>Trenutno uporablja S5SCC/DMA kartico >strežnik CLX:S50CLX in sicer na >38400bps.
<font size=-1>[ This Message was edited by: s52jk on 2001-05-22 08:12 ]</font>
Hoj,
tudi sam poskusam prepricati S5SCC/DMA kartico in WBFM postajo na 70 cm k sodelovanju pri 38.4 kb/s, vendar imam rahle probleme. Kartico mi prepozna, zatakne se mi pa pri parametrih ob zagonu dmascc_cfg.
Prilagam svojo verzijo zagonske skripte, ki spravi postajo na oddajo, kjer ostane cca. 30 s, nato pa se vec ne odziva dokler se ne nalozi ponovno modul dmascc.o:
   /usr/sbin/axparms -assoc S56WBV-7 delete
   /sbin/ifconfig dmascc1 down
   rmmod dmascc
   modprobe dmascc io=0x380
   /usr/sbin/dmascc_cfg dmascc1 --frequency 0 --nrzi 1 --clocks 0x00 --txdelay 2
 --txpause 3 --txtimeout 30 --txtail 3 --rtsoff 0.1 --dcdon 0.1 --dcdoff 0.2 --s
lottime 5 --persist 64 --waittime 1 --dma -1
   /sbin/ifconfig dmascc1 inet 164.8.73.19 netmask 255.255.255.0 broadcast 164.8
.73.255 arp up
   /sbin/ifconfig dmascc1 hw ax25 S56WBV-7 mtu 296
   /sbin/route add default gw 164.8.73.1  dev dmascc1
   /usr/sbin/axparms -route add dmascc1 S50DXX S55YMB-3 -ipmode D
   /usr/sbin/axparms -assoc policy deny
   /usr/sbin/axparms -assoc S56WBV-7 bvla
   /usr/sbin/arp -H ax25 -i dmascc1 -s 164.8.73.1 S50DXX
   /bin/echo -n 300 > /proc/sys/net/ax25/dmascc1/t1_timeout
   /bin/echo -n 65 > /proc/sys/net/ax25/dmascc1/t2_timeout
   /bin/echo -n 3000  > /proc/sys/net/ax25/dmascc1/t3_timeout
   /bin/echo -n 0 > /proc/sys/net/ax25/dmascc1/idle_timeout
   /bin/echo -n 25 > /proc/sys/net/ax25/dmascc1/maximum_retry_count
   /bin/echo -n 0 > /proc/sys/net/ax25/dmascc1/ax25_default_mode
   /bin/echo -n 1500 > /proc/sys/net/ax25/dmascc1/maximum_packet_length
73,
           S56WBV
