SOTA na 6m bandu
SOTA na 6m bandu
OdgovorNapisal/-a S57D » 01 Mar 2009, 10:22
Odlomek o slovenskih aktivnostih na 50MHz iz februarskih SOTA novic:
6 Metres
Our Slovenian friends have also been busy on 6m during the month with five activations taking place. All contacts were made on SSB. Milos, S57D in the same company as his 4m activation was on the summit of Krim S5/RG-010 on the 14th and worked four S5 stations plus a S2S with S56JAZ/P who was on the summit of Reber S5/BI-017. S56JAZ also worked five other S5 stations from his summit.
On the 19th Andy, S53MN/P activated Vrh Staneta Kosca S5/CP-031 and had one contact with S57D.
On the 21st Milos and usual friends operated from the summit of Pasja ravan S5/CP-011 and worked between them 12 Slovenian stations and one from Austria.
Finally on the 22nd Milos and friends were out again this time from the summit of Malenski vrh S5/CP-009 from where they made 10 contacts with other S5 stations.
Ron, GW4EVX
S57D
Prispevkov: 1230
Pridružen: 01 Maj 2003, 16:09
Kraj: Ljubljana - JN76GC
Re: SOTA na 6m bandu
OdgovorNapisal/-a S57D » 01 Maj 2009, 10:08
Odlomek o slovenskih aktivnostih na 50MHz iz aprilskih SOTA novic:
6 Metres
There was also some six metre SSB activity in Slovenia. On the 11th S57XX on Smledniski hrib S5/CP-035 worked S56JAZ/P on Kozica S5/BI-007 who made a total of 10 contacts from that summit. On the 13th S57OPZ had 11 S5 contacts from the summit of Kucelj S5/CP-021 and on the 19th had six S5 and two OE contacts from Mladivrh S5/CP-006.
Ron, GW4EVX
V poročilu manjka moja aktivacija na 50MHz z Janč.
S57D
Prispevkov: 1230
OdgovorNapisal/-a S57D » 01 Jun 2009, 08:05
Odlomek o slovenskih aktivnostih na 50MHz iz majskih SOTA novic:
6 Metres
Marjan S56JAZ/P started the ball rolling on 50MHz on May 1st with his activation of Crni vrh S5/PK-001 on ssb resulting in 6 contacts including 9A2EA. Marjan was out again the following day this time from Velika Kopa S5/PK-002 with another 6 ssb contacts in the log, and on May 17th he was on Rzenik S5/KS-016, this time with just 2 contacts. On May 23rd S56JAZ was out on Košutica S5/KA-008 and made 8 50MHz ssb contacts including IZ3LED.
Also out on May 1st was Zvone S57OPZ operating from Kojca S5/CP-007 from where he had 5 ssb contacts. On the 16th of the month Zvone activated Veliki vrh S5/PK-006, this time with 9 contacts on ssb including 9A3XM.
Slika Slika
On May 23rd it was the turn of Vrh Korena S5/KS-013 (which is from where the photos above were taken) Zvone made a load of 50MHz ssb contacts including OE8SPW, OE8XBH, 9A4K and nine S5 stations. Photos again courtesy of Zvone S57OPZ.
There was more activity from the lads (and lasses) in Slovenia in the shape of Milos S57D who, together with Sabina S57BNX, activated Limbarska gora S5/BI-033 on May 2nd (1 ssb contact), Obolno S5/BI-031 on May 3rd (5 ssb contacts) and Šmarjetna gora S5/CP-030 with a massive haul of 17 contacts including SV9CJO.
Mike G4BLH
S57D
Prispevkov: 1230
OdgovorNapisal/-a S57D » 03 Jun 2009, 13:02
Zadnja novica na Summitsbase Latest News:
Slovenia Summit worked from UK on 50MHz
On Monday June 1st well known UK SOTA activator/chaser Frank G3RMD made it into the log of Zvone S57OPZ operating from Škofje S5/CP-016 using 50MHz ssb, so it would appear that the sporadic E season has arrived at last. Frank was using an Icom 7000 and delta loop antenna.
(Mike G4BLH - 3rd June 2009)
Zvone S57OPZ was working with 3 element home made HB9 antenna and Yaesu FT-817 with 5W output.
(Milos S57D - 3rd June 2009)
S57D
Prispevkov: 1230
OdgovorNapisal/-a S57D » 01 Jul 2009, 09:58
Odlomek o slovenskih aktivnostih na 50MHz iz junijskih SOTA novic:
6 Metres
Six metres got off to an excellent start on the 1st of June with some good sporadic E conditions which allowed Zvone S57OPZ operating from Škofje S5/CP-016 to make contact with 15 stations including Frank G3RMD and stations in EI, EA and F. Zvone was out again later in the month and using the callsign S58SOTA activated Pasja ravan S5/CP-011 on the 13th (7 contacts inc SV) and Porezen S5/CP-002 on the 14th (20 contacts inc 9A, EA & I). On June 21st Zvone, this time using S54SOTA/P made 11 contacts from Sveti Trije Kralji S5TK-025 on 50Mhz, including G and GW, but there were no 50Mhz spots for him on SOTAwatch (the stations worked were not regular chasers).
More good conditions on June 11th gave Marjan S56JAZ on Veliki vrh {V. Zelenica} S5KS-010 contacts with G4JZF, GM0AXY and 7 other stations. The next day Marjan operated from Planjava S5/KS-004 and made 9 contacts including 5B4 & 9H4. On the 13th Marjan activated Ojstrica S5/KS-005 making 22 contacts on 6 metres including a S2S with S58SOTA/P.
There was more activity from Slovenia on June 14th in the shape of S56IHX on Veliki Rogatec S5/KS-027 (8 contacts) while on the 21st, Miran S56UBS activated Gora {Sveti Ahac} S5/RG-038 (7 contacts). Jurij S57AJJ/P made two contacts using 6m SSB from Plece S5/KA-027 on June 27th.
Milos S57D operated as S58SOTA on June 18th from Velika Kopa S5/PK-002 (12 contacts inc. LZ2SK, UT8IM, & T77C. Milos was out again on the 21st using his own callsign from Ulovka S5/TK-008 and made well over 30 contacts on 50MHz SSB including, among others, Don G0NES, Steve GW7AVV and Don G0RQL. These two photos courtesy of Milos S57D show the 'set up ' Milos was using on Ulovka S5/TK-028.
Slika Slika
Mike G4BLH
V poročilu manjkajo aktivacije Jurija S57X, ki jih je naredil s S5xSOTA/p pozivnimi znaki.
S57D
Prispevkov: 1230
OdgovorNapisal/-a S57D » 01 Avg 2009, 11:12
Odlomek o slovenskih aktivnostih na 50MHz iz julijskih SOTA novic:
6 Metres
S56JAZ was active on July 12th from Tosc S5/JA-021 making just one contact with IW3IA. He was out again on July 26th this time from Travnik S5/JA-057 from where he made four contacts (all S5 stations).
Mike G4BLH
V poročilu manjka vsaj še aktivacija S57BNX in S57D z Gore S5/RG-038.
S57D
Prispevkov: 1230
OdgovorNapisal/-a S57D » 01 Sep 2009, 07:47
Odlomek o slovenskih aktivnostih na 50MHz iz avgustovskih SOTA novic:
6 Metres (all activity SSB unless otherwise stated)
On the first of the month, Marjan S56JAZ operated from Rjavina S5/JA-009 and made 7 contacts. Two days later he activated Razor S5/JA-005 making just 2 contacts. On the 26th he was on Stenar S5/JA-010 making just one contact, while later the same day Marjan activated Pihavec S5/JA-014 this time making 3 contacts with other S5 stations.
The only way of checking on 4/6/10m activity is by looking at spots/alerts, working the stations or by receiving information directly from activators/chasers. It is impossible to trawl through every single activator entry, so it is inevitable that some activations will get missed. If you have any photos or information about 10, 4 or 6m activity, they would be gratefully received by your correspondent via data@summitsbase.org.uk
Mike G4BLH
S57D
Prispevkov: 1230
OdgovorNapisal/-a S57D » 01 Okt 2009, 10:30
Odlomek o slovenskih aktivnostih na 50MHz iz septemberskih SOTA novic:
Activity on 6m seems to be almost non existent at the moment. There were several 'alerts' for 50MHz operation during September, but very little evidence that they resulted in any contacts.
Any photos or information about 10, 4 or 6m activity would be gratefully received by your correspondent via data@summitsbase.org.uk
Mike G4BLH
S57D
Prispevkov: 1230
OdgovorNapisal/-a S57D » 03 Jun 2010, 13:06
S57AX was very active during May. On the 9th he was on Šentanski vrh S5/KA-029 and made seven FM contacts(S5 and 9A). He also made 50MHz contacts from another ten, yes ten, summits during May.
Mike G4BLH
S57D
Prispevkov: 1230
OdgovorNapisal/-a S57D » 02 Jul 2010, 18:30
There were some excellent conditions on six metres during June with stations from all over Europe being heard.
Darko S57AX was very active on the band during the month with activations from Veliki Javornik S5/BR-005 (5 ssb contacts),Velika Slivnica S5/RG-009 (4 ssb contacts), Velika Vremšcica S5/BR-013 (4 ssb contacts) and Jerebikovec S5/JA-036 (8 ssb contacts) to mention just a few. S57PZ was active on the 6th from Mladi vrh S5/CP-006 making just 4 contacts.
Mike G4BLH
S57D
Prispevkov: 1230
Vrni se na Vprašanja in odgovori
