Na tržišču je nov radio. Na netu je že nekaj objav. Wimo ga trži po €1,145.00.
Še primerjava med FT10dx in FT-710.
S53MM napisal/-a:Spet izropana zadnja stranica.....Samo da je DVI vtičnica in ext. speaker.
s52w napisal/-a:S53MM napisal/-a:Spet izropana zadnja stranica.....Samo da je DVI vtičnica in ext. speaker.
ANT 2, RX ANT, PTT...itak nihče ne rabi![]()
73 Damjan S52W
s52o napisal/-a:Postaj ne rabi nobenih dodatnih konektorjev, saj ni namenjena za " gonit " KW.
https://www.youtube.com/watch?v=KzWB_0XOgkM
FT710 minimum operating voltage test
( power shut down voltage limit )
1) FT710 can receive even at 9.08V
That’s very nice for 12V battery operation
2) Video Receiving Test
Min is 9.1V on 7MHz SSB
3) Video Transmit (100W FM) Test
Min is 10.3V on 51MHz FM
If you use at 10.3V continuously, let’s reduce power output to 50W by FT-710 menu.
It is much better than other SDR machines like ICOM (red zone 12V, shut down around 11V). If you operate with a 12V battery like DXpedition at isolated island it is difficult to adopt IC-7300. If you use IC-7300 with 12v battery it needs 12-13.8V DCDC converter.
The FT710 can be operated even with a 12V battery. It is big advantage for field operation, mobile car operation and especially DX-pedition.
