TM-D710E, nov Kenwoodov proizvod, zamenjava za TM-D700,
bom imel, kot kaže med prvimi na zalogi. Oktobra bo zaloga normalna, prve  pa dobim že v septembru.
Poln opis z cenami bo na
www.elnaprave.com takoj po dopustu.
Ker je novica sveža, besedila nisem prevedel.
Miro S58T
31st July 2007
We are pleased to send you preliminary information on our new VHF/UHF Dual Band Mobile Transceiver, the TM-D710E.
TM-D710E		VHF/UHF Dual Band FM Mobile Transceiver
1.	MAIN FEATURES
Built-In TNC
It has a built-in 1200/9600 bps TNC. With a portable computer, this allows you to enjoy Packet operation easily and it also enables you to enjoy the APRS®, and EchoLink® operation modes.
Full Dot LCD & Smart menu
The radio has a large full dot multi-functional LCD display (235x65 dots).  It enables you to see the display easily, and you can operate the radio via its smart menu system which you can operate instinctively.
Over 60 APRS® menus
Various new APRS features are available.  The predessor model, the TM-D700E, had 26 menus but the new TM-D710E has over 60 menus for greater APRS enjoyment.
High RF Power Output (50W)
The TM-D710E provides an impressive 50 watts of RF power on both VHF & UHF bands, with a choice of High/Mid/Low settings.
Dual Receive on Same Band (VxV, UxU, VxU)
In addition to simultaneous receive on both VHF and UHF bands, the TM-D710E can receive two frequencies on the same band (V x V or U x U).
Green & Amber Colour Display
To maximize visibility, the backlight colour of the large LCD display can be switched between green and amber.
Programmable Memory
For extra versatility, the TM-D710E has a programmable memory function that can store five entire operating profiles, ready for instant recall at the push of a button.  Each profile includes such settings as display mode, frequency range and memory mode.
1,000 Memory Channels
There are 1,000 split memory channels for storing essential data, such as transmit and receive frequencies, frequency step and tone frequency.  Each channel can be identified with a 6-digit alphanumeric memory name. The memory data can be edited and stored on a PC, using the optional PG-5G interface cable and MCP-2A memory control software.
Multiple Scan
As well as VFO scan, programmable scan, MHz scan, memory scan and call scan, the TM-D710E offers memory bank scan. The 1,000 channels can be grouped into 10 banks for selective scanning. Scan resume (time-operated, carrier-operated and seek), memory channel lockout, tone scan, CTCSS scan and DCS scan functions are built-in.
Built-in CTCSS/DCS
The TM-D710E is equipped with analogue CTCSS (42 subtone frequencies) and digital DCS (104 codes).
ECHOLINK® Memory
Up to 10 EchoLink® memory stations can be stored using call signs (max. 8 alphanumeric characters). You can easily access an Echolink node terminal without having to use a call sign.
ECHOLINK® NODE TERMINAL Operation
When the TM-D710E is connected to a PC (with the necessary software installed) usinig the optional PG-5H, it can operate as a node terminal for Echolink® access.
(Note)
*	APRS is a registered trademark Bob Bruninga, WB4APR
*	Echolink® is a registerted trade mark of Synergenics LLC
*	Echolink® official WEB site:
http://www.echolink.org
Other Features
	APRS features
	Decay Algorithm
	Proportional Pathing
	New-N Paradigm
	State/Section/Region Path
	Special Call Alert
	User Phrases
	QSY Function
	Visible Message Notifications
	Menu System
	Wide Band Reception : 118-524MHz & 800-1300MHz as standard
	Separate VOL/SQL for A and B Bands
	GPS connector for NMEA 0183 format
	8-Pin Mini-DIN connector for PC connection
	Programmable Function Keys
	Band Mask (Mask unused band)
	Call Channel
	S-meter Squelch & Hysteresis Timer
	Monitor Function
	Audio Mute & Hang-up Timer
	Automatic Power Off (up to 3-hours)
	MHz Mode
	Selectable Frequency Step
	Shift Function
	Repeater Offset (selectable)
	Automatic Repeater Offset (On/Off, VHF only)
	Reverse Function
	DTMF Memory (10 channels, 16 digits)
	Time-Out Timer
	Key Lock
	Power-on Password Protection
	Memory Shift
	Programmable VFO
	Beep On/Off, Volume Control
	Microphone program Function
	Channel Display Mode
	Power-On Message
	LCD Brightness Control, Automatic Dimmer
	Switch to External Speaker
	Reset (VFO, PART, PM, FULL)
	Cross Band Repeater Function (Dealer Modification)
	DTMF Remote Control (available in Cross Band Repeater mode)
2.  OPTIONAL ACCESSORIES
	MC-59		16-Key Hand Microphone
	MC-60A		Desktop Microphone
	MJ-88		Microphone Plug Adapter
	PG-2N		DC power Cable
	PG-3B		DC Line Noise Filter
	PG-5A		Data Cable
	PG-5F		Extension Cable Kit (4m)
	PG-5G		Programmable Interface Cable
	PG-5H		PC Interface Cable Kit
	SP-50B		External Speaker
2.	SUPPLIED ACCESSORIES
	16-Key Hand Microphone (MC-59)
	Mounting Bracket
	Mobile Angle, Panel Bracket (for Mobile Use), Panel Stand (for Fixed Base Station use)
	DC-Cable
	Screw set & Fuses
	Panel Separate Cable(8Pin Modular <->8Pin Modular 4m length)
	GPS Cable(Φ2.5mm Stereo Plug 2m length)
	Instruction Manual (Basic Operation)
	In-Depth Operation Manual  (CD-ROM)
3.	SPECIFICATIONS
General	TM-D710E
Frequency Range	Band A & B
Band A
Band B	TX : 144-146 MHz,  430-440 MHz
RX : 118-524MHz
RX : 136-524MHz,  800-1300MHz
Mode		F1D, F2D, F3E
Operating Temperature Range	-20℃ to +60℃
Frequency Stability		Within ±5ppm (-10°~ +50°C)
Antenna Impedance		50 ohm
Power Requirement		DC13.8V ±15%
Current Drain	Hi : 50W	Less than 13.0A (VHF)
Less than 13.0A (UHF)
(transmit)	Mid : 10W 	Less than 5.5A (VHF)
Less than 6.5A (UHF)
	Low : 5W	Less than 4.0A (VHF)
Less than 5.0A (UHF)
Dimensions (W x D x H)
Projections not included	Panel : 155 x 38 x 70 mm
Body :  140 x 142 x 43 mm
Weight (net)	Control Panel
TX/ RX Unit	0.3 kg
1.2 kg
Transmitter
RF Output Power	Hi	50W
	Mid	Approx. 10W
	Low	Approx. 5W
Modulation	Reactance modulation
Maximum Frequency Deviation	Within ±5kHz
Spurious Radiation	Less than -60dB
Modulation Distortion (300Hz ~ 3kHz)	Less than 3%
Microphone Impedance	600 ohm
Receiver
Circuitry	Double Super Heterodyne
Intermediate Frequency
1st IF (A Band/B Band)
2nd IF (A Band/B Band)
45.05MHz / 49.95MHz
455kHz / 450kHz
Sensitivity (VHF / UHF)	Less than 0.16μV
Squelch Sensitivity		Less than 0.1μV
Selectivity	-6 dB
-50 dB	More than 11kHz
Less than 30kHz
Kenwood follows a policy of continuous advancement in development.
For this reasons, specifications may be changed without notice.
