Iss school qso Friday 27 October 2006, 10:36 UTC
Stržniki, prehodi, delovanje, navodila, nastavitve, ...
Moderator: S56CT
OdgovorNapisal/-a S56CT » 26 Okt 2006, 21:54
On Friday 27 October 2006, starting at 10:36 UTC, there will be a contact between the ISS and the Flanders Science Festival Euro Space Center,Transienne in Belgium. This is a bridge contact with the ground
station WH6PN in Hawaii. Please join us in listening to this event.
The audio for this event will be fed into the EchoLink *AMSAT* (101
377) and *JK1ZRW* (277 208) servers. There is a possibility that the
audio from this event will also be fed into the IRLP Discovery Reflector 9010. We hope that all goes well and that the audio can be made available to us as planned. We hope to have good two way audio from this contact.
Please note that there are automatic breaks in the audio transmission
every 2.5 minutes during the event and while we listen to preparations
going on for this contact from about 20 minutes or so before the start of this event. On the EchoLink system, we normally feed the audio during
preparations for contacts, if the audio from the preparations is
suitable for transmission into ham radio systems. Each audio break is
approximately 1 second long. Please configure your systems to not time out during times of inactivity or ongoing audio transmissions.
For everyone's information and future reference. When any ARISS
event is supported through the IRLP "Discovery" Reflector 9010, audio is
automatically streamed to the Internet.
It is then available via the "Discovery" Reflectors companion web site
www.discoveryreflector.ca . Once on its main page, select "Audio
Library" (left side bar). The prompt to join the audio stream is posted at the top of this page.
More directly the URL is as follows: www.discoveryreflector.ca:8000/listen.pls
The audio on the Internet is typically delayed by about two minutes.
73 de Dieter kx4y
Dieter K. Schliemann, kx4y - zs6bbh - hs0zcn
ARISS EchoLink audio feed team member
1803 Roseberry Drive, Scottsboro, AL 35769-3960, USA
Home Phone - (256) 259-3900
Cell Phone - (256) 599-0581 (only on when away from home)
IRLP node 4713, EchoLink node 47135
Skype user ID: zs6bbh
73 Ian G3ZHI
Why not link your local repeater to the internet?
http://www.qsl.net/g3zhi - many ham radio links
http://www.ukirlp.co.uk
G4NJI IRLP 5200 Echolink 135909
Rotherham simplex 145.2875mhz
OdgovorNapisal/-a S56CT » 27 Okt 2006, 12:42
SKED je odpovedan!!!!!
73, Tilen
Vrni se na ECHOLINK
