ISS contact Coronado School in California on 26.May at 16:39
Stržniki, prehodi, delovanje, navodila, nastavitve, ...
Moderator: S56CT
OdgovorNapisal/-a S56CT » 23 Maj 2005, 00:53
Detail for ISS contact with Coronado School in California on 5/26/05
at 16:39UTC
Coordinator: Dieter Schliemann,KX4Y Event Type: School Contact
Start Date (mm/dd/yy): 05/26/05 End Date (mm/dd/yy): 05/26/05
Open to the Public: Yes Special Event Callsign: NA1SS
City: State/Province: CA
Country: US
Additional Comments:
We hope to see you join us in listening to this contact between the
ISS and the Coronado School in California on 26 May 2005 on the
EchoLink AMSAT and EDU_NET servers. The event will start at 16:39UTC,
but we will transmit audio from preparations before the contact.
Please give the EDU_NET server your preference over the AMSAT server
for your connection. This will keep the load light on the AMSAT
server, assuring us of better audio quality all around.
If using IRLP is more convenient for you than using EchoLink, please
connect to the IRLP reflector 9010. The ARISS IRLP Team is feeding
the audio into that reflector. No prior approval is needed to connect
Thanks for your interest and 73, de Dieter kx4y
S56CT
Prispevkov: 1113
Pridružen: 20 Jan 2002, 02:00
Vrni se na ECHOLINK
