Napisal/-a s50ml » 23 Feb 2010, 12:00
izsek iz navodila na strani 34:
Storing Independent Transmit Frequencies (“Odd Splits”)
All memories can store an independent transmit frequency, for operation on repeaters with
non-standard shift. To do this:
1. Store the receive frequency (downlink) using the method already described under
MEMORY STORAGE (it doesn’t matter if a repeater offset is active).
2. Turn to the desired transmit (uplink) frequency, then press and hold in the [F/W] key
for one second.
3. Within five seconds of releasing the [F/W] key, rotate the DIAL knob to select the
same memory channel number as used in step “1” above.
Upam da pomaga.
LP Matjaž
