Kenwood TK 278(N)
Kenwood TK 278(N)
OdgovorNapisal/-a s55e » 27 Sep 2009, 11:50
Pozdrav,
a je že kdo uspešno preprogramiral Kenwood TK 278(N) za HAM rabo!?
LP Jože
73, S55E
s55e
Prispevkov: 167
Pridružen: 03 Jun 2002, 09:38
Re: Kenwood TK 278(N)
OdgovorNapisal/-a s56kz » 28 Sep 2009, 09:47
Hi!
Kolikor vidim obstajajo dve verzije 150-174 MHz in 136-150 MHz.
SW pusti vpisati HAM frekvence tudi v 150-174 MHz verjetno pa je treba postajo poglasiti.
s56kz
Radioamater
Prispevkov: 272
Pridružen: 19 Maj 2001, 02:00
Kraj: Šentjur, JN76QF
OdgovorNapisal/-a s55e » 02 Okt 2009, 10:38
Pozdrav,
za tiste ki nimajo računalnika :-)
http://www.repeater-builder.com/kenwood ... k-x70.html
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds.
Press and hold (light) & (dial) while turning on radio.
Hold until (SEL) appears on the display.
Pressing (SCN) allows you to program the following
1. Monitor Key
Off = off
1 = Monitor momentary
2 = Monitor Lock
3 = Squelch off momentary
2. Scan Key
Off = off
Co = carrier operate
To = Time operate
3. Dial Key
Off = off
On = enable
4. TA key
TA = talkaround
RV = Reverse
Off
5. Lo Key
On
Off
6. Priority
None
1 = fixed
2 = selected
7. Fixed Priority Channel
Turn selector to channel
8. Look back time A
Turn selector to time in seconds
9. Look back time B
10. Revert Channel
1 = Selected
2 = Last Call
3 = Last used
4 = Selected + Talkback
5 = Priority
6 = Priority + Talkback
11. Tx Dwell time
12. Drop out delay
13. Time out timer
14. Tot Pre-alert
15. Tot Rekey time
16. Tot reset time
17. Squelch Level
Turn selector to Squelch
18. Beep tone
On
Off
19. Signalling
And
Or
20. Battery Save
On
Off
21. Selectable QT
On
Off
22. Clr to transpond
On
Off
23. Del/ Add
On
Off
Pressing (Dial) allows programming of:
DTMF
24. digit time
Turn selector to time in milliseconds
25. inter digit time
26. First digit time
27. Rise time
28. Rise time with QT
29. PTT ID
Off
1 = connect
2 = disconnect
3 = Both
30. Dial ID
On
Off
31. Connect ID
32. Disconnect ID
33. # of DTMF keys on Keypad
12
16
34. DTMF hold time
On
Off
35. Store & send
On
Off
36. D key assignment
Turn selector to D or time in seconds for pause
37. Dtmf Signaling
Off
1 = code squelch
2 = Selective Call
38. Intermediate Code
OFF
A
B
C
D
E
F
39. Group Code
OFF
A
B
C
D
E
F
40. Auto Reset time
Turn selector for time in Seconds
41. Call Alert/ Transpond
Off
1 =
2 =
3
4
5
42. Transpond
On
Off
Pressing (TA) will allow you to program Frequencies
Use selector to choose channel
Press PTT
Enter Rx frequency using:
- the Selector Knob to change kHz;
- the Selector Knob + (light) to change MHz.
If no channel is Shown press the (LO) button.
Press PTT
Enter Rx CTCSS code
Press PTT
Enter Tx Frequency as above
Press PTT
Enter Tx CTCSS code
Press PTT
1. Option Signal
Off
1 = DTMF
2 = 2-Tone
2. PTT ID
On
Off
3. Add/ Del
4. Busy Tx
5. Clock frequency shift
6. Power
Hi
Low
no kolikor sem poizkusil zadeva sicer deluje, vendar ne ravno 100% kot je zapisano.
LP Jože, 73, S55E
s55e
Prispevkov: 167
