Danes je 01 Nov 2020, 02:37
Napiši novo temo Odgovori na temo  [ 47 prispevkov ]  Pojdi na stran 1, 2, 3, 4  Naslednja
 Naslov prispevka: 1st EPC WW DX Contest
OdgovorObjavljeno: 05 Jan 2009, 02:09
Prispevkov: 2423
Dear OM
The EPC WW DX Contest Comite would like to invite you to participate
in the 1st EPC WW DX Contest that will take place
from 12.00UTC on 31 January untill 12.00 UTC February 1st, in BPSK125.
All information is on : http://www.epcwwdx.srars.org
Please join us with your participation, and also we would require your
help in promoting this event to all your Amateur Radio friends.
We would like to wish you all Happy New Year 2009
Jose Luis Pinto Camacho
EPC # 0278
Contest Promoter
EXISTING EPC MANAGER
ct3ee@netmadeira.com
 Naslov prispevka: Re: 1st EPC WW DX Contest
OdgovorObjavljeno: 29 Jan 2009, 03:13
Prispevkov: 2423
Dear Fellow PSK Contester,
The European PSK Club knows you as one of the most active PSK Contest Operators. We won't miss you in the coming EPC WW DX Contest 2009. This is just another reminder sent especially for the most active PSK operators. We would like to invite you again to take part in the contest, the rules can also be found at www.epcwwdx.srars.org The contest will be held from 12:00 UTC on 31.01.2009 to 12:00 UTC on 01.02.2009 on the BPSK125 mode. If you have any questions please do not hesitate to contact our Contest Secretary at http://www.epcwwdx.srars.org/index.php/contact.html
All the very best and 73!
UT7FP Victor
EPC WW DX Contest Committee
OdgovorObjavljeno: 29 Jan 2009, 07:42
Pridružen: 01 Jan 2006, 11:01
A ima kdo StatsEPCWWDX.dll za MixW, ali kakor so ga pač poimenovali ? Ali pa če kdo ve, kako se ga da narediti ?
OdgovorObjavljeno: 29 Jan 2009, 10:37
Ne odgovarjam sam sebi..., morda bom le drugim pomagal. Contest statistiko za MixW sem našel tu:
http://www.qrz.ru/contest/detail/172.html
Rusi imajo vse...
GL, CU in contest !
OdgovorObjavljeno: 29 Jan 2009, 12:32
Prispevkov: 2423
Je kdo že pripravil N1MM za 125bps psk? Nekaj sem poskušal z MMVARI engine, pa mi noče oddajat z makroji preko N1MM funkcijskih tipk ... Z MMVARI F-tipkami še nisem poskusil... Brez problema pa deluje, če nastavim hitrost 31bps... ?
Sicer pa bom izgleda delal od doma LP 80M na nizek INV V....
OdgovorObjavljeno: 29 Jan 2009, 16:52
Pridružen: 02 Jul 2001, 01:00
Prispevkov: 315
Kraj: JN75RX
s55z napisal/-a:
vse ok lepo in prav... kater ctest pa boš izbral? da bodo množilci dxcc + nr 001 ? :-)
nažalost klasićni WW ne :=)
tnx info
73 Simon, S53K
OdgovorObjavljeno: 29 Jan 2009, 20:08
Pa ne samo to, tudi različno točkovanje, odvisno od banda... Jaz sem se že pomiril v usodo, da bom delal brez statistike, izračun pa bo po tekmovanju. Potem sem našel omenjeni dll, pa vse dela perfektno, kot je treba.
OdgovorObjavljeno: 29 Jan 2009, 20:16
Prispevkov: 315
Kraj: JN75RX
S51AY napisal/-a:
.dll za n1mm ? :-)
73 Simon, S53K
OdgovorObjavljeno: 29 Jan 2009, 20:30
Prispevkov: 315
Kraj: JN75RX
S51AY napisal/-a:
striček google je vedno z nami :)
http://groups.yahoo.com/group/N1MMLogger/message/58928)
vzpodbudno pa je tole :
RE: [N1MM] EU PSK WW DX contest
I will look at this tonight and send it to Tom.. This was fixed in a
previous version but a mistake on my part caused it to be broken again....
73 Rick N2AMG
http://www.n2amg.com
bomo videli :)
73 Simon, S53K
OdgovorObjavljeno: 29 Jan 2009, 20:50
S51D napisal/-a:
S51AY napisal/-a:
.dll za n1mm ? :-)
Ne. Saj sem napisal, da za MixW... Mislim, da je najboljši, saj je v PSK tekmovanjih najvažnejši sprejem. Da ne ponavljam ostalih možnosti. Se pa dobro "prelevi" tudi v contest program. Če se spomnite debate z S57X, enkrat sem ga za preizkus uporabil v CQWW DX CW tekmovanju. Takrat smo ga "prepričevali", da je deloval, kot TR. Samo, preveč se zakomplicira, pa je vseeno dosti enostavneše delati z TR...
OdgovorObjavljeno: 29 Jan 2009, 21:17
Prispevkov: 315
Kraj: JN75RX
S51AY napisal/-a:
S51D napisal/-a:
S51AY napisal/-a:
.dll za n1mm ? :-)
se ti zdi, da ima boljši engine MixW kot MMVARI ? :-)
73 Simon, S53K
OdgovorObjavljeno: 29 Jan 2009, 22:37
Prispevkov: 2423
Simon, kot si omenil ima zadnja verzija tudi EPC WW DX contest... Točkuje brez napake! Glede MMVARI engine javim... grem testirat, ali bo to delovalo... morda imam kakšno nastavitev napačno...
Poskusil sem z MMVARI tipkami, dela.... ampak to ni to... Delati mora z original N1MM funkcijskimi tipkami... (ESM in ostale dobrote...)... Ne vem, zakaj na večji hitrosti ne dela niti PTT? Nekako ni povezan z MMVARI engine... ??
OdgovorObjavljeno: 29 Jan 2009, 22:44
Prispevkov: 315
Kraj: JN75RX
s55z napisal/-a:
Simon, kot si omenil ima zadnja verzija tudi EPC WW DX contest... Glede MMVARI engine javim... grem testirat, ali bo to delovalo... morda imam kakšno nastavitev napačno...
nimaš napačno :-) bug je v SW!!
contest je bil dodan v ver. 8.11.3, dne 20.11.2008
zadnja ver pa se mi zdi da je z datumom 27.1.2009 in sicer 9.1.4
se odg. od :
Date: Thu, 29 Jan 2009 16:23:10 -0500
Subject: RE: N1MM + PSK125
> I sent Tom a fix this morning. I am hoping he makes another build before the
> weekend.
> 73 Rick N2AMG
73 Simon, S53K
Zadnjič spremenil S53K, dne 29 Jan 2009, 22:51, skupaj popravljeno 1 krat.
OdgovorObjavljeno: 29 Jan 2009, 22:45
Prispevkov: 315
Kraj: JN75RX
s55z napisal/-a:
aja, sporoči kako ti dela z MKII, če imaš ...
tnx
73 Simon, S53K
OdgovorObjavljeno: 29 Jan 2009, 23:13
Prispevkov: 2423
Aha... sem vmes dopisoval v post :D ...
Torej se ve za bug... upam, da bodo pravočasno poštimali... na N1MM yahoogroups tega nisem zasledil... pa tudi na MMVARI ne... Za vsak slučaj bom pripravil macroje za MMVARI funkcijske tipke...
Sicer pa uporabljam microHAM USB II interface... dela povsem ok... tudi FSK na RTTY dela BP s pomočjo EXTFSK (v MMTTY seveda)... Torej vse preko enega USB porta (in dveh virtualnih COM portov)...
