CW kurs po Avstrijsko z Morserino napravco
Forum za ljubitelje CW
OdgovorNapisal/-a S59A » 22 Jun 2020, 22:09
https://forums.qrz.com/index.php?thread ... se.711775/
Na QRZ.com-forums (link zgoraj) si lahko ogledate zanimive videe ,o tem kako so se Avstrijci lotili učenja telegrafije.
V ta namen, so izdelali napravco Morserino 32, ki pa nudi tudi mnogo več,kot samo učenje. Isto je mogoče tudi nabaviti po zmerni ceni pri njih.
Med drugim je možna povezava dveh Morserinov 32 med sabo in tako trenirati QSO-je,ali koristiti istega kot Keyer z raznimi memorijami,itd...
Več informacij na linkih ,ki so označeni na QRZ-forums.Po svetu že laufa preko 1500 Moserinov32.
73,Drago,S59A
S59A
Prispevkov: 86
Pridružen: 21 Feb 2006, 21:37
Re: CW kurs po Avstrijsko z Morserino napravco
OdgovorNapisal/-a s56rir » 27 Jun 2020, 12:41
Zanimiva stvarca glede na karakteristike.
Za večjo količino je malo ceneje.
Bi mogoče bil kdo zainteresiran za skupinski nakup?
73 de Martin
s56rir
Prispevkov: 52
Pridružen: 10 Dec 2002, 00:33
Kraj: JN86BN
OdgovorNapisal/-a s57ut » 29 Jun 2020, 12:01
Pa še objava iz Morserino FB strani:
From John, M0STQ:
If anyone would like to try out a basic QSO practice bot, just point your M32 to qsobot.online and give it a try.
Tommy has been very kind and patient, and helped me focus my attention on the QSO process, rather than doing an extended echo trainer. He already has the phrases trainer, and the M32 is pretty good at word training out of the box.
So, this server should help beginners (like me) practice a basic QSO, with both sending and receiving.
Thanks for any feedback. Instructions (in Markdown) below.
John
# QSObot instructions
## Background
This programme mimics a number of different people, each with a different callsign, name and home location.
It is meant to be used for beginners to practice a basic QSO. Getting more fluent with sending and head copying should allow a beginner to get ready to have practice QSOs with real people, or even go on air.
## Config
Set the Morserino-32 WiFi peer to be "qsobot.online".
That's it. Set the speed to something you can copy. The bot will answer at the same speed with which you send.
## Starting and Finishing
Once the M32 is connected to your local WiFi network, and ready to send, key in "qrl?".
This asks "Is this channel busy?". If the programme already has all slots busy with QSOs, it will answer "qrl". Try again in a few minutes.
If there's a spare slot - one of the bot personalities is available - then it will answer "k". You can now go on to the main QSO.
If you send an <SK> "...-.-" at any time, the bot will say goodbye and your QSO is finished. You need to ask "qrl?" if you want to start again.
If you send nothing for 4 minutes, the bot will time out and send you a goodbye transmission.
## Basics
You key in words, and end with a terminating prosign like k "-.-", <kn> "-.--.", <bk> "-...-.-", or <sk>/<va> "...-.-"
"kn" will be taken as a terminator, too, although kn "-.- -." isn't really correct to send at the end of a transmission. Try to make it a continuous <kn> with no space between the k and n.
Once you've sent your transmission, and ended with a prosign, the bot will send back a transmission, which will end with <kn> or <sk>. <kn> for all but the last transmission. <sk> for the last transmission.
When you've finished your transmission, the bot will think, and then send back its answer. While it is sending back to you, it is deaf. Anything you send before its final <kn> will be ignored.
If you make a mistake whilst sending, key in eight dits "........" and this will delete the eight dits and the previous word you sent. If you find you made a mistake two words ago, you can type in "........" "........" which will delete the previous two words. Then carry on with the transmission and send your terminating prosign.
## QSO format
Once you get your initial "k" from the bot, it will be waiting for you to transmit.
First thing to do is ask for a QSO: "cq de [your_callsign] k". If you want to practice a more realistic cq call, "cq cq cq de [your_callsign] [your_callsign] [your_callsign] k" will work. Any number of "cq"s and [your_callsign]s should work.
The bot you're connected with should respond. If it were q1bot, you'd get "[your_callsign] de q1bot <kn>"
Then transmissions ping pong between the user and the bot, with some essential bits of information being exchanged:
- RST report of the other side's transmission (readability, strength, tone)
- name of the person/bot
- location (QTH) of the person/bot
When these bits of information have been exchanged, the bot will just send messages showing that it knows who it's talking with.
This is the time to end the QSO. Say good bye and thanks, and end with <sk>. You are done. Congratulations!
## Formality of callsign usage
Formally, every transmission has four sections:
- starting callsigns "[receiver] de [sender]"
- actual text e.g. "ur rst 599 599 = how cpi?"
- ending callsigns "[receiver] de [sender]"
- terminating prosign e,g. <kn> or <sk>
The bot never sends <ar> or other prosigns, in this version.
When users prefer less formality, sometimes the starting callsigns or ending callsigns or both are omitted, apart from the first and last transmissions.
The bot will take its lead from the user. If you don't use starting callsigns, then it won't either. If you don't use ending callsigns, it won't either. When it says goodbye, it will use both starting and ending callsigns.
## Example QSO
qrl?
- k
cq cq de wibble wibble k
- wibble de q9bot <kn>
q9bot de wibble ur rst 579 579 <kn>
- wibble de q9bot ur rst 599 599 <kn>
q9bot de wibble gm es thanx fer call q9bot de wibble <kn>
- wibble de q9bot op hr mickey mickey = so ur name pse? wibble de q9bot <kn>
name/op and qth and rst have to be exchanged. When the bot has everything it needs it will say
- wibble de q9bot thnx bert from london fer 579 rpt wibble de q9bot <kn>
if you keep transmitting, the bot won't say anything new, in this version, so it's time to end...
q9bot de wibble thnx mickey = cuagn 73 73 q9bot de wibble <sk>
- wibble de q9bot ok cuagn 73 73 wibble de q9bot <sk>
and the bot has gone, and may now be talking to another user.
There are currently nine different names and locations to collect :-)
## Feedback welcomed
Hard error/bug reports are very welcome. Please send to the sub-group, so if others are also testing the bot, they know that the error has been reported.
Advice where the bot's current behaviour is against proper amateur radio procedures would be welcomed. I don't want to help beginners learn incorrect procedure :-) I'm a beginner, so I only know from the internet.
Comments on bits that you like and don't like would be interesting. If there is general agreement that something would be better done a different way, then I'll change it.
Feature requests. If people want something new added, then I'll add it to the roadmap list, but I might not get it done very quickly, because there are other things already on that list, like connecting the bot to an iCW/Mumble chat room.
Thanks,
John (M0STQ)
Lp,
Uroš S57UT
s57ut
Prispevkov: 16
Pridružen: 07 Jan 2017, 21:20
Kraj: Bohinj
OdgovorNapisal/-a S51VC » 23 Nov 2020, 18:48
Ojla.
Malo sem brskal za tem Morserino-32, se vpisal v mail listo in mislim, da se stvar trenutno ne da dobit. Ima kdo drugačne informacije? Je ta zadeva samo v kitu ali se da dobit že sestavljeno, delujočo?
S51VC Max
S51VC
Prispevkov: 88
Pridružen: 17 Nov 2001, 02:00
OdgovorNapisal/-a s57ut » 24 Nov 2020, 15:55
Koliko sem razbral iz objave na morserino strani, je trenutna zaloga pošla. Je pa za novo verzijo manjši problem, ker istega zvočnika ni več na voljo in bo za naslednjo rudno potrebno spremenit ploščico. Glede na interes sem prepričan, da bo nova runda kar hitro na voljo.
Kar pa se "kit" kompleta tiče, se ni kaj za bat, naprava pride skorajda izdelana in če nimaš res dveh levih rok ne bi smelo biti nobenih težav s sestavljanjem.
73, Uroš S57UT
s57ut
Prispevkov: 16
Kraj: Bohinj
OdgovorNapisal/-a s56rir » 24 Nov 2020, 22:11
Kot že napisano je prva serija razprodana pa morajo zaradi zvočnikov narediti redizajn.
Dobiš lahko že zaključeno ali pa KIT, samo zna malo trajati. Je tako že vsaj mesec in pol, ko sem se odločil za naročilo, pa ni bilo več možno zaradi že navedenega.
Sem si naročil par ESP modulov, programje se dobi na git-u, ostalo periferijo pa bom sam naklamfal zraven. Se že peljejo in bi morali priti še letos.
Mogoče pridem kaj ceneje pa hitreje skoz.
73 de Martin
s56rir
Prispevkov: 52
Kraj: JN86BN
OdgovorNapisal/-a s57fj » 07 Dec 2020, 20:36
Če se bi šlo v kakšno skupinsko nabavo, se priklopim zraven.
Lp 73 S57fj Florjan
s57fj
Prispevkov: 119
Pridružen: 05 Dec 2018, 22:43
OdgovorNapisal/-a s56rir » 08 Dec 2020, 00:15
Sem dobil ESP module v petek. Samo so Kitajci poslali module z napačno frekvenco (868MHz namesto 433MHz).
Moram preveriti, če SW kaj vpliva. Verjetno ne, pa bomo pač malo višje "cvilili".
Malo je sicer pomanjkanje časa zaradi dela od doma in šolanja hkrati, ampak bom probal zadevo speljati še letos.
73 de Martin
s56rir
Prispevkov: 52
Kraj: JN86BN
OdgovorNapisal/-a s53v » 08 Dec 2020, 00:39
Hoj !
Ko gledam to napravco - porabiš več časa za programiranje, kot za učenje. :D :D Zakaj bi preprosto, če pa lahko kompliciramo. :D
Pred mnogo leti smo se učili in naučili z enostavno "zujalico " ali "zumerjem" tako, da smo kje staknili telefonsko slušalko in ogljeni mikrofon v serijo povezali 4,5V baterijo, dodali dva kontakta in list od žage kot taster in se je pouk začel. Pa so bili na bandu v tistih časih z "zujalico" ,ko še ni bilo raznih Morserinov boljši telegrafisti,kot danes. !!
Veliko ceneje bo, če na WEB-u ali Youtubu pogledate nek tečaj za sprejem telegrafije , za tipkanje pa kupite za nekih 30€ na E-bayu ali Aliexpressu Kitajski taster,ki že ima vgrajen "zumer" in ročico. Tudi kar nekaj starih tasterjev, ki jih je včasih izdelovala ZRS se še valja po klubih. Kdor pa že ima doma postajo ne rabi nič drugega razen ročice , saj ima danes praktično vsaka postaja že vgrajen elektronski taster z monitorjem. Na oddajniku pa se samo zapre izhodna moč.
Posebej sedaj v času Corona krize ,ko je doma časa na pretek se da solidno naučiti telegrafije v kakšnem mesecu toliko, da se potem skupaj s pomočjo nekoga ,ki že ima izkušnje poskusi narediti kakšno QRS CW zvezo nekje okrog 3550kHz. Je pa treba vstrajat in vsaki dan vadit vsaj pol ure.
Pa veliko užitka ob učenju
Prispevkov: 649
Vrni se na CW
