SOTA na 4m bandu
SOTA na 4m bandu
OdgovorNapisal/-a S57D » 01 Mar 2009, 11:27
Odlomek o slovenskih aktivnostih na 70MHz iz februarskih SOTA novic:
4 Metres
Our friends in Slovenia are now becoming active on 4m and I am pleased to report an activation by Milos, S57D/P in company with Sabina, S57BNX and Zvone, S57OPZ from the summit of Pasja ravan S5/CP-011 where they had six contacts with other Slovenian stations and one with 9A1Z on SSB. There were also spots for several S5 stations operating on different summits on 4m FM during Saturday Feb 28th, (also using the Wouxun-699E) and it is known that several contacts were made, including at least three S2S contacts. More and more countries are now getting access to 4m so it worth checking The Four Metre Website for the latest information.
The Es season will soon be on us so we can look forward to working stations outside of the UK on 4m from a summit.
Ron, GW4EVX
Re: SOTA na 4m bandu
OdgovorNapisal/-a S57D » 01 Apr 2009, 18:52
Odlomek o slovenskih aktivnostih na 70MHz iz marčevskih SOTA novic:
4 Metres
Another bumper month of activations on four metres due in part to the increasing number of operators using the excellent little Wouxun KG-699E handheld. The known activators using this rig are: Mike G4BLH, Ian 2E0EDX, Gerald G4OIG, Steve G1INK, Geoff G6MZX, Mike GW0DSP, Steve GW7AAV and Tony M6ADL. Also, in Slovenia S57OPZ, S57XX, S58MU, S57BNX and S57D. I also bought one a couple of weeks ago but have not used it for an activation yet. Anyone contemplating buying one from the eBay supplier need have no fears since they seem to be a very reputable company to deal with. I had a problem with the desk-top charger on mine and they sent me a replacement very promptly with no hassle.
Mention was made earlier of some S5 stations tryimg out 4m activations. S56WDN was one of those stations making 3 contacts from Malenski vrh S5/CP-009 on and 1 contact from Gabrška gora S5/CP-017 both on 15th March.
Ron
GW4EVX
Pri poročilu manjkajo aktivacije S57OPZ, S57XX in S57X.
OdgovorNapisal/-a S57D » 01 Maj 2009, 11:04
Odlomek o slovenskih aktivnostih na 70MHz iz aprilskih SOTA novic:
4 Metres
Our friends in Slovenia were also active on four metres during April. On the 5th S57XX was on Sveti Trije Kralji S5/TK-025, S57OPZ was on Gabrska gora S5/CP-017, while S57D and S57BNX were on Jance S5/BI-029. There were also several S5 stations out on the 13th including S57OPZ on Kucelj S5/CP-021 and S57XX on Sorta S5/CP-014. S57OPZ was out again on the 19th, this time on Mladi vrh S5/CP-006 from where he worked S51ZG and S57D.
Ron, GW4EVX
OdgovorNapisal/-a S57D » 01 Jun 2009, 08:57
Odlomek o slovenskih aktivnostih na 70MHz iz majskih SOTA novic:
4 Metres
May got off to a quick 70MHz start thanks to our friends in Slovenia. May 1st saw Jure S57XX/P out on Oblek S5/JA-043 while S57OPZ/P was on Kojca S5/CP-007 around the same time resulting in a 4m FM S2S contact between them. S57XX made 4 contacts and S57OPZ made 3 contacts.
Jure was out again on May 3rd, this time on Veliki vrh S5/PK-006 from where he worked S57D/P and S57BNX/P, both on Obolno S5/BI-031.
Zvone S57OPZ was active on the 16th from Veliki vrh S5/PK006 on 70MHz SSB and worked S51DI, S51ZG and 9A4QV. He is very keen to work the UK on four metres but points that it is 'necessary to have a bit of luck'. According to Zvone there are only six stations in S5 active on 4m SSB or CW. Of these Ivan S51DI and Janex S51ZG are perhaps the best known with many stations in the United Kingdom having worked them (even on FM) when there have been Sporadic E openings.
Zvone has a list of local mountains from where he can be QRV in about 30 minutes should there be an opening to the UK. Zvone's antenna for 70MHz and 50MHz is a sort of homebrew 3 element HB9 but the elements can be adjusted for one band or the other.
The rig is an FT817 for 6m (5w) which can also be used to drive a Spectrum TRC4-10sL transverter on 70 MHz giving in excess of 30w output and all powered from a 14Ah battery.
It really would be nice to make an S5 summit contact on 4m ssb (an S2S would be even better). Lets hope that we get some decent Sporadic E propagation over the coming months. Photos and information courtesy of Zvone S57OPZ.
Mike G4BLH
OdgovorNapisal/-a S57D » 01 Jul 2009, 10:46
Odlomek o slovenskih aktivnostih na 70MHz iz junijskih SOTA novic:
4 Metres
Levels of summit activity on four metres continued to be very good during June and it is very pleasing to see the band getting more use. It would be really fantastic to see a summit to summit contact between the UK and perhaps S5 if we can get some decent sporadic E propagation.
Zvone S57OPZ did get some four metre ssb contacts to the UK during his activation of Škofje S5/CP-016 on June 1st, namely GW0HZY, GU8FBO and G4AJC, but none of these are regular chasers. On the 13th, Zvone was out again, this time using the callsign S58SOTA/P from Pasja ravan S5/CP-011 (7 contacts using SSB &FM). The same callsign was also used on the 14th from Porezen S5/CP-002 (7 contacts using FM). On the 21st Zvone was on Sveti Trije Kralji S5/TK-025 using the callsign S54SOTA/P and managed a S2S contact on 70Mhz FM with Milos S57D on Ulovka S5/TK-028.
Mike G4BLH
OdgovorNapisal/-a S57D » 01 Avg 2009, 11:43
Odlomek o slovenskih aktivnostih na 70MHz iz julijskih SOTA novic:
4 Metres
On July 12th our friends in Slovenia joined in the 'four metre fun' when Jure S57XX activated Vivodnik S5/KS-028 making five contacts. On the 19th Jure activated Gradišce {Njivica} S5/KS-020 making 3 contacts on 4m FM including a S2S with S57D/P and S57BNX/P on Gora {Sveti Ahac} S5/RG-038.
Mike G4BLH
V poročilu manjkajo vsaj še aktivacije Zvoneta S57OPZ z Vrtače S5/KA-002 ter Milana S58MU z Blegoša S5/CP-003, Mladega vrha S5/CP-006, Koprivnika S5/CP-005 in Malenskega vrha S5/CP-009.
OdgovorNapisal/-a S57D » 01 Sep 2009, 08:33
Odlomek o slovenskih aktivnostih na 70MHz iz avgustovskih SOTA novic:
4 Metres (all activity FM unless otherwise stated)
Our friends in Slovenia were also active on four metres during August. On August 6th Zvone S57OPZ operated from the summit of Kepa S5/KA-003 and made 4 contacts including a S2S with Jure S57XX/P on Jošt nad Kranjem S5/CP-023. Jure in turn made 4 contacts including a S2S with Milos S57D on Krn S5/JA-022. On the 8th of August Zvone activated Stol S5/KA-001, this time making 5 contacts on 70MHz. This was followed up with another activation on August 12th from Košutnikov turn S5KA-004. Four contacts were made this time including an S2S with Jure S57XX/P on Rudnica S5/JA-047. Jure had been up on Ulovka S5/TK-028 on August 9th making just 3 contacts on 4 metres. Incidentally, Zvone has now got a new callsign, S57PZ which he used on 4m on August 30th from the summit of Slatnik S5/JA-035 making 5 contacts.
Slika Slika
On August 15th there were multiple activations using 4m including Milos S57D on Mangart S5/JA-003 and S53DGM/P + S56WDN/P + S54KM/P all operating from Plešivec S5/KA-028. The photos above were taken on the summit of S5/JA-003. The photo on the left shows (from left to right) the Icom IC-V82(7W-144MHz), Wouxun KG-UVD1(4W-433MHz) and Wouxun KG-699E(5W-70MHz). The photos above courtesy of Milos S57D.
Mike G4BLH
V poročilu ni vključena včerajšnja aktivacija Milana S58MU z Golega vrha.
OdgovorNapisal/-a S57D » 01 Okt 2009, 11:26
Odlomek o slovenskih aktivnostih na 70MHz iz septemberskih SOTA novic:
Milan S58MU/P got four metre activations underway on the 1st of the month from Škofje S5/CP-016 making three contacts.
On the 6th S57PZ was up on Altemaver S5/CP-001 and made 3 contacts while on the 9th he made just 2 contacts from Storžic S5/KA-005. S57XX activated Visoki Kanin S5/JA-006 and made a S2S contact with S57D/P and S57BNX/P who were both up on Slatnik S5/JA-035.
On Sep 12th S57D was up on Velika Slivnica S5/RG-009 but only worked one station on 4m, S57PZ. S57XX did not fare any better from Polhograjska Gora S5/CP-024 on the 13th when he too worked just one station on 4m, S57ILF.
S56UBS and S57DGM activated Blegoš S5/CP-003 on the 27th, but only made one contact (S57ILF).
Mike G4BLH
OdgovorNapisal/-a S57D » 01 Nov 2009, 13:10
Odlomek o slovenskih aktivnostih na 70MHz iz oktoberskih SOTA novic:
S56LXN was very active on 4m during October. On the 8th he made two 4m contacts from Strmec S5/CP-020. On the 11th he first activated ((S5/CP-002|Porezen)) S5/CP-002 making three 4m contacts. followed by Crvov vrh S5/CP-015 from where he made just one contact. On the 13th his summit activation was from Šorta S5/CP-014 which also resulted in just the one 4m QSO. On the 17th the summit activation was from Roviškovec S5/BI-011 (1 contact) and on the 18th the activation was from Parg (Peterkov vrh S5/RG-012 again resulting in just one 4m contact.
Mike G4BLH
OdgovorNapisal/-a S57D » 02 Jan 2010, 11:52
Odlomek o slovenskih aktivnostih na 70MHz iz decemberskih SOTA novic:
There was also a little bit of activity in Slovenia. S56LXN worked just S57ILF on Dec 2nd from Trupejevo Poldne S5/KA-010. He worked the same station from Slatnik S5/JA-035 on Dec 17th.
Mike G4BLH
OdgovorNapisal/-a S57D » 01 Feb 2010, 12:49
Odlomek o slovenskih aktivnostih na 70MHz iz januarskih SOTA novic:
Four metre activity was not confined to the UK. On January 3rd, S57PZ activated Velika Slivnica S5/RG-009 and made four contacts. S56LXN activated Kranjska Reber S5/KS-029 on Jan 4th making two contacts.He followed this up on the 14th from Gradišce {Njivica} S5/KS-020 (one contact), then on the 17th from Smledniški hrib S5/CP-035 (two contacts) and on the 20th from Lubnik S5/CP-012 (three contacts).
Mike G4BLH
OdgovorNapisal/-a S57D » 01 Mar 2010, 19:04
There was quite a lot of activity on 4m FM this month, and several reports were received from activators, many thanks for that.
On February 8th, S56LXN activated Krim S5/RG-010 and made four FM contacts including a S2S with S57XX/P on Pasja ravan S5/CP-011. On the 14th he switched to Velika Slivnica S5/RG-009 and worked just S51ZG while on the 16th it was the turn of Vovar S5/KS-044 to be activated with just two stations making it into the 4m log. Bojan also made 4m FM contacts from Dovška Baba S5/KA-011 on the 25th and from Blegoš S5/CP-003 on the 27th. He also had an alert out on Feb 28th for Črni vrh S5/BI-002 but at the time of going to press no spots had been seen.
Mike G4BLH
OdgovorNapisal/-a S57D » 12 Apr 2010, 12:01
As usual, there was also some activity from Slovenia. On March 6th S56LXN activated Tošc S5/CP-013 and made three contacts on 4m FM. On the 7th he activated Pasja ravan S5/CP-011, this time making just one contact, while on the 17th it was the turn of Debela pec S5/JA-029 (three contacts). On March 20th S57XX made just one 4m FM contact during his activation of Sivka S5/TK-022.
Mike G4BLH
OdgovorNapisal/-a S57D » 03 Maj 2010, 14:12
'Across the water' there were 4m spots during the month for Kjell LA1KHA on Mistberget LA/AH-006, S57PZ on Škofje S5/CP-016 and S56LXN on Mohor S5/CP-019 and Osolnik S5/CP-022.
Mike G4BLH
Zaradi nedelovanja SOTAdatabase je poročilo nepopolno, saj je bilo aktivnosti v S5 veliko več.
OdgovorNapisal/-a S57D » 03 Jun 2010, 14:02
I am aware that there was also four metre activity from LA and S5 but do not have any details.
Mike G4BLH
Aktivnosti v mesecu maju je bilo na 70MHz kar precej, še posebno je bilo živahno 1. in 2. maja, ko je potekal SOTA activity weekend.
