Stran 1 od 2
FT1000MP
OdgovorObjavljeno: 23 Avg 2011, 18:42
Napisal/-a s53v
Kot bazno postajo za 2m in 0,7m sem kupil rabljeno FT1000MP,ki pa ima dve napaki. Prva napaka je da,ko premikam RIT malo hitreje se mi običajno zapelje v negativno smer, neglede če obračam v drugo smer. Če vrtim RIT zelo zelo počasi,gre v + in - od frekvence in je OK. Kakor sem gledal na web-u je baje vrzrok v enkoderju. Ima kdo kakšen nasvet,kako to rešiti ??
Drugo težavo imam z gumbom na baznem sprejemniku. Ima namreč "luft" in malo skače(gor,dol) ,ko ga vrtim. Se da mogoče mehanizem vrtenja gumba kako justirat.??
V naprej hvala za nasvet
S53V
Re: FT1000MP
OdgovorObjavljeno: 23 Avg 2011, 20:56
Napisal/-a s55m
1. vprašanje
To se dogaja skoraj vsem "tisočkam" (S57Q,S57C,S55M....).
I found a solution the the "FT-1000MP RX-Clarifier Check" posting of 19-07-1998.
The problem is the rotary encoder of the Clarifier function. To smoothen rotation, the manufacturer of this type of encoder,
puts some grease into the shaft of the encoder. Due to extensive usage, this lubricant comes into the encoder itself, where
it flows between the fixed contact pads and the rotary contacts (you can compare it to the wiper contact of a potmeter). As
the lubricant is not electrically conducting, some contact points (representing digital values) are not detected by the digital
control.
Solution is simple:
1. open TRX (both covers)
2. remove all knobs and dials from frontpanel (only those needed - it'll point itself out)
3. tilt front panel towards you and locate little PCB (printed circuit board) holding the Clarifier encoder
4. loosen connectors + screws and pull out the little board as a whole
5. on the encoder (shaft facing upwards) you see 4 clips; bend them 90° upwards and CAREFULLY pull away the upper
part
6. now you see a black disk with metallic contact pads, and in your other hand, you see three brittle springs, all covered
with grease.
7. clean both parts thoroughly using Q-tips with alcohol (or something similar not agressive to plastic), but BE
CAREFULL not to bend the springs.
8. now assemble everyting back together by following above steps in reverse order, but take care of the springs when
closing the encoder!
Should work 100% ok! Good luck!
ON5ZO
2. vprašanje
Razdri in poglej, saj za to težavo nisem še slišal. Morda preberi v manualu tam, kjer piše kako se nastavlja trdota obračanja VFO-ja. Morda je samo odvijačeno....
Re: FT1000MP
OdgovorObjavljeno: 23 Avg 2011, 22:03
Napisal/-a s53v
Hvala Adi. Sem med tem že tudi sam našel na WEB-u to rešitev za RIT. Kar se tiče pa pogona za VFO pa samo z nastavitvijo trdote ne bo šlo. Bojim se, da je pogon malo poškodovan saj "SKAČE" gor in dol in bi ga moral verjetno razdreti. Nimam pa manuala,zato tudi ne vem,kako se razstavi.
lp S53V
Re: FT1000MP
OdgovorObjavljeno: 23 Avg 2011, 22:35
Napisal/-a s55oo
Tukaj se nahaja tudi service manual:
http://www.wz5q.net/index/manuals.htm
Cisto spodaj preveri.
Re: FT1000MP
OdgovorObjavljeno: 24 Avg 2011, 07:24
Napisal/-a s55m
Re: FT1000MP
OdgovorObjavljeno: 26 Avg 2011, 17:44
Napisal/-a s53v
Hoj !
Problem s RIT-om sem rešil brez razdiranja po nasvetu Bojana S57M tako, da sem na vsako stran na tiskanini enkoderja zalotal kondenzator 10nF proti masi in je BP. -Hvala Bojan
Za VFO pa imam hujši problem,ker sploh ne morem sneti gumba z osi in razdreti čelno ploščo. Nekdo,ki je pred mano snemal gumb(medenina) ga je naribal na (jekleno) os in gumb ne gre nikamor,čeprav je imbus vijak popolnoma odvit. Verjetno bom moral na silo odlomiti os in zamenjati dajalnik.Ima kdo kakšno idejo kako to najbolj elegantno rešim??
73 S53V
Re: FT1000MP
OdgovorObjavljeno: 27 Avg 2011, 18:30
Napisal/-a s57ad
s53v napisal/-a:Hoj !
73 S53V
Z dobro voljo, božjo pomočjo in pol kile dinamita :lol:
Re: FT1000MP
OdgovorObjavljeno: 27 Avg 2011, 20:41
Napisal/-a s53v
s57ad napisal/-a:
Hojla Mirko !
Zato grem pa jutri na izlet na sv. Višarje - Hi !
lp J s53v
Re: FT1000MP
OdgovorObjavljeno: 27 Avg 2011, 23:07
Napisal/-a s57ad
s53v napisal/-a:
s57ad napisal/-a:
Hojla Mirko !
lp J s53v
:lol: Seveda sem se le šalil, OC. Lep izlet ti želim, 73 de Mirko, S57AD
Re: FT1000MP
OdgovorObjavljeno: 15 Okt 2011, 15:30
Napisal/-a s53v
Hojla !
Potem,ko sem se prepričal z vgradnjo roofing filtra NS v FT2K da je stvar koristna sem se odločil, da ga vgradim še v FT1K. Testi INRAD filtra ki so jih naredili pri ARRL-u ter Peter Hard v Radcommu so bili vspodbudni me je pa Boštjan S55O presenetil z nformacijo, da so nekateri hami na Primorskem ugotovili, da filter celo poslabša IP3 in so jih zmetali ven. !! Opozoril me je tudi na članek w8ji
http://w8ji.com/receiver_tests.htm
Ker mi logično ni šlo skupaj, da filter poslabša IP3 sem še malo brskal po internetu in ugotovil,da je to res in da je vzrok temu za cca 3,5dB preveliko ojačenje INRADOVEGA medfrekvenčnega ojačevalnika na 68MHz,kar za cca 10 dB poslabša IP3. Mike W2AJI tudi predlaga,kako to popravimo
http://www.va3cr.net/mods/RoofingFilterModMarkV.htm
V originalnem INRAD-ovem ojačevalniku je potrebno zamenjati samo dva upora in filter bo deloval kakor je izmeril ARRL. V FT1K meniju 9-1 je potem ev. potrebno še nastaviti ojačenje v medfrekvenci najlažje tako, da pri istem signalu s primerjavo S-metra v drugem sprejemniku umerimo ojačenje celotnega sprejemnika.
Enako sem zmanjšal ojačanje tudi INRAD-ovem roofing filtru pri FT 920. Prilagam INRAD-ovo shemo s spremenbami.
Lp /73 S53V
Re: FT1000MP
OdgovorObjavljeno: 13 Jan 2013, 14:36
Napisal/-a s53v
Hojla !
Projekt modifikacij na MP1000MP, ki ga je naredil I7SWX . Podobne modifikacije je naredil tudi na K3 in FT2000.
http://www.pensioneitaliacapri.com/ham/ ... 0I7SWX.pdf
Re: FT1000MP
OdgovorObjavljeno: 04 Jun 2014, 13:35
Napisal/-a s53v
Hojla!
Na FT1K mi je izgleda škripnil avdio izhod za slušalke in zvočnik. Sheme,ki so na WEB-u so obupno slabe in iz njih nikakor ne morem
pogledati načrta ter signalov niti si ogledati tiskanine. Imam pa signal na avdio izhodu,ki je namenjen za dodatno ojačenje in ne gre preko potenciometra za glasnost. Na avdio končno stopnjo za drajvanje zvočnika TDA2003 pin 1. signal še pride na izhodu ojačevalnika pa ga ni več. Čudno mi pa je, da ne delajo slušalke,ker je ojačevanik TDA2003 namenjen samo za poganjajnje zvočnika.
Razdrl bi Audio board vendar dokler nimam sheme, nisem prepričan,da je vzrok samo na TDA2003. Tudi nisem siguren ali se bele "flet" kable samo
potegne iz konektorja ali imajo kakšno dodatno pritrditev.
Re: FT1000MP
OdgovorObjavljeno: 04 Jun 2014, 17:45
Napisal/-a s53v
Hojla !
Našel sem shemo in ugotovil,da je verjetno nekaj narobe z regulatorji Q3021 ali Q3018 ( 2SC3444-T11),ki napajata obe veji. Ne najdem pa tega
na AF bordu pa tudi kopije montažnih shem,ki jih imam so nečitljive. Mi lahko tudi kdo svetuje,kako se odklopijo trdi flat(beli) kabli.Ali se samo potegnejo ven ali imajo ti kabli kakšno dodatno pritrditev na konektor?? Bojim se namreč, da jih ne potrgam. Yaesu ni prav "User friendly" za servisiranje :( .
Re: FT1000MP
OdgovorObjavljeno: 04 Jun 2014, 20:48
Napisal/-a 9A2V
Zdravo!
Beli flat kabli se samo potegnejo ven..
Lp Velimir.9A2VJ
Re: FT1000MP
OdgovorObjavljeno: 04 Jun 2014, 21:12
Napisal/-a s53v
9A2VJ napisal/-a:Zdravo!
Lp Velimir.9A2VJ
Velimir hvala za info.
