X108 DELUXE
OdgovorObjavljeno: 14 Nov 2014, 18:07
Napisal/-a s55z
Xiegu Technology je dala v prodajo novo zelo všečno HF 0.5 do 30MHz 1-20W radijsko postajico X108 DELUXE z enojno konverzijo zelo primerne cene (pri nas cca 615€ z DDV). Minimalističen industrijski design zagotavlja visoko kakovost, uporabne funkcije in zelo solidne karakteristike.
Slika Slika
Slika Slika
Karakteristike
Receiver:
    - Low noise, single conversion super heterodyne type
    - Double balanced diode mixer for extended dynamic range
    - 0.2μV receive sensitivity (preamp on)
    - Narrow band double tuned bandpass filters covering all HF amateur frequencies including WARC bands
    - Six element LPF
    - IF channel AGC for constant gain
    - Switchable preamplifier & signal attenuator
    - High performance narrow band IF crystal filter with shape factor up to 1.7
    - Twin VFO for split operation
    - S-meter/RF Power/SWR via front panel display
    - Optional NB module
    - Optional front and rear handles
Transmitter:
    - RF Output power adjustable between 1 & 20 Watts
    - Dedicated MOS RF power tube for superior performance
    - High VSWR protection circuitry for output stage
    - Inbuilt CW keyer with adjustable rate
Specifications:
    - Frequency range: 0.5 – 30MHz Continuous
    - Transmitting: All HF Amateur bands including WARC bands
    - Operating mode:
    ... SSB J3E
    ... CW A1A
    ... AM A3E
    - Minimum Frequency Step: 1Hz
    - Antenna impedance: 50Ω
    - Operating temp. range: -10 - +60 ℃ ℃
    - Frequency stability: ±0.5ppm
    - Operating voltage: 12 - 14.5V DC
    - Current draw:
    ... Receive: 600mA
    ... Transmit: 7.5A Max
    - Dimensions (mm): 120 x 45 x 180 mm [not inc. front and rear handles and knobs]
Zanimiva igračka... :)
