Napisal/-a S57D » 01 Jul 2009, 10:58
Odlomek o slovenskih aktivnostih na 50MHz iz junijskih SOTA novic:
6 MetresSix metres got off to an excellent start on the 1st of June with some good sporadic E conditions which allowed Zvone S57OPZ operating from Škofje S5/CP-016 to make contact with 15 stations including Frank G3RMD and stations in EI, EA and F. Zvone was out again later in the month and using the callsign S58SOTA activated Pasja ravan S5/CP-011 on the 13th (7 contacts inc SV) and Porezen S5/CP-002 on the 14th (20 contacts inc 9A, EA & I). On June 21st Zvone, this time using S54SOTA/P made 11 contacts from Sveti Trije Kralji S5TK-025 on 50Mhz, including G and GW, but there were no 50Mhz spots for him on SOTAwatch (the stations worked were not regular chasers).
More good conditions on June 11th gave Marjan S56JAZ on Veliki vrh {V. Zelenica} S5KS-010 contacts with G4JZF, GM0AXY and 7 other stations. The next day Marjan operated from Planjava S5/KS-004 and made 9 contacts including 5B4 & 9H4. On the 13th Marjan activated Ojstrica S5/KS-005 making 22 contacts on 6 metres including a S2S with S58SOTA/P.
There was more activity from Slovenia on June 14th in the shape of S56IHX on Veliki Rogatec S5/KS-027 (8 contacts) while on the 21st, Miran S56UBS activated Gora {Sveti Ahac} S5/RG-038 (7 contacts). Jurij S57AJJ/P made two contacts using 6m SSB from Plece S5/KA-027 on June 27th.
Milos S57D operated as S58SOTA on June 18th from Velika Kopa S5/PK-002 (12 contacts inc. LZ2SK, UT8IM, & T77C. Milos was out again on the 21st using his own callsign from Ulovka S5/TK-008 and made well over 30 contacts on 50MHz SSB including, among others, Don G0NES, Steve GW7AVV and Don G0RQL. These two photos courtesy of Milos S57D show the 'set up ' Milos was using on Ulovka S5/TK-028.
Mike G4BLH
V poročilu manjkajo aktivacije Jurija S57X, ki jih je naredil s S5xSOTA/p pozivnimi znaki.
