Nasveti o postaji Yaesu FT 857
OdgovorNapisal/-a S51BR » 08 Jun 2009, 20:09
Sicer tvegam, da mi bo spet kdo zaklenil temo kot se je to zgodilo v primeru viewtopic.php?f=2&t=7917. Upam, da bom tu lahko spraševal o podrobnostih Yaesu FT 857 in če kdo namerava zakleniti, naj mi prej pove, kje sploh lahko pišem. :)
OK, k vprašanju. Kako denimo za RPT na krvavcu na 438,675 MHZ, pardon natančneje za 431,075 nastavim subton 123?
73, Rudi, S51BR
ex. S56SRB in S57SRB,
S51BR
Prispevkov: 298
Pridružen: 22 Jul 2004, 21:19
Kraj: JN75LX, Sevno
Re: Nasveti o postaji Yaesu FT 857
OdgovorNapisal/-a s55o » 08 Jun 2009, 21:25
Stran 57 manuala 4. točka in naprej... prijetno branje...
OdgovorNapisal/-a s55o » 09 Jun 2009, 00:27
If your repeater uses controlled access (using either CTCSS or DCS), press the [FUNC]
key momentarily, then rotate the SELECT knob one click clockwise to cause Multi
Function Row “e” [TON, – – –, TDCH] to appear on the display. Now select the appropriate
tone access system:
1. Press the [A](TON) key to activate the CTCSS tone encoder, which provides a
subaudible repeater access tone. One press of the [A](TON) key will activate the
CTCSS tone encoder. In this situation, you will observe the “TEN” indicator on the
display. If you press the [A](TON) key repeatedly, you will observe “TSQ” (CTCSS
Encode/Decode), “DEN” (Digital Coded Squelch, Encode), followed by “DCS” (Digital
Coded Squelch, Encode/Decode). One additional press will disable all repeateraccess
tone systems. See the next section for a discussion of DCS operation.
2. If the default repeater access tone is not appropriate for the repeater on which you are
operating, it may be set easily:
(1) Press and hold in the [A](TON) key for one second. This instantly recalls Menu
European Version
Version A
2-m
145.1 145.5
145.6 145.8
146.0 146.4 147.0 147.6 148.0
146.6 147.4
Euro Version 1
Euro Version 2
Version A
70-cm
440.0 445.0 450.0
438.20 439.45
433.00 433.40
ARS-Repeater Subbands
58 FT-857D Operating Manual
Mode No-083 [TONE FREQ].
(2) Rotate the DIAL knob to select the
desired CTCSS frequency.
(3) When done, press and hold in the
[FUNC] key for one second to save
the new setting and exit to normal
operation.
5. With repeater shift activated, you can temporarily
reverse the transmit and receive frequencies
by pressing the [B](REV) key in the Multi Function Row “d” [RPT, REV, VOX].
The “–” icon will blink while “Reverse” shift is activated. Press the [B](REV) key again
to revert to the “Normal” shift direction.
6. On many transceiver versions, the Automatic Repeater Shift (ARS) feature is enabled at
the factory. This feature automatically activates the appropriate repeater shift when you
are operating inside the designated 144 MHz or 430 MHz FM repeater sub-bands in
your country. If you wish to change the On/Off settings for the ARS, use Menu Mode No-
002 [144MHz ARS] or Menu Mode No-003 [430MHz ARS] (see page 97).
Str.57 manuala, 4 točka.
OdgovorNapisal/-a S51BR » 11 Jun 2009, 08:58
Hvala, uspelo mi je. :)
73, Rudi, S51BR
S51BR
Prispevkov: 298
Kraj: JN75LX, Sevno
OdgovorNapisal/-a s55o » 11 Jun 2009, 13:19
No vidiš, da se manual splača prebrat :) pri postajah s 3mi gumbi še posebej!
Uživaj v branju pa upam, da bova kmalu imela zvezo na radiu! Veliko DX
OdgovorNapisal/-a S51BR » 11 Jun 2009, 14:52
Saj berem, pa sem preveč površen in sem očitno ta odstavek preskočil. :) Hvala še enkrat.
Prek frekvence je pa takole: vedno sem na Krimu (2m), zdaj precej tudi na Krvavcu, minuli vikend na UKV ZRS tekmovanju, na KV pa čakam, da se bo kaj zgodilo. ;) Upam, da se res kmalu tudi slišiva. :)
73, Rudi, S51BR
S51BR
Prispevkov: 298
Kraj: JN75LX, Sevno
OdgovorNapisal/-a s55db » 19 Feb 2011, 18:42
Da si sposodim temo:
1. Kako deluje prikaz moči na postaji, če nastavim PWR mi na VHF pokaže nekaj manj kot polovico črtic pri 50W?
2. Kako preveriti če je vse v redu s postajo, ki je bila mogoče narobe priklopljena (zamenjana polariteta), upam da ni prišlo do tega, vendar bi bil rad siguren.
Hvala in 73
s55db
Prispevkov: 208
Pridružen: 10 Sep 2009, 11:07
Kraj: Podgrad/Lj
OdgovorNapisal/-a S52DK » 19 Feb 2011, 20:03
Na frekvenci najdi sogovornika in poizkusita z različnimi močmi, če se vidi kakšna razlika. Na VHF lahko poizkusiš tudi preko RPT, enako na UHF. Lahko pa povprašaš, če ima kdo v okolici PWR meter in enostavno to izmeriš. V primeru, da bi bila zamenjana polariteta napajanja postaja verjetno ne bi delovala.
OdgovorNapisal/-a S57GB » 20 Feb 2011, 10:16
s55db napisal/-a:Da si sposodim temo:
Hvala in 73
PWR-odvisno koliko indikatorjev je potrebnih za neko moč.lahko da, ker je postaja 100w pač kaže logično pol manj.malo sem že pozabil odkar sem imel FT.
73 de Boštjan S57GB
antena je važna!
S57GB
Prispevkov: 271
Pridružen: 12 Mar 2006, 12:05
Kraj: LJ-Podgorica-JN76HC
OdgovorNapisal/-a S51BR » 20 Feb 2011, 13:28
Po mojih izkušnjah je vseeno, če zamenjaš polariteto ali kar koli drugega. Tudi z oddajo brez priklopa na anteno sem "poskusil" nehote. Ugotavljam pa, da ima postaja vgrajene vse varnostne elemente, da blokira procese, če si kaj narobe priklopil. To so le moje izkušnje z mojo postajo.
73, Rudi, S51BR
S51BR
Prispevkov: 298
Kraj: JN75LX, Sevno
OdgovorNapisal/-a S51AY » 20 Feb 2011, 13:50
Če na postaji zamenjamo polariteto napajanja in če zaščita deluje, se ne bo zgodilo nič. Dobesedno nič - niti delala ne bo... :D
Če pa zaščite ni, ali ne deluje... sorry , potreben bo servis... :( :D
OdgovorNapisal/-a S54AO » 05 Mar 2011, 12:39
Pri postaji FT857D se 50W pri swr1:1,0 15 crtic /nekaj cez polovico/ 73
Gus
S54AO
Prispevkov: 8
Pridružen: 01 Avg 2008, 11:40
OdgovorNapisal/-a s55db » 05 Mar 2011, 13:49
Tole sem na googleu našel:
0 - 1.14:1
1 - 1.33:1
2 - 1.55:1
3 - 1.65:1 PWR Folds Back
4 - 1.81:1
5 - 2.1:1
6 - 2.5:1
7- 3.0:1 HI SWR "HSWR" Flashes
s55db
Prispevkov: 208
Kraj: Podgrad/Lj
OdgovorNapisal/-a s55db » 22 Mar 2013, 22:34
Nevem ce je bilo ze kje omenjeno, upam da nekomu olajsam programiranje:
http://b4d.sablun.org/blog/?p=219
s55db
Prispevkov: 208
Kraj: Podgrad/Lj
OdgovorNapisal/-a s55x » 27 Mar 2013, 22:56
s55db napisal/-a:Nevem ce je bilo ze kje omenjeno, upam da nekomu olajsam programiranje:
Resnično je tole precej preprosta zadeva. Z nekaj sreče lahko z omenjenim programom preneseš "program" iz katere druge postaje na 857d.
ex. S51JS
s55x
Prispevkov: 175
Pridružen: 20 Feb 2010, 16:30
Kraj: Mozirje (JN76li)
