Danes je 21 Avg 2019, 16:40
OdgovorObjavljeno: 05 Jan 2014, 19:55
Pridružen: 11 Jul 2003, 12:58
Prispevkov: 419
Pozdravljeni.
Zanima me zakaj ni nobenih podatkov o packet v Slo,pogledal sem že skoraj vse,kjer se je dalo,pa ni nič novejših podatkov?
Tel.preko e-mail ali ZS.
Član Radiokluba S53AJK
OdgovorObjavljeno: 05 Jan 2014, 21:38
Pridružen: 25 Sep 2001, 01:00
Prispevkov: 281
Kraj: Nova Gorica, JN65TW
Pozdravljen, Luka,
Za "hitri" ax.25 packet radio nimam podatkov, koliko je kje še operativen. V priponki najdeš shemo jugozahodnega dela NBP omrežja v obliki
za "Gugl zemljo". Mogoče vidiš Golo (S55YIG) iz svojega QTHja.
73 de tom*/s56g
p.s.: za podatke drugih RA digitalnih omrežij (tudi wifi, uporabljan v radioamaterske namene)se toplo priporočam!
Priponke:
Komentar datoteke: NBP
NBP_v_1_2.zip [3.79 KiB]
Prenešeno 249 krat
OdgovorObjavljeno: 06 Jan 2014, 09:09
Pridružen: 16 Nov 2004, 10:33
Prispevkov: 447
Kraj: Prelog, JN76HC
Najbrž se kaj dosti ni spreminjalo v zadnjem času tako da bi tole moralo še veljati: http://lea.hamradio.si/~s53m/map/index.html
OdgovorObjavljeno: 06 Jan 2014, 20:19
Pridružen: 03 Apr 2006, 13:38
Prispevkov: 26
Kraj: Deutschlandsberg, Austrija
...and some old info regarding the sites is located here:
http://lea.hamradio.si/~s51kq/PACKET.HTM
some quick check displayed the following situation, as far as I was able to reach or identify:
s55yvu Radlje (144,775), operational, but no active links
s55yko Kor, non operational (neither on 144,850 or higher links)
s55ymb Pohoje (144,900), operational, Links to s55yms, s55yku-1, s55yor active
s55yms Murska Sobota (144,825) operational, Link to s55ymb active
s55yku Kum operational, Link to s55ylj, s55yve, s55ybk, s55yza operational
more I didn't get sry..
it would be very cool to have the old and the new world connected together,
lep prodrav Robert
OdgovorObjavljeno: 06 Jan 2014, 20:37
Prispevkov: 26
just for doc purpose, I've been able to connect to Golo S55yig, but there no hook to the google earth mentioned link.
MSSV:S55YMS>
*** Poslusani (minute,stevilo) ***
4: S55YMB-1 (4,385)
9: OE6XSR (7,223)
MSSV:S55YMS>
*** Klice S55YMB OE6RKE-1 na kanalu 4 ***
MSSV:S55YMS> Connected to S55YMB
*** Povezava vzpostavljena na kanalu 4 ***
MBR:S55YMB>
*** Klice S55YKU-1 OE6RKE-2 na kanalu 1 ***
MBR:S55YMB> Connected to S55YKU-1
*** Povezava vzpostavljena na kanalu 1 ***
*** Dobrodosel na Kumu ! ***
KUM:S55YKU>
1: S55YMB-1 (2,207676)
5: S55YLJ-5 (2,217175)
1: S55YLJ-1 (2,216791)
2: S55YVE-1 (4,215882)
3: S55YBK-7 (4,208728)
KUM:S55YKU>
*** Klice S55YLJ-1 OE6RKE-3 na kanalu 1 ***
KUM:S55YKU> Connected to S55YLJ-1
*** Dobrodosel na Krvavcu ***
LJU:S55YLJ>
5: S55YKU-5 (2,80350)
1: S55YKU-1 (2,89096)
2: S55YIG-8 (3,73832)
2: S55YIB-8 (3,77383)
LJU:S55YLJ>
*** Klice S55YIG-1 OE6RKE-4 na kanalu 2 ***
LJU:S55YLJ> Connected to S55YIG-1
*** Povezava vzpostavljena na kanalu 2 ***
*** Zivijo de SuperVozelj GOLO:S55YIG ***
GOLO:S55YIG>
8: S55YLJ-2 (1,6121)
1: S55YNG-4 (8,1064)
GOLO:S55YIG>
OdgovorObjavljeno: 06 Jan 2014, 20:50
Prispevkov: 419
Zanima me ker program za win 7 64bit in nastavitve,uporsbil bi postajo kenwood tm d710ge.
OdgovorObjavljeno: 06 Jan 2014, 21:05
Prispevkov: 26
flexnet in wpp delam super z win7 32 in 64 bit..
to check the s5 old pr network yourself I found an inet based entry.
1) connect to telnet gate of wa7v
2) change with flex to xnet host of wa7v-2
3) connect with c ir3ip to digi in trevisio
4) connect with netlsv to net node of iz3lsv xnet host
5) connect with c ir3uhu to the next supervozelj
6) and finally connect with c s55ylj the sv digi north of ljubljana
maybe this handy for someone..
lp Robert, 73 de oe6rke
OdgovorObjavljeno: 06 Jan 2014, 23:32
Pridružen: 29 Jun 2008, 22:16
Prispevkov: 113
Kraj: JN76JD- Moravče
Enkrat, zdaj že pred parimi leti sem se spravil in naredil zemljevid, na katerem so vsa ax.25 vozljišča.
Če klikneš na katerega od njih, imaš zraven napisane informacije. Kakšnih pretiranih sprememb ni bilo, se pa gradi novo NBP omrežje, trenutno samo na zahodu Slovenije. Upam, da ti bo kaj v pomoč ;)
Zemljevid AX.25
http://www.geopedia.si/?params=T1522#T1522
73 de Gregor
OdgovorObjavljeno: 07 Jan 2014, 23:32
Prispevkov: 281
hola, Vsi!
Matjaž mi je sporočil, da na S55YIG še deluje ax.25 na 13cm; od tam naprej pa gre proti Črni Prsti S55YCP in gatewayu S50YFE samo še NBP.
Obeta se precej burno konstruktorsko leto in upajmo, da se bo omrežje spet razpredlo čez našo kokoško :) posebej še, če bo volja in interesi
tudi za oživitev nekaterih zapuščenih digipeaterjev.
73 de tom*/s56g
p.s.: mni tnx for your kind assistance, Robert :) GL!
