Stand Alone Software defined Radio =SunSDR-MB1=
OdgovorNapisal/-a s51un » 08 Avg 2013, 19:32
Predstavitec nove radijske postaje na osnovi SDR.
Link do vira: http://sunsdr.com/en/forum/16-internati ... r-mb1.html
in članek v angleškem jeziku. Za prevod si pomagajte z Google translate.
On the "Maykop 2013" HAM Fest for the first time was presented new concept of HAM Stand Alone Radio based on new DUC/DDC technologies via our transceiver SunSDR2. This is a "SunSDR-MB1" HF/6M/VHF transceiver.
So.. In one box we have : Full PC(Micro-ITX PC, Intel Core i5 CPU, full blown Windows 7 (or Linux Ubuntu)), transceiver's hardware core based on SunSDR2 transceiver, 125W PA, PA LPF, ATU(option), Antenna switch, GPS receiver(option), WLAN(option), 7" display, Fully reprogrammable front panel (all buttons and all knobs), green highlight of all buttons and a main knob. Also additional HDMI connector for external a big display.
User can push one button (20 sec start time/ 5 sec finish time) and can works in radio air without Keyboard and mouse. If customer wants he can use mouse and keyboard for extended transceiver's control and for working with Logger, DIGI software etc., which installed inside the transceiver.
It is more than a simply clasical transceiver, it is more than simply monoblock (PC+SDR), this is new generation in HAM transceivers - fully DUC/DDC Software Defined Radio, fully Software Defined Front control panel!
Features:
Software: ExpertSDR2 (own software)
Direct conversion in RX/TX mode, in HF/VHF bands
Frequency range 0-80MHz, 80-160MHz
Wide band spectrum panadapter up to 80MHz
Two independent receivers
Full duplix mode (in the future - software defined).
High dynamic range of receiver: up to 119-120dB in the HF, and up to 114dB in the VHF.
Output power, nominal: 125W(HF), 30W(VHF)
IMD3 DR of transmitter: about 30-40 dB
Reference 10 MHz input
Very small CW delay: 10ms
ADC sample rate: 160MHz
ADC resolution: 16 bit
SFDR receiver: 78-82 dB
DUC sample rate: 360MHz
DUC resolution: 14 bit
High perfomance 24 bit Audio Codec on board
Connect to PC: LAN/WLAN(Ethernet/WiFi 802.11 g/n)
Power supply: 12-15V 1A(RX)/5A(TX)/ 220V 1.5-2 A.
Weight: 10 Kg
Inputs/outputs:
Two VHF antenna connector(SO239)
Two HF antenna connectors(SO239)
Wide RF input port direct connect to high speed ADC(SMA)(for XVTRX, measurement etc.) (SMA)
Wide RF output port direct connect to DUC(SMA)(for XVTRX, measurement etc.)
RX Out, uses with external BPF, ATT, P.AMP and ADC IN. (SMA)
Reference 10MHz input connector(SMA)
WiFi antenna connectors for 801.11 g/n up to 300Mb/s WAN(SMA)
ALC input port(RCA)
PTT input port(JACK 6.3mm)
CW Key input port(JACK 6.3mm)
External Control port with 9 power switch and RS-485 interface(D-SUB-15)
External Control 2 port for Automotive whip antenna 9310 from Stealth Telecom.
Electret Microphone input(line)(JACK 6.3mm)
Dynamic Microphone input with PTT switch for MH-31(RJ-45)
Headphones output(line)(JACK 6.3mm)
Ethernet connector(RJ-45)
RS-232 connector(DB9)
MIC, LIN, Phone(Jack 3.5mm) - Embedded PC's sound card, for example, for Skype via your transceiver etc.
DC input 12-15V 5A / AC input 220 V 1.5-2A.
HDMI connector for external display.
2xUSB connectors.
"Ground" connector.
Approximate price:
Basic version: 2500 EURO (without options).
Full version: 3000 EURO (with WiFi, GPS, ATU)
Software:
ExpertSDR2(all updates) - is free.
Linux OS - is free.
Windows 7 Home Basic - 100 EUR
In front panel may be changed design after 6-10 month, but already right now we have preorders on this design. Transceiver SunSDR-MB1 is available for order.
Iz lastnih izkušenj 1A XCVR. Sem uporabnik tiste škatlice na zadnji sliki, spodnji levi kot, ki je srce najavljenega transiverja.
73 de Bojan, S51UN
s51un
Prispevkov: 302
Pridružen: 02 Maj 2013, 22:03
