IP maskerada
OdgovorNapisal/-a s56jlp » 19 Maj 2001, 13:34
kako se v linux debian-slink vkljuci IP maskerado? hocem se telnetati direktno na rcul in ne preko leje...
moj pr_pi0a:
ifconfig pi0a inet 44.150.1.81 hw ax25 S56JLP-6 netmask 255.255.0.0 broadcast 44.150.1.255 mtu 1500 arp up
echo -n 35 > /proc/sys/net/ax25/pi0a/t1_timeout
echo -n 2 > /proc/sys/net/ax25/pi0a/t2_timeout
echo -n 18000 > /proc/sys/net/ax25/pi0a/idle_timeout
echo -n 30 > /proc/sys/net/ax25/pi0a/maximum_retry_count
echo -n 1 > /proc/sys/net/ax25/pi0a/backoff_type
piconfig pi0a speed 0 clockmode 1 txdelay 2 persist 240 slot 3 squelch 2 dma 3
/sbin/route add 44.150.1.1 mss 1460 window 20440 irtt 500 dev pi0a
# /sbin/route add -net 44.150.1.1 netmask 255.255.255.0 mss 1460 window 20440 irtt 500 dev pi0a
/sbin/route add default pi0a
/sbin/route add 44.150.1.81 lo
/sbin/route add 44.150.1.81 mss 1500 window 2048 dev pi0a
# /sbin/route add 44.150.8.1 mss 1460 window 20440 irtt 500 dev pi0a
/usr/sbin/axparms -route add pi0a S50LEA S55YLJ -ipmode V
/usr/sbin/arp -H ax25 -i pi0a -s 44.150.1.1 S50LEA
# /usr/sbin/axparms -route add pi0a S50YFE S55YLJ-2 S55YIG-8
# /usr/sbin/arp -H ax25 -i pi0a -s 44.150.8.1 S50YFE
mislim, da so potrebne se neke DNS fore, ker mi telnet sedaj javi host name lookup failure, ce dam telnet open rcul.uni...
Leon
s56jlp
Prispevkov: 38
Pridružen: 18 Maj 2001, 01:00
Kraj: The Third Rock
OdgovorNapisal/-a s51bw » 19 Maj 2001, 19:13
Za uporabo IP maskerade ti kot "odjemalcu" ni treba nastaviti drugega kot default router na 44.150.1.1
(route add default gw 44.150.1.1).
DNS si seveda postimaj. V datoteko /etc/resolv.conf vpisi
nameserver 44.150.1.1
Andrej
s51bw
Prispevkov: 85
Pridružen: 17 Maj 2001, 01:00
Kraj: Space
OdgovorNapisal/-a s56jlp » 19 Maj 2001, 20:24
se vedno ne dela....
mogoce bo ta izpis kaj pomagal
/etc/host.conf:
order hosts,bind
multi on
/etc/hosts:
127.0.0.1 ATR localhost
/etc/resolv.conf:
# An example /etc/resolv.conf might look something like:
# domain ampr.org
# search ampr.org
name server 44.150.1.1
/etc/rc.boot/pr_pi0a:
ifconfig pi0a inet 44.150.1.81 hw ax25 S56JLP-6 netmask 255.255.255.0 broadcast 44.150.1.255 mtu 1500 arp up
# #/sbin/route add 44.150.1.1 mss 1460 window 20440 irtt 500 dev pi0a
/sbin/route add -net 44.150.1.0 netmask 255.255.255.0 pi0a
/sbin/route add default gw 44.150.1.1 pi0a
/sbin/route add 44.150.1.81 mss 1460 window 20440 dev pi0a
ukaz route -n:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
44.150.1.81 0.0.0.0 255.255.255.255 UH 0 0 0 pi0a
44.150.1.81 0.0.0.0 255.255.255.255 UH 0 0 0 lo
44.150.1.0 0.0.0.0 255.255.255.0 U 0 0 1 pi0a
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 1 lo
0.0.0.0 44.150.1.1 0.0.0.0 UG 0 0 0 pi0a
ukaz route -v:
44.150.1.81 * 255.255.255.255 UH 0 0 0 pi0a
44.150.1.81 * 255.255.255.255 UH 0 0 0 lo
44.150.1.0 * 255.255.255.0 U 0 0 1 pi0a
localnet * 255.0.0.0 U 0 0 1 lo
default 44.150.1.1 0.0.0.0 UG 0 0 0 pi0a
poskusil sem ze veliko drugih nastavitev (iz net in ax25 howto-ja), ampak brez uspeha.
tnx za pomoc,
Leon
s56jlp
Prispevkov: 38
OdgovorNapisal/-a s51bw » 19 Maj 2001, 20:34
Pravilen zapis v /etc/resolv.conf je
in ne
Torej, pisano skupaj je prav.
Andrej
s51bw
Prispevkov: 85
Kraj: Space
OdgovorNapisal/-a s56jlp » 19 Maj 2001, 20:45
prepisal sem direktno iz enega od howtojev..
bom poskusil
Leon
s56jlp
Prispevkov: 38
OdgovorNapisal/-a s56jlp » 19 Maj 2001, 20:55
zivjo Andrej,
ja sedaj dela. ponavadi gre vse narobe, ce se ne drzis howtojev, tokrat je bilo drugace..hi
mimogrede, ali je treba resetirati pc, ce spreminjas te skripte v /etc, da se ponovno nalozijo?
tnx za pomoc!
Leon
s56jlp
Prispevkov: 38
OdgovorNapisal/-a s51bw » 19 Maj 2001, 22:25
Linuxa ni treba restartati, razen ce ne menjas jedra operacijskega sistema...
Andrej
s51bw
Prispevkov: 85
Kraj: Space
Vrni se na S50LEA
