Vključen debug
Vključen debug
OdgovorNapisal/-a s57fk » 29 Jan 2011, 09:25
[phpBB Debug] PHP Notice: in file /viewtopic.php on line 981: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CET/1.0/no DST' instead
[phpBB Debug] PHP Notice: in file /viewtopic.php on line 981: getdate(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CET/1.0/no DST' instead
Sicer ni ne vem kako moteče, ampak tole bi bilo bolje odpravit, ali pa preusmerit v kak log ...
73 de Frenki S57FK
s57fk
Prispevkov: 8
Pridružen: 02 Jul 2008, 19:36
Kraj: Ljubljana, JN76GB
Re: Vključen debug
OdgovorNapisal/-a s55o » 29 Jan 2011, 10:19
Hvala za obvestilo!
B
Prispevkov: 2525
Re: Vključen debug
OdgovorNapisal/-a S55SR » 29 Jan 2011, 19:14
Tudi font je nekam velik. Vsaj pri meni. Glavna stran in podstrani tem so v redu, ko po odprem
prispevek (post) se font poveča za 200%.
ISF (imejte se fantastično)
Samo
S55SR
Prispevkov: 420
Pridružen: 28 Nov 2007, 17:11
Kraj: Koper - Capodistria
Re: Vključen debug
OdgovorNapisal/-a s51sk » 29 Jan 2011, 20:35
Enako, glede fontov.
s51sk
Prispevkov: 152
Pridružen: 23 Apr 2002, 09:05
Kraj: Ribnica
Re: Vključen debug
OdgovorNapisal/-a s57ad » 29 Jan 2011, 21:09
Enako!
s57ad
Prispevkov: 415
Pridružen: 17 Apr 2004, 17:40
Re: Vključen debug
OdgovorNapisal/-a S51U » 29 Jan 2011, 22:22
Enako veliki fonti ...
S51U
Prispevkov: 368
Pridružen: 12 Jul 2006, 12:50
Kraj: JN75GX
Re: Vključen debug
OdgovorNapisal/-a S59RA » 30 Jan 2011, 07:07
Enako, sem mislil, da je pri meni kaj spremenjeno
73 de Aleš, S59RA
S59RA
Prispevkov: 40
Pridružen: 31 Jul 2007, 19:03
Re: Vključen debug
OdgovorNapisal/-a S56INF » 30 Jan 2011, 12:33
Tudi pri meni na IE8 so fonti preveliki, ko grem na samo temo.
LP Marko
S56INF
Prispevkov: 17
Pridružen: 30 Nov 2009, 13:17
Re: Vključen debug
OdgovorNapisal/-a s52aa » 30 Jan 2011, 15:20
Fonti so posledica debug sporočila na vrhu, ki podre obliko foruma.
s52aa
Prispevkov: 539
Pridružen: 16 Nov 2004, 10:33
Kraj: Prelog, JN76HD
Re: Vključen debug
OdgovorNapisal/-a s57lx » 30 Jan 2011, 18:41
Hvala za informacijo o težavici. Sedaj bi moralo bit urejeno. :-)
Luka
s57lx
Prispevkov: 121
Pridružen: 15 Okt 2005, 21:44
Kraj: Medvode - JN76ED
Re: Vključen debug
OdgovorNapisal/-a S56INF » 30 Jan 2011, 20:30
Sedaj dela prav, hvala...
LP Marko
S56INF
Prispevkov: 17
Vrni se na S50LEA
