Nova verzija echolinka
Stržniki, prehodi, delovanje, navodila, nastavitve, ...
Moderator: S56CT
OdgovorNapisal/-a S56CT » 02 Mar 2007, 09:58
V teh dneh je po dolgem času na voljo nova verzija echolink-a za Windowse. V novi verziji naj bi odpravili nekatere hroščke in jo seveda pripravili za Visto.
Kljub temu, da naj bi nova verzija omogočala nekatere nove funkcije, kot tudi preverko firewalla, za tiste, ki ne znajo drugače preveriti nastavitev požarnega zidu ter audio kompresorje so večinom vsi, ki so novo verzijo preizkusili nazaj naložili staro varijanto.
Skratka, zaenkrat nima smisla, da si posodabljate staro verzijo, razen, če hočete in si želite problemov. :D
Tule je še objava o omenjeni posodobitvi iz yahoo groups, objav nezadovoljnih hamov, ki so si naložili novo verzijo pa ne bom prilepil, ker je na lei premalo diska. :D
Dear Echolinkers
The new version of Echolink Software 2.0.902 is available for download. Those
who already have the new version to kindly ignore the message.
NOTE- before downloading/installing take backup of the following :
1.Your important .wav recordings/beeps etc. located usually in the Program
files>> K1RFD folder(echolink software) >> wav folder.(Recordings done using
Echolink software)
2. Back up of Favorit's folder all your favorit call sign in a text file.
Later you can copy paste .wav files and favorits call-signs back into the
respective folders in the new version.
To check your Echolink software needs an upgradation : Goto: Echolink
software >> Help Menu >> Software Updates (Sub Menu) >> Click "Check for
Updates" button.
This what the latest update on the www.echolink.org says dtd:02-25-2007
under "News and Tips" link on the site http://www.echolink.org/news.htm :
"25 February 2007: Version 2.0.902 of the EchoLink software is now available.
Along with a number of bug fixes, this version makes it easier to use an
EchoLink Proxy, and includes a built-in firewall tester and sound-card
calibrator. There are also several changes to ensure smooth operation on Windows
Vista, and an updated installer. This is a recommended upgrade for all EchoLink
users. "
Current Version: 2.0.902
2.0.902 (February 25, 2007)
Updated installer.
Drop-down box to select public proxy; new Proxy and Performance tabs.
Proxy can be changed without requiring re-start.
Sound card fine-tuning control with self-calibrate option.
Built-in Firewall Test utility (similar to Troubleshooter).
Added DTMFDigit event to API.
Opening wave device at startup so it shows up on Vista volume panel.
Moved text and WAV files to My Documents area instead of install
directory.
Added more COM ports to drop-down lists (COM9-COM16).
Bug fix for: Showing incorrect list of input devices on Audio page
Bug fix for: Vista behavior on links to level adjustments
Bug fix for: Speed-dial ambiguity between base and Sysop calls
Bug fix for: StartRecordingQSO parameter in API
Bug fix for: API events that have Boolean parameters using wrong value
for True
Bug fix for: Space bar sometimes non-responsive as TX control
Bug fix for: Allowing Connect command via API when link disabled
Bug fix for: Incorrect listings for Serbia and Macau
Bug fix for: Incorrect shortcut key for switching views in Keyboard
Shortcuts Help page
Bug fix for: Minimize/Restore not working as expected
Bug fix for: Incorrect initialization of interface type in Link Setup
Wizard
Bug fix for: When using the Web remote control feature in Sysop mode,
the Connect To function does not work with callsigns that begin with a digit.
I have download the above mentioned ver and its running fine so far on windows
2000 Pro. yet to try the proxy related changes in the software.
73's
Karan VU3GTF
Vrni se na ECHOLINK
Po forumu brska: Google [Bot] in 2 gostov
