Vprašanje za poznavalce
OdgovorObjavljeno: 02 Jun 2019, 11:49
Napisal/-a s57bat
Hej hoj!
Preko kombinacije sharpsdr in dsd+ spremljam DMR promet čez repetitorje. Zadeva omogoča tudi vizualno kontrolo prometa. Krvavec dela OK (Motorola, Madžarski server), preko vseh ostalih repetitorjev pa se pojavlja nek kriptiran promet. Prilagam delček loga:
2019/06/01 12:33:48 Group call; TG=293 RID=2930347 [S56WBI] Slot=1 10s
2019/06/01 12:33:48 Private call; Tgt=2110009 Src=3354675 Slot=1
2019/06/01 12:33:49 Private call; Tgt=3604480 Slot=1 1s
2019/06/01 12:33:51 Private call; Tgt=4476242 Src=2115908 Slot=1 1s
2019/06/01 12:33:52 Private call; Tgt=3604480 Slot=1
2019/06/01 12:33:53 Enc Bcast OVCM Group call; TG=5453110 RID=5718601 Slot=1
2019/06/01 12:33:54 Private call; Tgt=4476242 Src=2115908 Slot=1
2019/06/01 12:33:54 Private call; Tgt=2110009 Src=3354675 Slot=1
2019/06/01 12:33:55 Private call; Tgt=3604480 Slot=1
2019/06/01 12:33:56 Enc Bcast OVCM Group call; TG=5453110 RID=5718601 Slot=1
2019/06/01 12:33:56 Private call; Tgt=4476242 Src=2115908 Slot=1
2019/06/01 12:33:57 Private call; Tgt=2110009 Src=3354675 Slot=1
2019/06/01 12:33:58 Private call; Tgt=3604480 Slot=1
2019/06/01 12:33:59 Enc Bcast OVCM Group call; TG=5453110 RID=5718601 Slot=1
2019/06/01 12:33:59 Private call; Tgt=4476242 Src=2115908 Slot=1
2019/06/01 12:48:30 Group call; TG=293 RID=2930392 Slot=1
2019/06/01 12:51:29 Group call; TG=293 RID=2930347 [S56WBI] Slot=1 8s
2019/06/01 12:51:30 Enc Bcast OVCM Group call; TG=5453110 RID=5718601 Slot=1
2019/06/01 12:51:30 Private call; Tgt=4476242 Src=2115908 Slot=1
2019/06/01 12:51:31 Private call; Tgt=2110009 Src=3354675 Slot=1
2019/06/01 12:51:32 Private call; Tgt=3604480 Slot=1
2019/06/01 12:51:33 Enc Bcast OVCM Group call; TG=5453110 RID=5718601 Slot=1
2019/06/01 12:51:33 Private call; Tgt=4476242 Src=2115908 Slot=1
2019/06/01 12:51:34 Private call; Tgt=2110009 Src=3354675 Slot=1
2019/06/01 12:51:35 Private call; Tgt=3604480 Slot=1
2019/06/01 12:51:35 Enc Bcast OVCM Group call; TG=5453110 RID=5718601 Slot=1
2019/06/01 12:51:36 Private call; Tgt=4476242 Src=2115908 Slot=1
2019/06/01 12:55:32 Group call; TG=293 RID=2930266 [S51PV] Slot=1
2019/06/01 12:55:49 Group call; TG=293 RID=2930247 Slot=1
2019/06/01 13:10:54 Group call; TG=293 RID=2930191 [S56KGJ] Slot=1
2019/06/01 13:30:41 Group call; TG=293 RID=2930274 [S56LLR] Slot=1
2019/06/01 13:31:18 Group call; TG=293 RID=2930096 [S57OM] Slot=1 3s
2019/06/01 13:31:19 Enc OVCM Group call; TG=5453111 RID=5197088 Slot=1 1s
2019/06/01 13:31:20 Enc Bcast OVCM Private call; Tgt=4998471 Slot=1s Pri3
2019/06/01 14:16:45 Group call; TG=293 RID=2930203 [S57F] Slot=1
2019/06/01 14:17:01 Group call; TG=293 RID=2930203 [S57F] Slot=1
2019/06/01 14:17:11 Group call; TG=293 RID=2930203 [S57F] Slot=1 2s
2019/06/01 14:17:14 Enc OVCM Group call; TG=5453111 RID=4595780 Slot=1 Pri2
2019/06/01 14:17:15 Enc OVCM Private call; Tgt=6971758 Src=2097152 Slot=1s Pri1
2019/06/01 14:17:15 Group call; TG=293 RID=2930203 [S57F] Slot=1
2019/06/01 14:21:45 Group call; TG=293 RID=2930257 [S57CMN] Slot=1
2019/06/01 14:21:53 Group call; TG=293 RID=2930257 [S57CMN] Slot=1
Promet čez Krvavec vsebuje samo 293 call-e
Po moje to precej obremenjuje promet, lahko pa se tudi motim...
Prosim samo za konkretne odgovore, brez forumskih znalcev. Npr. S52ID je spraševal kaj je ch ranging in dobil odgovor, da je to rangiranje kanalov. V bistvu pa je to aktiviranje lokacije sogovornika.
73 Tomaž
Re: Vprašanje za poznavalce
OdgovorObjavljeno: 06 Jun 2019, 08:38
Napisal/-a s57bat
V bistvu žalostno.
Kljub akciji hotspot v vsako slovensko vas in repetitor na vsak kucelj, nihče od skrbnikov ne ve kaj spušča v eter.
73 Tomaž
OdgovorObjavljeno: 06 Jun 2019, 19:49
Napisal/-a s51da
Hoj,
To tudi mene zanima.
Glede na to, da se to dogaja le kadar pride promet preko Brandmeister omrežja, bi mogoče kdo ki se spozna na delovanje strežnika, povedal kaj o tem kaj pošilja na repetitorje...
73 de s51da
OdgovorObjavljeno: 06 Jun 2019, 20:23
Napisal/-a S57NK
V dnevnikih repetitorja S55DKP Nanos (MMDVM) ne zasledim nobenih posebnosti. Možno je, da program dsd+ ne dekodira uspešno vseh podatkovnih delov prenosa ter izgubi sinhronizacijo s podatki, kar na koncu zgleda kot kriptirana 'šara'.
Največja težava je uspešno dekodiranje FEC (Forward Error Correction). V DMR je namreč uporabljeno precej algoritmov FEC, za povrh nekatere postaje podatke kodirajo napačno (predvsem GPS položaj). Avtor MMDVM je imel s tem kar nekaj težav in predvidevamo lahko, da jih ima tudi avtor programa, ki ga uporabljaš.
73 de Janko, S57NK
OdgovorObjavljeno: 06 Jun 2019, 20:37
Napisal/-a s51da
Te čudne ID-je se vidi tudi če uporabljaš Retevis postajo z MD380 Tools firmwarom v Net monitor načinu.
Je pa res, da sem vse to opazil le na Hyterinem repetitorju. Na Motoroli s Krvavca tega ni, niti na MMDVM hotspotih - stestirano vsaj na treh.
Janko, prekinjanje v sprejemu na Retevisih je tudi samo če je repetitor Hytera, na MMDVM in Motoroli s Krvavca pa tega ne opazim. Mogoče pa je oboje povezano!?!
73 de s51da
OdgovorObjavljeno: 06 Jun 2019, 21:02
Napisal/-a S57NK
Hmm, na mojem Retevis RT3 z MD380 tools v promiskuitetnemu načinu na Trstelju (tudi Hytera) ne opazim nič nenavadnega. Promiscious=net monitor ali ga moram posebej vklopiti?
Kaj mi lahko posreduješ javni IP, na katerega gre promet na Koblo? Bom poskušal z Wiresharkom posneti vaš promet na master strežniku, da vidimo, če pride to čudo po omrežju ali po radiju.
OdgovorObjavljeno: 06 Jun 2019, 21:17
Napisal/-a S57NK
Katere relacije so v teku, tako privat kot na pogovorne skupine, lahko sledite tudi sami. Seznanite se s protokolom MQTT, si namestite MQTT odjemalca ter spremljate dogodke na našem master strežniku na naslovu master.brandmeister.si . Teme (topics), na katerih dogodke se lahko naročimo, se opisane na https://wiki.brandmeister.network/index.php/MQTT_API. Master/2931/Session/# - Call Control events bo ravno pravšnja tema za naš primer.
O dogodkovnih vodilih, strežnikih, protokolu MQTT itd je najboljši priročnik tale: https://www.hivemq.com/blog/mqtt-essentials-part-1-introducing-mqtt/
OdgovorObjavljeno: 06 Jun 2019, 21:29
Napisal/-a s51da
Netmon najlažje vklopiš tako, da na osnovnem ekranu pritisneš rdečo tipko zgoraj desno, potem pa s puščico dol najdeš Netmon in z zeleno potrdiš. Potem s tipkami od 1 do 6 in 0 izbereš kaj naj prikazuje. Obstaja tudi vklop skozi menije, kjer potem samo pritisneš tipko 8 ali 9 in ti takoj deluje Netmon. Lahko pa vklopiš USB logging in ti bo v Linux konzoli lepo izpisovalo vse kar se s postajo dogaja in kaj počne.
To čudo pride 100% po omrežju, ali pa repetitor nečesa ne razume in sam doda. Kadar je zveza v lokalu, brez omrežja tega ni. Novejše verzije DSD+ zadevo opisujejo kot Tier III podatke. Tu verjetno gre za napako v dekodiranju ali pa tudi ne. Toliko se ne spoznam.
73 de s51da
OdgovorObjavljeno: 06 Jun 2019, 21:33
Napisal/-a s57bat
No, pa se je premaknilo. Hvala David. HI
Ravno sem preverjal promet paralelno na dveh SDR sistemih. Prvi je bil na Ermanovcu(hytera), drugi pa na V. planini(MMDVM) in so bili ID-ji private call-ov identični, tako da ne verjamem v napako dekodiranja DSD+. Bom posnifal še kakšen hotspot. Te nesnage ni na Krvavcu.
73 Tomaž
OdgovorObjavljeno: 23 Jun 2019, 18:16
Napisal/-a s57bat
Da malo obudim temo.
Preko Krvavca res med zvezami ni packarije, vendar pa včasih ure in ure oddaja tole:
OdgovorObjavljeno: 24 Jun 2019, 15:57
Napisal/-a S57NK
Malo natančnejše izražanje prosim. Že iz spektrograma je razvidno, da to ni 'ure in ure' ampak občasno, verjetno na nekaj 10 sekund. Verjetno gre za periodično oddajanje signal 'svetilnika' (beacon), ki pomaga DMR postajam pri preklapljanju (roaming) med različnimi repetitorji. Postaje poslušajo te signale in se na osnovi njihove moči odločajo, kdaj preklopiti na ustreznejši repetitor.
OdgovorObjavljeno: 24 Jun 2019, 19:49
Napisal/-a s57bat
Hej hoj!
Na spektrogramu se vidi par sekundna prekinitev, signal pa traja kakšno minuto in to "ure in ure". Predvsem pa sta mi zanimiva tgt in src na koncu povorke raw data.
73 Tomaž
OdgovorObjavljeno: 25 Jun 2019, 11:26
Napisal/-a s53al
Sem začetnik na DMR. Postaja je RT3S.
Zanima pa me, zakaj repetitor na Trdinovem vrhu (D) oddaja signal na vsake cca 20. sec. Zaznavno je le preko diodice, ko začne utripat.
Na analognem se pa sliši tisto "brenčanje"?.
Ali repetitor preverja, če je postaja v dometu???
L.p
OdgovorObjavljeno: 27 Jun 2019, 18:56
Napisal/-a s56wdn
Aleš pozdravljen
Vsi repetitorji oddajajo beacon signal za potrebe roaminga pri postajah ki to omogačajo. Na FM si pa nastavi sub ton 123Hz
