WCA vikend 14.-15.06.2014 - WCW 2014
OdgovorObjavljeno: 07 Jun 2014, 23:08
Napisal/-a s50v
Naslednji vikend 14.-15.06.2014 bo že peti zaporedni vikend gradov.
V temu času imate veliko možnosti narediti zveze s postajami, ki oddajo z gradov po svetu.
Tudi S5 gradovi bodo med njimi.
Se slišimo!
Re: WCA vikend 14.-15.06.2014 - WCW 2014
OdgovorObjavljeno: 12 Jun 2014, 08:08
Napisal/-a s50v
Najave aktivacij:
15/06/2014 - WCA & COTA-DL pedition of DF0WCA to Friedrichswerth Castle!
-Gerhard DL5AWI will be active on the 15th of June 2014 and particiate in WCW-2014 from Friedrichswerth Castle, WCA: DL-04402. COTA-DL: THB-244. He plans to work as DF0WCA on allbands. QSL via bureau. 73 & 11! [tnx info DL5AWI].
14/06/2014 - WCA & COTA-RU activity R7RIB from Museum Mikhaylovskaya battery and Northern fortification!
- Mikhail R7RIB will be active on the 14th and 15th of June 2014 and participate in WCW-2014 from Museum Mikhaylovskaya battery, WCA: UA-00618 , COTA-RU: C-7111 and Northern fortification, WCA: UA-00620, COTA-RU: C-7113. He plans to work on all bands Digital modes and SSB. QSL via bureau. 73 & 11! [tnx info R7RIB].
14/06/2014 - WCA & COTA-RU pedition RX1CQ/P to Karelsky Fortified!
- Dmitry RX1CQ, will be active on the 14th and 15th of June 2014 and participate in WCW-2014 from Karelsky fortified, WCA: UA-00256, COTA-RU: U-102, RDA: LO-23. He plans to work as Home Call/P, on all bands! QSL via HC, bureau or direct. 73 & 11! [tnx info RX1CQ].
14/06/2014 - WCA & BCA & BFORTA pedition of ON3NMR/P to Fort Maizeret!
- The members of Radio Club Belgradois, ON3NMR will be active on the 14th of June 2014 and participate in WCW-2014 from Fort Maizeret, WCA: ON-00490, BCA: NM -058, BFORTA: BFA-008 located in Province of Namur. They Plan to work as ON3NMR/P on 40 meters SSB (+ / - 7.085 MHz) and 15 meters CW. QSL via EURAO: FRA, P.O.Box: 1630, B-1000 Brussels 1, Belgium . 73 & 11! [tnx info ON3NR].
14/06/2014 - WCA & COTA-DL pedition of DL0BQ/P to Schloss Auerbach!
- The members of Radio club DARC OV Bergstrasse F02 will be active on the 14th of June 2014 and participate in WCW-2014 from Schloss Auerbach, WCA: DL-00076, COTA-DL: HBN-001. They plan to work as DL0BQ/P (special DOK: HT14 for the Hessentag in Bensheim) on all bands. QSL via DARC bureau. 73 & 11! [tnx info DL4FDM (HB9CSA)].
14/06/2014 - WCA & COTA-DL pedition of DL0HG/P to Roemercastell Saalburg!
- The members of Radio club OV F11 will be active on the 14th of June 2014 and participate in WCW-2014 from Roemercastell Saalburg, WCA: DL-02836, COTA-DL: HBN-123. They plan to work on 40 meters as DL0HG/P. All contacts are also valid for the Limes Award http://www.fox11.de/the-limes-award.html. QSL via DARC bureau. 73 & 11! [tnx info DL9WO].
14/06/2014 - WCA & COTA&DL pedition of DL1JKK/P to Castle Mylau!
- Karl DL1JKK will be active on the 14th and 15th of June 2014 and participate in WCW-2014 from Castle Mylau, WCA: DL-01267, COTA-DL: SAX-161. He plans to work as DL1JKK/P fom 07:00 UTC on all bands. QSL via Home Call, bureau or diect. 73 & 11! [tnx info DL1JKK].
14/06/2014 - WCA & S5-WCA pedition of S51RU/P to Vitanje Castles!
- Marjan S51RU will be active on the 14th of June 2014 and participate in WCW-2014 from:
- Dvorec Vitanje, WCA/S5-WCA: S5-00296;
- Novi Grad Vitanje (Weitenstein), WCA/S5-WCA: S5-00297;
- Stari Grad Vitanje (Weitenstein), WCA/S5-WCA: S5-00298.
He plans to work as S51RU/P from 05:00 UTC on 40, 30, 20 and 2M meters CW/SSB/FM. Log will be uploaded into the WCA database. QSL via bureau. 73 & 11! [tnx info S51RU].
14/06/2014 - WCA & COTA-RU pedition of RZ1CWC/P to Fort Seraya Loshad!
- The members of Radio club RZ1CWC will be active on the 14th and 15th of June 2014 from Fort Seraya Loshad, WCA: UA-00210, COTA-RU: F-116, RDA: LO-30. He plans to work as RZ1CWC/P on all bands CW/SSB. QSL via RW6HS. 73 & 11! [tnx info RZ1CWC].
14/06/2014 - WCA & COTA-YL pedition of YL73EPC/P to Rezekne Castle!
- Arnis YL3GBC will be active on the 14th of June 2014 and participate in WCW-2014 from Rezekne Castle (Rositen), WCA: YL-00064, COTA-YL: L-005 located in Latgale. He plans to work only Digital modes as special callsign YL73EPC/P. QSL via YL3GBC. 73 & 11! [tnx info YL3GBC].
14/06/2014 - WCA & COTA-RU pedition of UE70VBG to Vyborg Castle!
- Alexey UA1CDA will be active on the 14th of June 2014 and participate in WCW-2014 from Vyborg Castle, WCA: UA-00004, COTA-RU: C-104, RDA: LO-24, ARLHS: ERU-231, RLHA: RLE-124. He plans to work as special callsign UE70VBG on all bands. QSL via bureau. 73 & 11! [tnx info UA1CDA].
14/06/2014 - WCA & UCFA pediton of UT0NN/P , UR5NLG/P and UR5NJJ/P to Historical and Cultural Reserve Busha!
- Vasily UT0NN, Igor UR5NLG and Alexey UR5NJJ will be active on the 14th and 15th of June 2014 and participate in WCW-2014 from Historical and Cultural Reserve Busha, WCA: UR-00147, UCFA: VI-002, UFFA: UUFF-013, URDA: VI-35, WW Loc. KN48bi. They plan to work on 80, 40 and 20 meters CW/SSB/RTTY as Home Call/P. QSL via UT0NN. 73 & 11! [tnx info UT0NN].
14/06/2014 - WCA & ZWP pedition of SP9YFF/P to Zamek Rudno z. Tenczyn!
- The members of Silesian Radioamateur Group will be active on the 14th and 15th of June 2014 and paticipate in WCW-2014 from Zamek Rudno z. Tenczyn, WCA: SP-00786, ZWP: MKR08, PGA: KR06. They plan to work as SP9YFF/P on all bands. For detail information please visit at:www.sp9yff.pl. Log will be uploaded into the WCA database, ZWP and LoTW. 73 & 11! [tnx info SP9URK].
14/06/2014 - WCA & COTA-YL activity of YL1WT from Fortification of Liepaja!
- Alexey YL2QS and others operators will be active on the 14th and 15th of June 2014 and participate in WCW-2014 from Fortification of Liepaja, WCA: YL-00106, COTA-YL: K-027. They plan to work on 20 meters CW/SSb as YL1WT. QSL via bueau. 73 & 11! [tnx info YL2QS].
14/06/2014 - WCA & UCFA pedition of EM7UT to Vitich Fortress!
- The members of Radio club "DELTA" will be active on the 14th and 15th of June 2014 and participate in WCW-2014 from Vitich Fortress, WCA: UR-00197, UCFA: KO-008. They plan to work as special callsign EM7UT on all bands CW/SSB/Digital modes. QSL via UR7UT, bureau or dirrect. 73 & 11! [tnx info UR7UT].
73 & 11! de Andrew RN1CW
THE CASTLES HUNTER
WCA coordinator & award manager
http://www.wcagroup.org
