P: SDR XCVR Brick 2
OdgovorObjavljeno: 04 Jun 2026, 11:40
Napisal/-a s51un
Prodam SDR radijsko postajo, Cena 600EUR ali po dogovoru.T: o4I8I4926, 73 de Bojan s51un
Tehnični podatki:
BRICK2 SDR HERMES 14-BIT DUC/DDC TRANSCEIVER HAM AMATEUR RADIO 1.8-60MHZ 384KHZ ANAN 10E
2 Receivers , 1 Transmitter
LNA +20 dB
RX Dynamic Range: 110 dB
Step Attenuator 0-31 dB
RF power 160-6m up to 15W, DIGI max 10W
Separate RJ11 / RJ12 Mic connector (Yaesu MH-48, MH-36)
Built-in CW-keyer
TCXO frequency stabilization (0.1 ppm)
Suitable for UP Converter (VHF, UHF, QO-100(OSCAR-100, Es’hail-2))
Display output power and SWR direct in Control Program
Housing dimensions 150x100x55mm
Band voltage for Xiegu XPA125B GPA100
Decimal (BCD) as Yaesu, Elecraft
PTT Out
