 14 Mhz
Call for Activity S5/IW3RUA/P
73 & 11 de IW3RUA
s50v
Prispevkov: 263
Kraj: LJ/SG
OdgovorNapisal/-a s52o » 23 Jul 2012, 13:12
28/07/2012 - WCA & CCA pedition OK2AN/P from Castles in Czech Republic!
-Vasek OK2AN will be active from the 28th of July till 4th of August 2012 from several castles:
Hruba Skala, WCA: OK-00420, CCA: LI-028, WW Loc. JO70ON;
Hruby Rohozec, WCA: OK-00421, CCA: LI-029, WW Loc. JN70NO;
Maly Rohozec, WCA: OK-00425, CCA: LI-033, WW Loc. JN70NO;
Svijany, WCA: OK-00417, CCA: LI-025, WW Loc. JN70MN;
Trosky, WCA: OK-01403, CCA: LI-060, WW Loc. JN70OM;
Kostalov, WCA: OK-01470, CCA: LI-064, WW Loc. JN70QN;
Semily, WCA: OK-00426, CCA: LI-034, WW Loc. JN70QO;
Rotstejn, WCA: OK-01402, CCA: LI-059, WW Loc. JO70OO;
Zbirohy, WCA: OK-00749, CCA: LI-039, WW Loc. JN70OO;
Kozlov, WCA: OK- 01469, CCA: LI-063, WW Loc. JN70QM;
Lomnice nad Popelkou, WCA: OK-00424, CCA: LI-032, WW Loc. JN70QM.
He plans to work on all bands as OK2AN/Portable. QSL via Home Call.
Log will be uploaded to WCA E-Log. 73 & 11! [tnx info OK5NN].
s52o
Prispevkov: 406
OdgovorNapisal/-a s52o » 09 Avg 2012, 18:55
Vitaly YL3AFK, Alex YL3BU, Evgeny YL2TD and Grigorij YL2NS will be active on the 11 - 12 August 2012 from Edole Castle, WCA: YL-00022, COTA-YL: Z-007, WW loc. KO07UA. They plan to work from 10:00 UTC on 11 August till 13:00 UTC on 12 August as YL11WCA on 80 - 10 meters CW and SSB near WCA frequences. QSL via bureau . Log will be uploaded to WCA E-Log. 73 & 11!
http://yl3bu.lv/news/WCA_Edole_castle
Uldis yl2IU
s52o
Prispevkov: 406
OdgovorNapisal/-a 9a6ndd » 12 Avg 2012, 21:29
U srijedu, 15.08.2012. ekipa u sastavu Daki 9A2WJ, Mato 9A3SM i Drago 9A6NDD pokušati će aktivirati slijedeće 9A COTA reference:
WCA 9A-00220 - 9A-0220 Kurija Adamović-Hellenbach-Mikšić, Sv. Helena
WCA 9A-00016 - 9A-0016 Kurija Omilje, Donja Drenova
WCA 9A-00283 - 9A-0283 Utvrda Zelingrad, Sv. Ivan Zelina
i rezervna referenca ako se stigne ili slučajno ne uspije pronaći neka od gore navedenih:
WCA 9A-0006 - 9A-0006 Kurija Drašković, Dugo Selo
Početak rada s prve lokacije je poslije 10:00 (LT), a raditi ćemo na 14 i 7 Mhz, SSB i CW.
Ako nas spotate na cluster (unaprijed hvala ) obavezno upišite WCA i broj reference jer će tako biti vidljivije za WCA lovce.
73&11 de 9A6NDD
9a6ndd
Prispevkov: 19
Pridružen: 28 Jan 2010, 19:43
OdgovorNapisal/-a 9a6ndd » 30 Avg 2012, 22:17
U sklopu obilježavanja proslave Dana grada SLATINA 01.rujna 2012., Radio klub Slatina 9A1ABE u sastavu:
Ivan Dolovski (9A7DRI), Miša Nicinger (9A4TA) i Zlatko Cibok (9A3BCZ) aktivirati će dvorac Drašković u Slatini, WCA 9A-00240, 9A COTA 9A-0240.
Planirani početak aktivnosti je 08:00 UTC (10:00 po našem vremenu) na 7 i 14 MHz (+ eventualno 144MHz).
9a6ndd
Prispevkov: 19
OdgovorNapisal/-a s52o » 10 Nov 2012, 18:20
11/11/2012 - WCA & BCA pedition OT6A/P from Fort de Maizeret and Chateau de Maizeret!
- Paul ON6DP, Didier ON6YH and Jean-Pierre ON7ZM will be active on the 11th of November 2012 from Fort de Maizeret (1914-1918), WCA : ON-00490, BCA: NM-058 and from Chateau de Maizeret, WCA: ON-01294, NM-112. They plan to work as OT6A/P from 07:00 till 11:30 UTC on all bands. QSL via bureau. 73 & 11! [tnx info ON6DP].
11/11/2012 - WCA & DCE pedition EA8ADL/P from Castillo Las Coloradas!
- Jose Antonio EA8ADL will be active on the 11th of November 2012 from Castillo Las Coloradas, WCA: EA-01912, DCE: GC-010 located in Las Palmas, Canary Islands. He plans to work as EA8ADL/P on all bands. Log will be uploaded to WCA E-Log. 73 & 11! [tnx info EA8ADL].
s52o
Prispevkov: 406
OdgovorNapisal/-a s52o » 16 Nov 2012, 14:59
Hi, Castles Friends,
Here some new activity alert by our friend Eric HB9IAB :
Date: Saturday 17th of November, 2012 ;
Time: From 08:00 UTC;
Callsigns: HB9HI/p Radio Club ;
Bands: 40m SSB , then maybe up ;
Freq. : +/- 7110 kHz
Reference: DCS-VD060 Chateau de Roche
Reference: WCA-HB00690 for the World Castles Award
Operators: HB9IAB Eric, and other Club-Members
Station: 100 W rf , Dipole Antenna
Remarks: New Ones
Help on the frequency, spots on the clusters and SWL Reports vy welcome!
Please , apply the DX Code of Conduct, tnx!
Have Fun with our Hobby, good hunting,
73 de Augusto hb9tza
s52o
Prispevkov: 406
OdgovorNapisal/-a s52o » 21 Mar 2013, 20:56
Hello All!
- In honour of celebrating the 50th anniversary of ARA foundation (1963-2013) members of ARA will activate from 20th till 30th of March 2013 from Palais des Rais (Bastion 23) in Algier City, WCA: 7X-00012. They plan to work as special callsign 7T9A on all bands, all modes. QSL via bureau or direct. 73 & 11! [tnx info 7X2RO].
73 & 11! de Andrew RN1CW
WCA Co-ordinator (World Castles Award)
s52o
Prispevkov: 406
OdgovorNapisal/-a s52o » 24 Maj 2013, 13:13
Hello All!
25/05/2013 - WCA & DCFP & DMHP pedition of CT7/CU3EJ to Convento de Sao Francisco, Palacio Marquesses de Angeja, Castelo de Alenquer!
- Lionel CU3EJ will be active on the 25th of May 2013 from Convento de Sao Francisco, WCA: CT-01024, DMHP: LX-017 from Palacio Marquesses de Angeja, WCA: CT-01025, DMHP: LX-018 and from Castelo de Alenquer, WCA: CT-00008, DCFP: C-008, DMHP: LX-019 located in WWFF: CTFF-019. He plans to work as CT7/CU3EJ on 40 and 20 meters. QSL via CU3EJ, bureau or direct. 73 & 11! [tnx info CU3EJ].
24/05/2013 - WCA & 9A-COTA pedition of 9A4MF/P to Kurija Jankovic and Trenkov Castles!
- Miroslav 9A4MF will be active on the 24th of May 2013 from Kurija Jankovic Castle, WCA/9A-COTA: 9A-00031 and maybe from Trenkov Castle, WCA/9A-COTA: 9A-00032. He plans to work from 14:00 UTC on 40 and 20 meters. QSL via bureau or direct. 73 & 11! [tnx info 9A6NDD].
s52o
Prispevkov: 406
OdgovorNapisal/-a s50v » 20 Jun 2013, 11:40
Hi All,
with the call-sign IW5AB/p & IZ5GST/p
on June, 20 2013 starting @ about 13.00z
will be activated the following references:
DCI FI-721 WCA I-04482 DAI TC-1013
DCI FI-722 WCA I-04483 DAI TC-1013
DCI FI-058 WCA I-03819 DAI TC-1013
Thank @ All for attention.
Steve, IZ5GST / N1GST
s50v
Prispevkov: 263
Kraj: LJ/SG
OdgovorNapisal/-a s52o » 28 Apr 2014, 17:36
V času prvomajskih praznikov so v DL predvidene sledeče aktivacije:
Hello, below compiled listing for planned activities on castle day at may 01:
DL-04064 BRB-069 – Schloss Blankensee – DC7VS, DG2RON
DL-02880 HBN-124 – Schloss Grossen-Buseck – DO6MBA
DL-00740 RPB-061 – Schloss Kyrburg – DH6PC
DL-00858 RPB-179 – Schloss Lichtenburg – DK5VQ
DL-02132 SAB-001 – Schloss Wernigerode – DL6CWR
DL-02142 SAB-011 – Schloss Zerbst – DL9ZEA
DL-02144 SAB-013 – Burg Stapelburg – DL6CQG
DL-02150 SAB-019 – Schloss Merseburg – DL2HWB
DL-02151 SAB-020 – Schloss Frankleben – DL0MER (DL9HUH, DL1HUD, DL1HRE, DK6UC)
DL-02154 SAB-023 – Schloss Ilsenburg – DL9ZHG
DL-02173 SAB-042 – Schloss Hohenerxleben – DK2AJ, DL4NTC
DL-02179 SAB-048 – Großes und kleines Schloss Blankenburg – DL9ZOG
DL-02180 SAB-049 – kleines Schloss Blankenburg – DL9ZOG
DL-02182 SAB-051 – Burgruine Heimburg – DL6MST
DL-02195 SAB-064 – Grillenburg – DL5GSM
DL-02204 SAB-073 – Schloss Stolberg – DM2BPG, DL2HUC
DL-02208 SAB-077 – Schloss Neue Residenz Halle – DK5RK
DL-02232 SAB-101 – Schloss Berssel – DL4ST, DL8MLD
DL-02275 SAB-144 – Schloss Zörbig – DG3HWO, DL3HWO
DL-02285 SAB-154 – Schloss Radis – DO2AS, DL2HQS
DL-02286 SAB-155 – Schloss Reinharz – DM4JH, DG0HAB
DL-02289 SAB-158 – Schloss Wittenberg – DK0WWB, DN3WB
DL-02301 SAB-170 – Schloss Moritzburg (Zeitz) – DL2HDI, DL1AGS
DL-02306 SAB-175 – Schloss Rehmsdorf – DL1HWR
DL-02327 SAB-196 – Schloss Ostrau – DM7MA, DM7EA
DL-01171 SAX-065 – Burg Stolpen – DL5DWF
DL-01218 SAX-112 – Schloss Colditz – DK0MIT (DL1RUN, DL2LUN)
DL-01255 SAX-149- Rennaissanceschloesschen in Rodewisch – DL1JKK, DL5JRA
DL-01263 SAX-157 – Schloss Steinpleis – DL4UP
DL-01275 SAX-169 – Burg Rochlitz – DK0MIT (DL1HMM)
DL-01286 SAX-180 – Schloss Augustusburg – DK0MIT (DG0BBE)
DL-01293 SAX-187 – Schloss Sachsenburg -DK0MIT – (DG0ERS, DL1JBE)
DL-01300 THB-006 – Schloss Ranis -DL7LM 40m
DL-01339 THB-045 – Schloss Schwarzburg – DL3AMB
DL-01355 THB-061 – Schloss Berka – DK0THB (DM2AN, DJ2YY)
DL-01367 THB-073 – Neues Schloss Lobenstein – DL7SMK
DL-01395 THB-101 – Burg Haineck – DF0WCA (DL5AWI), DM2EV
DL-01398 THB-104 – Ruine Lobenstein – DL7SMK
DL-01452 THB-158 – Ruine Scharfenstein – DL0GMA (DJ3AX)
DL-01475 THB-181 – Mainzer Schloss Heiligenstadt – DG0OKC, DL1AUU 80/40m
DL-01477 THB-183 – Schloss Knau – DL4APJ
DL-01504 THB-210 – Schloss Breitungen – DL1AXB
DL-01511 THB-217 – Burg Seebach – DL3WM, DG0OS, DL1ALA
DL-01517 THB-223 – Schloss Poelzig – DO3HSJ, DO8IH, DN1AF 80m, UKW
DL-04238 THB-241 – Kloster/Schloss Mildenfurth – DJ2AX THB-101 Burg Haineck
DL-02831 BOB-040 – Schloss Prunn – DA0WCA (DF6EX)
DL-02833 BOB-042 – Burg Rosenburg – DA0CW/p (DF6EX)
DL-02335 BOB-001 – Burg Falkenberg – DA0WCA (DF6EX)
73,44,11 Manfred –DF6EX-
s52o
Prispevkov: 406
Vrni se na Najave S5 WCA
