Power SDR modifikacija programa za TX
OdgovorNapisal/-a S54Z » 03 Jun 2011, 13:06
How to open PowerSDR TX in all frequency range (1 - 60MHz).
First Method:
Inside PowerSDR.mdb file add (via Microsoft Access) in table "State" record: ID "extended", SaveValue "True".
Make file (in Texter or notepad) "extended.ed" , with text "True" inside.
You can transmit in all fr.range!
Second method:
In PowerSDR.mdb file see table "BandText".
Format:
Low - low frequency value
High - high frequency value
Name - Frequency range text description
Transmit - text "True", or "False". TX On(True)/TX Off(False).
All frequency values in MHz.
Frequency bands must not coverage between other bands. All frequencies out of band will be - "Out of Band".
Example:
Low: 7,040001
High: 7,099999
Transmit: True
Low: 7,3
High: 7,35
Name: 41M Short Wave
Transmit: False
Change "False" --> "True" and you can transmit in this band.
If you want have TX in all thinkable and not thinkable frequencies, you could delete all recording in the table "BandText" except first.
Then edit like this:
Low: 0,7
High: 40000
Transmit: True
Congratulations, you have TX in all frequencies (1 - 60 MHz).
S54Z
Prispevkov: 131
Pridružen: 01 Sep 2004, 22:03
