Miljon minut na CPRST:S55YCP
Moderatorji: s56g, S57BBA
OdgovorNapisal/-a s53mv » 13 Avg 2006, 09:13
Ali priblizno dve leti neprekinjenega delovanja:
*** Zivijo de SuperVozelj CPRST:S55YCP ***
CPRST:S55YCP>
*** SuperVozelj V90 68020+68450 Cas delovanja: 1007219 minut 2237 zank/s ***
Kanal: 1 DCD: 13% PTT: 0% Caka: 0 Vstop: 398000 Izstop: 557630
Kanal: 2 DCD: 4% PTT: 0% Caka: 0 Vstop: 0 Izstop: 0
Kanal: 3 DCD: 9% PTT: 0% Caka: 0 Vstop: 106993 Izstop: 134491
Kanal: 4 DCD: 0% PTT: 0% Caka: 0 Vstop: 144335 Izstop: 144335
Kanal: 5 DCD: 1% PTT: 1% Caka: 0 Vstop: 144335 Izstop: 144335
Kanal: 6 DCD: 0% PTT: 0% Caka: 0 Vstop: 186 Izstop: 4
Kanal: 7 DCD: 2% PTT: 0% Caka: 0 Vstop: 1194592 Izstop: 1198579
Kanal: 8 DCD: 4% PTT: 0% Caka: 0 Vstop: 469810 Izstop: 485590
Javljanja: 202230 Odzivi: 144335 Slike(BIN): 7147 Slike(JPEG): 45
Geslo: 2 Osnovni naslov: 0003116A Klicani naslov: 00000000 Perioda: 0
CPRST:S55YCP>
#0 1:182/+18.2V 2:93/+11.3C 3:72/+3.1C CPRST:S55YCP>
*** Odzivi (minute,0.1ms) ***
3! LJU (0,156040)
1! IDRIJA-1 (0,153342)
1! KUP-1 (0,101264)
1! GOLO (0,60364)
1! CERKNO-1 (0,57986)
4! CPRST-4 (0,54105)
8! CERKNO-8 (1,12100)
8! IDRIJA-8 (1,11057)
7! KUM-7 (1,7685)
8! GOLO-8 (1,5564)
7! GORICA-7 (1,4164)
5! CPRST-5 (7,213137)
CPRST:S55YCP>
*** 9 uporabnikov CPRST:S55YCP *** 510 prostih blokov spomina ***
8:6 (S55YIG) IW3SMU-5 S55YCP 21/67963 <0!0> 8:4 (S50CLX) S55YCV IW3SMU-6 67812/21
7:7 (S55YKU) S52W-4 S55YCP 56/9289 <0!0> 8:4 (S50CLX) S55YCV S52W-5 9140/56
8:7 (S55YCV) S50CLX-1 S55YCP-6 27647/33058 <0!0> 7:7 (S50DXS) S55YKU-6 S50CLX-2 32905/27647
7:7 (S55YNG) S57A-1 S55YCP 9/28341 <0!0> 8:6 (S50CLX) S55YCV S57A-2 28192/9
7:5 (S55YKU) 9A3ZK-2 S55YCP 9/21834 <0!0> 8:7 (S50CLX) S55YCV 9A3ZK-3 21684/9
8:7 (S55YIG) S59AA-2 S55YCP 9/11116 <0!0> 8:7 (S50CLX) S55YCV S59AA-3 10966/9
Upravlja CPRST:S55YCP <0!0> 5:7 (!) CPRST-5 S55YCP-5 57/880
5:7 (!) S55YCP-5 CPRST-5 880/57 <0!0> Upravlja CPRST:S55YCP
7:7 (S55YNG) S53MV-2 CPRST 8/1132 <5!0> Upravlja CPRST:S55YCP
CPRST:S55YCP>
*** 73 de SuperVozelj CPRST:S55YCP ***
*** Zveza podrta !!! ***
Destilirana voda za akumulatorje je ze doma (tnx S57UUD), tudi novo
inacico programa mogoce damo gor. 73 de Matjaz S53MV
s53mv
Prispevkov: 34
Pridružen: 28 Maj 2001, 01:00
OdgovorNapisal/-a s52ft » 13 Avg 2006, 09:33
congrats, pa napisi nam se kaj kdaj v cqzrs prosim, pogresamo tvoje clanke.
s52ft
Prispevkov: 131
Pridružen: 31 Jan 2004, 12:37
OdgovorNapisal/-a s55m » 13 Avg 2006, 12:11
Hvala Matjaž!
Prispevkov: 1598
OdgovorNapisal/-a S56KPN » 13 Avg 2006, 12:25
Čestitke za kvalitetno delo!
S56KPN
Prispevkov: 220
Pridružen: 13 Avg 2002, 14:02
Re: Miljon minut na CPRST:S55YCP
OdgovorNapisal/-a S50U » 13 Avg 2006, 16:55
s53mv napisal/-a:Ali priblizno dve leti neprekinjenega delovanja: *** Zivijo de SuperVozelj CPRST:S55YCP *** CPRST:S55YCP>
Čestitke Matjaž in Podbrška ekipa.
CUL Danilo, S50U
https://s50clx.infrax.si
S50U
Prispevkov: 572
Pridružen: 07 Avg 2002, 23:05
Kraj: Cíerkna
OdgovorNapisal/-a s50ta » 13 Avg 2006, 20:55
Zivijo kompanija
Najprej se pridruzujem cestitkam Matjazu - S53MV, konstruktorju SuperVozelj projekta. Naj pa dodam se to, da bo drugo leto 10 let od kar deluje SuperVozelj S55YCP.
Hojhojhoj,
danses smo prvic pognali CPRST:S55YCP na hribu. Zveze grejo:
434.400 do MRZ in IDRIJA
434.200 do LJU
1298.68 se ne dela....upam, da jutri postelamo anteno do MRZ...
Prosimo dopolnite/popravite tabele...na IDRIJA in MRZ smo jih
za silo ze sami.....
73 de S56RTA, S56RTL in S53MV
Ker je bil Matjaz tokrat zelo skromen, bom na tem mestu napisal par stavkov vec, okoli dogajanja na samem zacetku postavitve vozlisca S55YCP. Skoraj celo desetletje je ze od tega, ko je Matjaz na fakulteti pristopil do mene z idejo, da bi postavili PR vozlisce na Crni prsti. Bil sem zelo vesel te ideje in moznosti sodelovanja z njim.
Toliko sem spremljal dogajanje v radioamaterskih vodah, da sem priblizno vedel kaj se dogaja, ce drugega ne sem takrat z veseljem prebiral članke Tehnike in konstruktorstva. Pa tudi hitrejsi "packet" se je obetal v Baski grapi, saj smo takrat na cluster in BBS hodili preko vozljisca S55YKK (Kuk), seveda na 1200 bps, pa se vsaj 10W je bilo treba spravit v anteno, da si prisel iz Grape.
Vecji del projekta postavitve vozlisca je seveda padel na Matjaza smo se pa vsak po svoje trudili in mu bili v pomoc. Spominjam se, kako je Matjaz predlagal, kaksen naj bo kot postavitve soncnih celic, da jih pozimi ne razbijejo ledene svece, ko se lomijo od strehe. Tako je Ljubo- S51ST pripravil kompletno konstrukcijo, v katero smo vgradili soncne celice in jih pritrdili na planinsko koco na Crni prsti. Vpadni kot sonca na soncne celice v tem primeru ni ravno idealen, so pa po devetih letih se vedno neposkodovane in dajejo zadosti energije za polnjenje akumulatorskih baterij. V spominu mi je ostalo tudi to, da smo Luku - S56RTL vedno nalozili najtezji nahrbtnik, pa je vseeno bil prvi na vrhu.
Takrat sem se prakticno prvic srecal z "mikrovalovi" in se nevede "zastrupil" ... hi. Seveda je na hrib sla tehnika, ki jo je Matjaz iz Nove gorice prinesel ze v delujocem stanju in postelano za dolocene frekvence. Na Crni prsti so potekala predvsem kovinarska, zidarska in instalacijska dela.
Tudi s Planinskim drustvom Podbrdo smo se zelo lepo domenili, da smo antenski sistem lahko pritrdili na planinsko koco in racunalnik, ter RTX-e postavili v planinsko kočo. Za ta namen so nam odobrili prostor, ki ga se vedno uporabljamo, ceprav vedno ni ravno vzorno pospravljen, ker ga vzdrzevalci planinske koce uporabljajo za odlaganje najrazlicnejsega orodja. Zaenkrat jih se vedno uspemo prepricati, da vsaj enkrat na leto na Matjazevo pobudo prostor pocistijo, da se da priti vsaj do nasih naprav.
Tudi luknjo skozi zid planinske koce so nam dovolili prevrtati, da smo pripeljali kable od anten do RTX-ov. Nikoli ne bom pozabil, kako smo si sposodili vibracijski vrtalnik in 40cm sveder, da bi prevrtali steno, ki je debelejsa od tistih 40 cm, vendar daljsega svedra pac ni bilo. Tako smo modrovali kako bi se zadeve lotili, ko pa smo določili mesto, kjer naj bi postavili uvodnico nam je po parih poskusih uspelo napraviti za naso cev preveliko luknjo v steni, ker se je odkrusil kar cel konkreten kamen. No tako smo se morali iti pa se zidarje...hi.
Seveda je bilo treba v casu postavitve vozljisca S55YCP parkrat tudi prespati v koci in naslednje jutro nadaljevati z delom. Tisti veceri, ko se je Matjaz razgovoril o satelitski tehnologiji in pojasnil marsikatero neznanko radijske tehnologije, so mi se posebej ostali v spominu.
Tudi marsikateri radioamater, ki ne zaide pogosto v tiste (nase) kraje je takrat prisel na Crno prst in ponudil roko pri postavljanju vozlisca. Tako sem imel priloznost spoznati Andreja - S51BW, pa Robija S53WW. Kasneje se je nam enkrat pridruzil se Damijan S53GA (ex. S57BDG) iz druge strani Crne prsti (Bohinja), pa tudi z Darkom - S57UUD smo se enkrat na Crni prsti ze srecal. Upam, da nobenega nisem pozabil, drugace pa se opravicujem.
Tako kot je Matjaz napisal je zgornji podatek zadosti dober pokazatelj, da je vozljisce trenutno se v zelo dobrem stanju, ceprav v zimskih razmerah kljubuje zimam, ki so precej ostre. Velja pa misliti za prihodnje, da bi bilo na vozliscu potrebno marsikaj obnoviti, oz. posodobiti. Trenutno pomagam ekipi Planinskega drustva Podbrdo, ki razmislja o prenovi koce na Crni prsti, na podrocju oskrbe z elektricno energijo. Vse kaze, da je tudi novo vodstvo planinskega drustva do radioamaterjev naklonjeno in upam, da bomo nasli formulo za skupno zadovoljstvo.
Tako kot vedno bom tudi tokrat zelo vesel, ce se uspemo z Matjazem skupaj odpraviti na Crno prst, veselim pa se tudi druzbe se katerega drugega radioamaterja, da bomo lazje nesli destilirano vodo...hi.
73 de Andrej S50TA (ex. S56RTA)
s50ta
Prispevkov: 120
Pridružen: 06 Jul 2001, 01:00
Čestitke
OdgovorNapisal/-a s53kp » 26 Avg 2006, 00:18
Pridružujem se čestitkam Matjažu in kompaniji, ki so pomagali.
Pa če še vemo, da to napajajo iz "sončne elektrarne" je uspeh toliko večji.
s53kp
Prispevkov: 226
Pridružen: 27 Apr 2003, 19:36
Kraj: Koper
OdgovorNapisal/-a s50ta » 11 Sep 2006, 20:01
Hoj
Danes zjutraj po 9 uri sva se z Matjazem - S53MV iz vasi Kal nad Basko grapo, odpravila proti 1844m visokemu vrhu Crne prsti. Ponovno sva bila primerno obtezena s 15 litri destilirane vode, ki jo je priskrbel Darko - S57UUD in jo je bilo potrebno spravit 1000m visje. Po priblizno uri in pol sva prisopihala pod vrh zadanega cilja.
http://lea.hamradio.si/~s50ta/CrnaPrst/Vrh_s55ycp.jpg
Po krajsem predihu in osvezitvi je sledil pregled stanja sestavnih delov Super Vozlja S55YCP:
Najprej kontrola naprav v skatli, kjer je zmontirana vsa elektronika,
http://lea.hamradio.si/~s50ta/CrnaPrst/Skatla.jpg
http://lea.hamradio.si/~s50ta/CrnaPrst/postaje.jpg
pa pregled akumulatorskih baterij in dotakanje vode, ki je nisva nazaj v dolino odnesla niti dcl.
http://lea.hamradio.si/~s50ta/CrnaPrst/baterije.jpg
Sledila je tudi demontaza SV racunalnika in zamenjava eproma z APRS dodatkom.
http://lea.hamradio.si/~s50ta/CrnaPrst/SuperVozelj.jpg
Seveda je Matjaz prekontroliral tudi stanje baterije v switcherju.
http://lea.hamradio.si/~s50ta/CrnaPrst/s53mv_akcija.jpg
Zatem je bilo treba vse zloziti nazaj v skatlo in ponovno prikljuciti na baterije.
http://lea.hamradio.si/~s50ta/CrnaPrst/skatla_nazaj.jpg
Ko je bilo vse zlozeno nazaj v skatlo, v baterijah sveza destilirana voda in vse skupaj malo ocisceno je bilo treba preverit ce vse se dela tako kot je treba.
http://lea.hamradio.si/~s50ta/CrnaPrst/test.jpg
Matjaz je ocistil se kamero, da se bo lepse videlo...hi.
http://lea.hamradio.si/~s50ta/CrnaPrst/antene1.jpg
Kontrola anten in kablov tudi ni izostala.
http://lea.hamradio.si/~s50ta/CrnaPrst/antene2.jpg
Za nazadnje sva se vizuelno pogledala proti soncnim celicam.
http://lea.hamradio.si/~s50ta/CrnaPrst/celice.jpg
Po priblizno 3 urni delovni akciji sva se pocasi v lepem jesenskem popoldnevu odpravila nazaj v dolino.
http://lea.hamradio.si/~s50ta/CrnaPrst/odhod.jpg
In se zadnji pogled proti planinski koci Zorka Jelincica na Crni prsti.
http://lea.hamradio.si/~s50ta/CrnaPrst/koca.jpg
73 de Andrej S50TA
s50ta
Prispevkov: 120
OdgovorNapisal/-a s57uud » 11 Sep 2006, 20:15
Lepe slike. So me kar malo vzpodbudile k misli, kako bi le šel še kdaj na Črno prst.
Tudi sam imam kar nekaj slik te točke, ki so nastale ob podobni akciji. No vzpona je kar nekaj, še posebej če neseš nekaj več opreme. Upam da moja destilirana voda na poti ni preveč spremenila lastnosti - utegnila bi namreč postati težka. :lol:
Vse čestitke za uspešno akcijo.
73 de S57UUD, Darko.
s57uud
Prispevkov: 659
Pridružen: 17 Sep 2001, 01:00
Kraj: Kačiče 15, 6215 Divača
OdgovorNapisal/-a S51AG » 11 Sep 2006, 21:30
čestitkam se pridružujem. Takšne akcije duh radioamaterstva ohranjajo pri življenju. Le tako naprej!
Tono, S51AG
S51AG
Prispevkov: 610
Pridružen: 26 Dec 2003, 14:01
Kraj: Ptuj, JN76WK
Vrni se na Packet radio
