obremenitev kabla H155
OdgovorNapisal/-a S56VGL » 29 Maj 2006, 18:04
Zanima me koliko watow lahko spustim čez omenjeni kabel,imam ojačevalec ranger 811h na kv in 50mhz in 2m 70cm,da se mi ne bo kaj zasmodilo
Tel.preko e-mail ali ZS.
Član Radiokluba S53APR
S56VGL
Prispevkov: 459
Pridružen: 11 Jul 2003, 13:58
OdgovorNapisal/-a s55o » 29 Maj 2006, 18:19
Evo:
http://www.k1ttt.net/technote/coaxloss.html
Stric Google pozna mnogo odgovorov na podobna vprašanja.
Zadnjič spremenil s55o, dne 29 Maj 2006, 18:33, skupaj popravljeno 1 krat.
Prispevkov: 2596
OdgovorNapisal/-a s56al » 29 Maj 2006, 18:25
Pozdravljen Luka,
Še ene par linkov:
http://lea.hamradio.si/~s50c/hardware/coax.txt
http://www.wireless-lan-antenne.wimo.de ... asheet.pdf
http://www.interprojekt.pl/katalog/kable-RF/H155pe.pdf
Če boš kabel obremenjeval z RTTY, FM ali podobnimi načini dela, vzemi faktor rezerve vsaj x2.
LP, Sadni
OdgovorNapisal/-a S57vg » 29 Maj 2006, 19:14
Luka kaj si sploh prebral navodila od tega linearja?? :evil:
LINEAR AMP Ranger 811
Each band has its own tuned I/P and the O/P Pi network has a nine-position bandswitch for better tuning. To aid tuning even further there are 6:1 reduction drives on the tune and load capacitors. These capacitors are a double module exclusive to Linear Amp UK Ltd.
The valves are cooled by a 120mm, low noise Papst fan which gives excellent cooling but is so quiet you will hardly know it is running.
Front panel features include two back-lit, flush-mounted meters which show plate current and grid current. The grid current meter also doubles as a relative RF power O/P meter, selectable on the front panel. Fully adjustable ALC is also controlled from the front panel.
Output power: 800W CW or SSB, 400W RTTY
Gain: 10dB nominal
Power requirements: 230V AC at 8 Amps, 50/60 Hz
Frequency coverage: All amateur bands 1.8 - 29.7 MHz
Valves: 4 x 811A, vertically mounted
Cooling: Papst 120mm axial fan
DC voltage: 1700V DC
Protection: Primary AC fuses, soft-start
ALC: Front panel adjustable control
Dimensions: 14in wide x 9.5in high x 16in deep 355mm x 240mm x 405mm
Weight: 23kg
SKYPE callto://velko40/
S57vg
Prispevkov: 171
Pridružen: 01 Jan 2004, 14:22
Kraj: Maribor
OdgovorNapisal/-a s56a » 29 Maj 2006, 23:06
s54s napisal/-a:Pozdravljen Luka,
Še ene par linkov:
LP, Sadni
Profesore, zdaj ko si ratal Sadni, lahko sse S50C navajas kot tech reference :P
Jaz se lahko posipam s pepelom, ce je glih S53MV ukazal na napako pri vecjem stevilu mojih sivih celic.
