FT-2000 Slovenske izkušnje?
OdgovorNapisal/-a s58dx » 04 Jan 2007, 20:52
Pozdrav vsem in HNY :) ,
je komu božiček ali dedek mraz prinesel FT-2000?
Če je prosim da napišete par stavkov kako zadeva špila!
Torej, user comments please!
Hvala vnaprej :lol: ,
Nermin S58DX 8)
Kenwood rules!
s58dx
Prispevkov: 156
Pridružen: 21 Maj 2001, 02:00
OdgovorNapisal/-a s56izw » 04 Jan 2007, 21:51
:D
73!
Zadnjič spremenil s56izw, dne 05 Jan 2007, 23:39, skupaj popravljeno 1 krat.
s56izw
Prispevkov: 394
Pridružen: 25 Maj 2004, 12:46
Kraj: velenje
OdgovorNapisal/-a S52OW » 04 Jan 2007, 23:11
Živjo.
Prej sem imel Markv-field, s postajo sem bil zelo zadovoljen.
FT-2000 ima predvsem veliko ergonomičnih prednosti in
zelo čist (tih) sprejem pri veliki občutljivosti. S selektivnostjo sem
bil zadovoljen pri obeh.
Kar nekaj prednosti sem opazil, ravno danes sem jih vrgel skupaj za
kolega iz uk. Bom kar prekopiral, če kaj ne bo jasno, lahko obrazložim.
I like the ft-2000 very much.
Ft-2000 Improvements over Markv-field:
-Menus in groups
-3 band equalizer
-no rf in external speaker
-better display ( no tracks for other functions)
-quick split
-If dsp works great
-better manual notch (fine/course)
-programmable 100khz step
-programmable bands via vfo b
-tx gnd in menu (for keying external amp)
-tx req (with let say foot switch you can tune the ext. amp with one press)
-sub af on big knob
-voice memory
-selectable roofing filters
-display indications of rx filtering status
-att on "digital knob"
-ipo as well
-agc as well
-agc programmable
-nb (better)
-The radio doesn’t worms at all
-ultra quiet fan
-cat settings
-vox settings on front panel
-ultra silent auto tuner
-No loss vrf
-tuner stays in memory (on or of) when you switch the bands also
-Very silent receiver and high sensitivity
-6m band
I don't like:
-No indications on second vfo when tx (swr etc)
-Voice memory oscillates at the end of recording
-Voice memory doesn't have the repeat function
I like the radio very much!!!
73, s52ow Tilen
Zadnjič spremenil S52OW, dne 06 Jan 2007, 16:36, skupaj popravljeno 1 krat.
S52OW
Prispevkov: 497
Pridružen: 26 Avg 2003, 18:13
Kraj: Golo 670m asl
OdgovorNapisal/-a S51U » 04 Jan 2007, 23:35
Tudi tukaj se lahko prijavite in delite kakšno izkušnjo - lastniki FT 2000 seveda, nedavno so nas namreč ločili, tako da ima vsaka od novih postaj Yaesu svoj "forum".
Carol piše takole :
The Fox Tango FT-2000 users group will be located at the following
link and will continue here:
http://groups.yahoo.com/group/Yaesu_FT-2000/
S51U
Prispevkov: 371
Pridružen: 12 Jul 2006, 13:50
Kraj: JN75GX
OdgovorNapisal/-a S52OW » 06 Feb 2007, 13:27
Zunaj je prvi firmware z naslednjimi popravki:
> 1. DVR Noise Burst
> 2. DNF update
> 3. NB update
> 4. 60 meter mode data corruption
> 5. SSB Talk Power
> 6. Speech Processor update
Sam sem imel samo napako pri oddaji Voice rekorderja, namreč na koncu
oddanega "sporočila" se je pojavljala oscilacija. Problem je zdaj rešen.
p.s. tnx s51di za info.
S52OW
Prispevkov: 497
Kraj: Golo 670m asl
OdgovorNapisal/-a S51U » 06 Feb 2007, 18:49
S52OW napisal/-a:Zunaj je prvi firmware z naslednjimi popravki:
> 1. DVR Noise Burst
> 2. DNF update
> 3. NB update
> 5. SSB Talk Power
Kako pa si uploadal firmware ?
S51U
Prispevkov: 371
Kraj: JN75GX
OdgovorNapisal/-a S52OW » 06 Feb 2007, 19:23
Odlično je opisano v navodilih.
Preko com-port "straight" kabla, ki ga tudi drugače uporabljam za krmiljenje ft-2000.
S52OW
Prispevkov: 497
Kraj: Golo 670m asl
OdgovorNapisal/-a S51AY » 13 Dec 2007, 03:28
Zadnjič spremenil S51AY, dne 19 Mar 2008, 11:29, skupaj popravljeno 1 krat.
OdgovorNapisal/-a S51AY » 20 Jan 2008, 22:07
Zadnjič spremenil S51AY, dne 19 Mar 2008, 12:04, skupaj popravljeno 1 krat.
OdgovorNapisal/-a S51U » 20 Jan 2008, 23:10
Ja, zadeva je bila pred enim letom res aktualna, v tem času pa sem dobil iz Californije 2 brezplačna originalna kabla ( v razmiku enega tedna, hi ) za upload firmware, na spletni strani se tudi stalno obnavlja zadeva, tako da sem z njihovo uslugo, ki je bila na začetku za 9000 več kot kilava, sedaj zadovoljen.
Zadeva špila :wink:
S51U
Prispevkov: 371
Kraj: JN75GX
