P: SDR XCVR Brick 2
P: SDR XCVR Brick 2
OdgovorNapisal/-a s51un » 04 Jun 2026, 11:40
Prodam SDR radijsko postajo, Cena 600EUR ali po dogovoru.T: o4I8I4926, 73 de Bojan s51un
Tehnični podatki:
BRICK2 SDR HERMES 14-BIT DUC/DDC TRANSCEIVER HAM AMATEUR RADIO 1.8-60MHZ 384KHZ ANAN 10E
2 Receivers , 1 Transmitter
LNA +20 dB
RX Dynamic Range: 110 dB
Step Attenuator 0-31 dB
RF power 160-6m up to 15W, DIGI max 10W
Separate RJ11 / RJ12 Mic connector (Yaesu MH-48, MH-36)
Built-in CW-keyer
TCXO frequency stabilization (0.1 ppm)
Suitable for UP Converter (VHF, UHF, QO-100(OSCAR-100, Es’hail-2))
Display output power and SWR direct in Control Program
Housing dimensions 150x100x55mm
Band voltage for Xiegu XPA125B GPA100
Decimal (BCD) as Yaesu, Elecraft
PTT Out
(161.01 KiB) Še ni prenešeno
s51un
Prispevkov: 300
Pridružen: 02 Maj 2013, 22:03
