Vero VR-DB2R
Vero VR-DB2R
OdgovorNapisal/-a s55db » 05 Nov 2011, 02:20
http://www.vgc.hk/Dual-Band-Two-Way-Radio-VR-DB2R.htm
Se en izmed kitajcev, tokrat IPX7...
Frequency range:
136-174 & 300-350 MHz (TX/RX)
136-174 & 350-390 MHz (TX/RX)
136-174 & 400-470 MHz (TX/RX)
136-174 & 450-520 MHz (TX/RX)
136-174 & 245-246 MHz (TX/RX)
144-146 & 430-440 MHz (TX/RX)
High/Low Power Switchable
25KHz/12.5KHz Switchable
Auto Contact Function - This function is useful for environments which need close communications, such as climbing, exploration and rescuing. The radio will beep when the users are out of communication range and this function is ON
Auto Output Power When in Duplex Status - When the VR-DB2R is in duplex status, it can automatically adjust the output power based on the distance between two radios.
Channel step - 5K/6.25K/10K/12.5K/25K
PC Programming
Dual Display, Dual Standby
Whisper Function - This function can be enabled in quiet environments, allowing you to speak quietly into the radio and still be heard clearly.
CTCSS / DCS
FM radio :88-108 MHz
Transmission Time Out
s55db
Prispevkov: 208
Pridružen: 10 Sep 2009, 11:07
Kraj: Podgrad/Lj
Re: Vero VR-DB2R
OdgovorNapisal/-a S57GB » 05 Nov 2011, 11:53
jah tko, dokler tile kitajčki delujejo, so zelo cenovno dostopni, po kvaliteti modulacije in ostalih karakteristik se lahko postavijo ob bok bolj znanim znamkam, se bodo prodajali še pa še.
73 de Boštjan S57GB
antena je važna!
S57GB
Prispevkov: 271
Pridružen: 12 Mar 2006, 12:05
Kraj: LJ-Podgorica-JN76HC
Re: Vero VR-DB2R
OdgovorNapisal/-a s55db » 05 Nov 2011, 12:31
Posebnost tega je, da je prvi kitajski radio po IPX7 standardu.
Naj kar proizvajajo, morda zbudijo veliki trio in jim pride do glave to da vrednost TH-D72 ni enaka iPhoneu, oziroma je, ker sta oba produkta precenjena :D
Sem zadovoljen tako z TH-D72, kot Wouxunom in Baofengom...
s55db
Prispevkov: 208
Kraj: Podgrad/Lj
Re: Vero VR-DB2R
OdgovorNapisal/-a s56rlu » 05 Nov 2011, 19:56
zanimivo je, da imajo tudi mobilne postaje...bi blo lepo imet kakšno ceno :>
s56rlu
Prispevkov: 70
Pridružen: 07 Sep 2009, 10:30
