Kontest ATV
Amaterska TV
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 24 Maj 2024, 10:05
Tekmovanje IARU ATV da, tekmovanje IARU ATV ne?
Mislim, da to ni dilema. Morda je dilema med tem, ali narediti nekaj QSO ali v celoti ignorirati tekmovanje IARU ATV.
Za IARU je ATV Pepelka.
Po letu 2005, letu bolj ali manj, gre ATV na "podstrešje". Od časa do časa se pokaže v kakšni novi "preobleki" DVB-S, DVB-T, satelit, ...
Končni udarec ATV je zadal IARU. IARU, ki bi moral pomagati, spodbujati in usmerjati, je vnesel kaos in spodbuja opuščanje RA ATV.
Še nikoli nisem slišal, da bi gospodinja na tržnici prosila, daj temi zelenjave.
IARU ne dela razlike med FM, DVB-S2, ... vse je "juha". In ustanovili so komisijo strokovnjakov. (Mislim, da ti strokovnjaki še nikoli niso sodelovali na ATV tekmovanju .)
V pravilih tekmovanja IARU ATV med drugim piše:
Vodja tekmovanja IARU ATV: Organizirajte in objavite prazno datoteko dnevnika vsaj 3 tedne pred tekmovanjem, sodnik prijavite se pravočasno in rezultate objavite v šestih tednih po tekmovanju.
“IARU ATV contest manager: Organize, and publish blank log file at least 3 weeks before the contest, judge logs in time, and issue results within six weeks after the contest.”
Na straneh društev sploh ni pravil, tudi v angleščini ne...
88 s58ru
s58ru
Prispevkov: 1079
Pridružen: 28 Okt 2004, 21:07
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 24 Maj 2024, 13:39
Hi Rudy
The updated Contest Rules have been published on the IARU Website for some weeks:
https://www.iaru-r1.org/about-us/commit ... ontesting/
The rules are here:
https://www.iaru-r1.org/wp-content/uplo ... ontest.pdf
and the spreadsheet is here:
https://www.iaru-r1.org/wp-content/uplo ... 4-4-21.xls
The rules were amended this year following a request for comment (which I sent to you) and discussions amongst contest participants at the last IARU Region 1 conference.
All ATV modes (FM, AM, DVB-S/S2, DVB-T/T2) are allowed in the contest. Satellite is excluded, but there are some proposals for a separate satellite event under discussion.
I have copied this e-mail to Rob PE1ITR who is taking over running the contest this year.
Look forward to seeing you in the list of entrants for this year.
s58ru
Prispevkov: 1079
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 08 Jun 2024, 08:17
Nered, vreden IARU.
Danes bodo na dan prišli vsi ATV čudeži.
s58ru
Prispevkov: 1079
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 08 Jun 2024, 11:42
https://slovhf.net/iaru-r1-atv-2024-tekmovanje/
Komu je namenjeno to vabilo?
Že v letu 2005 je bila Slovenija razdeljena na tri dele. Nekaj ATV-jašev je bilo na severu od Celja. Nekaj jih je bilo južno od Postojne. Osrednja Slovenija je bila siva cona ATV.
Takrat smo imeli ATV managerja pri zvezi; enkrat letno srečanje na Trojanah; vsaj na papirju 15-20 repetitorjev; ATV Slovenski kontekst; IARU ATV kontekst;…
Danes, ATV manager je v »oblakih«; lahko se udeležujemo le na IARU kontekstih; imamo dva ATV RPT; v Sloveniji skoraj nimamo korespondentov; na Hrvaškem verjetno ni ATV-jašev; v sosednji Italiji vlada IARU- kaos.
Danes niso samo volitve v Evropski Parlament. Danes se bo videlo koliko je uspešen IARU in posredno razne zveze RA.
s58ru
Prispevkov: 1079
Vrni se na ATV
