LZ Open 80m Sprint contest
OdgovorNapisal/-a s58ru » 15 Okt 2010, 20:17
LZ Open 80m Sprint contest will take place on 16-th of October (saturday) from 02.00 to 06.00 UTC (only 4 hours total contest time).
We have added 3 new categories :
Straight Key Entrants, Field Operation Stations and Solar Energy Powered Stations.
We invite CW operators from all over the world to take part in this event and to join us in our efforts to make this contest more dynamic. We need 300 participants !
Everyone works everyone in a 30 minutes time period.
You can watch live logs check right after the contest. There is a live result's page changing after every new log received. You can also compare your log with any other log and you can see your errors. This cross check function is unique and we are proud to be the first contesters using it.
We are also recording the contest so it will be interesting for you to hear how your signal sounds here in Sofia.
Please see the rules at http://www.lzopen.com
Every participant is very important to us! We are open to any critics or suggestions.
Thanks for your support - we all hope to see you in the contest !
73 , LZ1GL Krasimir Latinov
s58ru
Prispevkov: 1231
Pridružen: 28 Okt 2004, 21:07
Re: LZ Open 80m Sprint contest
OdgovorNapisal/-a s52w » 16 Okt 2010, 08:05
Lepo tekmovanje. Po dolgem času delal s »pešakom« TS-1 ki začuda še dela. Sicer pa čutim rahle bolečine v roki. Verjetno rezultat (155 QSO) z F tipkami nebi bil veliko boljši. Bolj bi pomagalo, če bi svoj trap dipol dvignil malo višje od idealne višine Beverige antene :) . Z obzirom, da aktivnost v našem KVP pada, bi se dalo tekmovanje poživiti s takšnimi ali podobnimi pravili. Ampak to je že druga zgodba…
s52w
Prispevkov: 541
Pridružen: 07 Nov 2004, 15:38
OdgovorNapisal/-a s55m » 16 Okt 2010, 13:53
A loga pa še nisi poslal?
OdgovorNapisal/-a s52w » 16 Okt 2010, 23:25
s55m napisal/-a:A loga pa še nisi poslal?
Verjetno sem jih presenetil s hitrostjo pošiljanja in ga niso takoj obdelali, ker sem ga poslal že ob 06.10 UTC. Sedaj ob 22.00 UTC je gor in že pridobiva na UBN :P
s52w
Prispevkov: 541
Vrni se na Tekmovanja KV
