IC-7300 nastavitev časa preko USB
OdgovorNapisal/-a s51un » 25 Feb 2021, 22:41
Pripenjam link, kako nastaviti čas na radijski postaji preko USB povezave. Avtor DD5AT.
https://amateurfunk-mint.blogspot.com/2021/01/icom-ic-7300-setzen-der-zeit-per-usb.html
REM *** Batchfile to set time from USB-Port
mode COM3 BAUD=115200 PARITY=n DATA=8 STOP=2 to=on xon=off odsr=off dtr=off rts=hs idsr=off > NUL
@echo off
set T=%time: =0%
echo FEFE94E01A050095%T:~0,2%%T:~3,2%FD > C:\Users\***\auto\example_dump_1.txt
certutil -decodehex example_dump_1.txt example_dump_1.bin
copy example_dump_1.bin \\.\com3 /b
del example_dump_1.*
s51un
Prispevkov: 302
Pridružen: 02 Maj 2013, 22:03
