WRTC 2010
WRTC 2010
OdgovorNapisal/-a s50xx » 01 Jul 2010, 09:19
10./11. julija, v času IARU HFC tekmovanja se bo dogajal tudi WRTC 2010 (http://www.wrtc2010.ru/). 50 ekip iz celega sveta se bo pomerilo na ruskih poljih za naslov najbolšega. Znani so tudi že klicni znaki:
R31A R31D R31N R31U R31X
R32C R32F R32K R32O R32R R32W R32Z
R33A R33G R33L R33M R33Q R33U
R34C R34D R34O R34P R34W R34X R34Y R34Z
R36C R36F R36K R36O R36W R36Y R36Z
R37A R37G R37L R37M R37P R37Q R37U
R38F R38K R38N R38O R38W R38X
R39A R39D R39M R39R
O nagradah in diplomah za delane WRTC postaje:
http://www.wrtc2010.ru/?id=51&idp=29
Kristjan, S50XX
s50xx
Prispevkov: 210
Pridružen: 10 Sep 2002, 19:53
Kraj: Vogrsko
Re: WRTC 2010
OdgovorNapisal/-a S59W » 06 Jul 2010, 07:31
Še malo bolj obširno:
World Radisport Team Championship (WRTC) is the main contesting event of 2010. This time WRTC will be held around the city of Moscow - the capital of Russia, where 50 teams from all parts of the world will be in the same field.
We invite you to support WRTC and take part in the IARU HF Championship from 12:00 UTC July, 10 till 12:00 UTC July, 11.
Rules of IARU HF Champhionship: http://www.wrtc2010.ru/index.php?id=21
Rules for special prizes for QSOs with WRTC teams: http://www.wrtc2010.ru/index.php?id=77
Download a table with the special callsigns used during WRTC: http://www.wrtc2010.ru/press/wrtc_callsigns.pdf
Do not forget to send your logs till the July, 11 18:00 UTC to: logs@wrtc2010.ru or upload them at: http://www.wrtc2010.ru/upload
We also invite you to see WRTC online information:
- photo reports from the event starting on the July, 6 http://www.wrtc2010.ru/photos/
- video broadcasting of the major events WRTC (opening ceremony, location drawings, award ceremony and more): http://www.wrtc2010.ru/video/
- watch every 5 minutes for competitors scores: http://www.wrtc2010.ru/online
See you in the contest on the July, 10-11 and at our site.
Best regards,
Organizing Committee
GL, Tomaž/S59W
S59W
Prispevkov: 91
Pridružen: 13 Okt 2004, 15:44
Re: WRTC 2010
OdgovorNapisal/-a s55o » 09 Jul 2010, 09:52
Jutri je tekmovanje WRTC. Upam, da bomo uspeli čimveč zvez narediti z r3?? postajami in naši ekipi želimo čimveč uspehov!
Prispevkov: 2596
Re: WRTC 2010
OdgovorNapisal/-a s50xx » 09 Jul 2010, 22:37
Dva izmed 50 najavljenih znakov nista bila izdana, R34Y in R37G.
Če boste lovili WRTC postaje, torej samo 48 znakov.
Kristjan, S50XX
s50xx
Prispevkov: 210
Kraj: Vogrsko
Re: WRTC 2010
OdgovorNapisal/-a s55m » 11 Jul 2010, 19:59
Če bo tudi po pregledu dnevnikov tako, kot je na online score listi, lahko samo čestitam S50A in S57AW za čudovit in vseh pohval vreden rezultat!
Field day stile:
Re: WRTC 2010
OdgovorNapisal/-a S54O » 11 Jul 2010, 20:27
s50xx napisal/-a:Dva izmed 50 najavljenih znakov nista bila izdana, R34Y in R37G.
Poleg omenjenih mi manjka v logu še R39U. Verjetno tudi tega ni bilo, ker ga niti med spoti ne najdem.
Ne glede na to, kaj bo pokazal pregled dnevnikov, res čudovit pogled na http://www.wrtc2010.ru/online/online_results.php
Bravo Tine in Robi!
73 de Boris S54O
S54O
Prispevkov: 226
Pridružen: 02 Jun 2003, 13:35
Re: WRTC 2010
OdgovorNapisal/-a S57XX » 12 Jul 2010, 11:55
S54O napisal/-a:
Bravo Tine in Robi!
73 de Boris S54O
Meni manjkata samo najavljena. Ene znake je bilo kar težko zbrskati :-?
LP Jure
S57XX
Prispevkov: 679
Pridružen: 28 Feb 2002, 02:00
Kraj: Škofja Loka
Re: WRTC 2010
OdgovorNapisal/-a S54O » 12 Jul 2010, 13:02
Trudim se najti R3xx znake (kdo je kdo) - da vidim, komu sem "največ pomagal" :-)
Na clustru vidim, da je s53mm objavil, da sta Tine in Robi bila R39D
(žal samo 2x logirana pri meni, pa niti enkrat ju nisem spotiral :-( ).
http://www.5bits.net/lu5dx/2010-wrtc-spots-analysis/
73 de Boris S54O
S54O
Prispevkov: 226
Re: WRTC 2010
OdgovorNapisal/-a S57XX » 12 Jul 2010, 13:26
Najverjetneje bodo znake dopisali šele ob objavi rezultatov. Takrat bo vse jasno :D
LP Jure
S57XX
Prispevkov: 679
Kraj: Škofja Loka
Re: WRTC 2010
OdgovorNapisal/-a S57XX » 12 Jul 2010, 21:15
Četrta! Čestitke!
LP Jure
S57XX
Prispevkov: 679
Kraj: Škofja Loka
Re: WRTC 2010
OdgovorNapisal/-a S59W » 13 Jul 2010, 07:15
Končni rezultati:
1. RW1AC / RA1AIP
2. ES5TV / ES2RR
3. N6MJ / KL9A
4. S50A / S57AW
Zgleda, da sta Tine in Robi zaradi napak izgubila dve mesti. Čestitke našima za najboljši S5 score na WRTC.
GL, Tomaž/S59W
S59W
Prispevkov: 91
Re: WRTC 2010
OdgovorNapisal/-a S51AY » 13 Jul 2010, 19:45
Kot mi je znano, so bili problemi objektivne narave. Kljub vsemu pa si zaslužita najmanj velike čestitke za fantastično 4. mesto !
Ali po nogometno : "Krajevna skupnost" iz srednje Evrope je povzročila "globalno segrevanje" !
Pridružen: 01 Jan 2006, 12:01
Re: WRTC 2010
OdgovorNapisal/-a S53W » 13 Jul 2010, 21:00
Tole bi vam rad povedal:
Zelo , zelo malokrat se oglašam, tudi tokrat se nisem imel namena.
Ker, da, jima izrečem čestitke, bi bilo premalo - od mene NEPOMEMBNO!!!!!
Ampak, nekaj mi je reklo:
- Včeraj in danes sem naredil samo 17 zvez na kv, in 9 (devet) od korespondentov
iz PY, W, DL, SM, OK, F, ..., mi podarja iskrene čestitke za izredno lep -
fantastičen uspeh na WRTC 2010 v Moskvi, slovenski ekipi, Tinetu in Robiju...
In, tole vama tudi, takole na široko, posredujem.... ....
Zelo, zelo ponosni smo na vaju, vzor sta nam...
73!
Bojan, S53W
Bojan, S53W
S53W
Prispevkov: 25
Pridružen: 12 Okt 2006, 10:03
Kraj: Maribor
Re: WRTC 2010
OdgovorNapisal/-a S51V » 14 Jul 2010, 09:10
Čestitam, bravo fanta!
S51V
Prispevkov: 43
Pridružen: 14 Mar 2008, 11:03
Kraj: MOTA
Vrni se na Tekmovanja KV
