ICOM izdelal postajo za 70 MHz IC-7100
OdgovorNapisal/-a s52o » 25 Avg 2012, 12:35
ICOM je predstavil novo postajo za KV in 6, 4, 2 metra in 70 cm.
Novi ICOM 7100 - Touch Screen
Icom Inc. have shown a new sample of a revolutionary HF/VHF/UHF Amateur Radio Mobile Transceiver with touch screen control called the IC-7100 at the Tokyo Ham Fair 2012.
The IC-7100 is a HF+6m+VHF+UHF all mode compact radio with an innovative slanted touch-screen LCD controller. A first for an Icom transceiver, the IC-7100 is designed to the 70MHz band in European versions where 70MHz is open to Amateur radio enthusiasts. To maintain its commitment to D-STAR, all versions of the IC-7100 will come with standard D-STAR DV mode.
Since the launch of the original IC-706 in 1995, Icom has been leading the market of HF/VHF/UHF multi-band mobile radios. The popularity of vehicular mounted amateur radios may not be as high as the times of the IC-706 series, but the IC-7100 has been carefully designed to reignite Amateurs’ interest in mobile communications and brings digital communication opportunity to a wider range of radio Amateurs.
Planned Features include
• Slanted front separated controller with large touch screen dot matrix LCD (controller cannot be attached to body front)
• Speaker is self contained inside the controller
• Full mode (SSB, CW, AM, FM, RTTY decode) and D-STAR DV
• HF (100W) / 50MHz (100W) / 70MHz (50W) / 144MHz (50W) / 430MHz (35W) (Note: Power may be different according to version. The 70MHz band is available for some versions only)
• Lower current consumption / cooler operation (compared with the IC-7000)
• SWR meter function also works for VHF and UHF bands
• Remote power on / off
• IF DSP for filtering / interference removal / noise reduction
• SD memory card slot, voice recording
• USB Audio In / Out, remote control
• +/- 0.5ppm frequency stability
• 505ch memory channels
http://www.icomuk.co.uk/getFile.asp?cat ... 5&fFID=244
http://www.youtube.com/watch?v=DeeaMwnCUgo
73 de S57PZ - Zvone
s52o
Prispevkov: 409
Pridružen: 02 Sep 2004, 22:04
Kraj: Hotavlje JN76BC
Re: ICOM izdelal postajo za 70 MHz IC-7100
OdgovorNapisal/-a s52o » 25 Avg 2012, 16:49
Še 7 minutni video:
http://www.youtube.com/watch?v=98QHwsJ2zeY
Lp, Zvone - S57PZ
s52o
Prispevkov: 409
OdgovorNapisal/-a S57BIG » 26 Avg 2012, 01:59
s57pz napisal/-a:Še 7 minutni video:
Lp, Zvone - S57PZ
MAH, ta firma vztrajno in vsepovsod vsiljuje svoj digitalni način glasovnega komuniciranja : "D-STAR".
Ampak, ker sem bolj "poslušalski", kot "oddajalski" tip, sem leta nazaj zapravil kar dosti denarja za njihove
sprejemnike, tipa : "R-5, R-10 R-20 in PCR1000", sedaj pa vztrajno iščem neke programsko-strojne variante,
za sprejem in demodulacijo digitalnih načinov komuniciranja.
Ampak nikakor ne uspem najti nekih konkretnih rešitev,
ki bi bile prijazne do okolja in obenem tudi moje denarnice. :(
73 DE S5-RS-002
73 de S57BIG
S57BIG
Prispevkov: 94
Pridružen: 08 Okt 2003, 12:45
Kraj: Maribor
OdgovorNapisal/-a S58WW » 26 Avg 2012, 10:49
Spoštovani MAH!
Za tvoja zahtevna ušesa se bo tu našlo marsikaj :lol: !
http://f4dan.free.fr/sdr_eng.html
http://www.qrz.com/db/S58WW
S58WW
Prispevkov: 234
Pridružen: 06 Jun 2002, 09:57
Kraj: Dob pri Domžalah
OdgovorNapisal/-a s55db » 26 Avg 2012, 12:40
Zanimiva zadeva, zgleda pa da nima autotunerja :(
s55db
Prispevkov: 208
Pridružen: 10 Sep 2009, 11:07
Kraj: Podgrad/Lj
OdgovorNapisal/-a s52o » 26 Avg 2012, 14:24
Vsekakor zelo zanimiva zadeva saj nakazuje da bo ICOM v bodoče varjetno začel pri postajah uporabljati Touch Screen.
Postaja je zanimiva tudi zaradi 70 MHz. Po Yaesu FT-847 je to prva postaja, ki bo imela 70 MHz v svoji ponudbi
in to kar z 50 Wati, kar je več kot dovolj za ta band...
Lp, Zvone - S57PZ
s52o
Prispevkov: 409
OdgovorNapisal/-a s55db » 26 Avg 2012, 16:10
Nazalost bo cena temu primerna, ocenjujem da bodo zahtevali okrog 1300e. Zaenkrat tiha zelja da bo proracun dopuscal nabavo :D
s55db
Prispevkov: 208
Kraj: Podgrad/Lj
OdgovorNapisal/-a s52o » 27 Avg 2012, 09:47
Tako kot vse ICOM postaje bo tudi ta " draga " !
I heard will be available late in October for U$1.875.00, which I think is a little too much if this price is right.
Lp, S57PZ
s52o
Prispevkov: 409
OdgovorNapisal/-a S51AY » 29 Avg 2012, 11:53
Torej ne bo konkurence za Nokio... :P
Saj je že čas, da serijsko vgrajujejo, 70MHz. Samo tako naprej !
