Fri 11 aug 2006 iss school qso 0732utc on echolink
Stržniki, prehodi, delovanje, navodila, nastavitve, ...
Moderator: S56CT
OdgovorNapisal/-a S56CT » 10 Avg 2006, 05:49
On Friday 11 August 2006, starting at 07:32 UTC, there will be a
contact between the ISS and the Teven-Tintenbar School in Australia.
This is a direct contact between the ham radio ground station at the school and the ISS.
Please join us in listening to this event.
The ham radio operators at the school during this event, plan on
feeding the two way audio from this event to the ARISS team via Skype. The ARISS audio feed team plan on feeding the audio from this contact from Skype into the EchoLink *AMSAT* (101 377) and *JK1ZRW* (277 208) servers, as well as into the IRLP Discovery Reflector 9010. We hope that all goes well and that the audio can be made available as planned. This being a direct contact, we hope to have good two way audio from
this contact.
Please note that there are automatic breaks in the audio transmission
every 2.5 minutes during the event and while we listen to preparations
going on for this contact. On the EchoLink system, we normally
feed the audio during preparations for contacts, if the audio from the preparations is suitable for transmission into ham radio systems. Each audio breakis approximately 1 second long. Please configure your systems to not time out during times of inactivity or ongoing audio transmissions.
For everyone's information and future reference. When any ARISS
event is supported through the IRLP "Discovery" Reflector 9010, audio is
automatically streamed to the Internet.
It is then available via the "Discovery" Reflectors companion web
site www.discoveryreflector.ca . Once on its main page, select "Audio
Library" (left sidebar). The prompt to join the audio stream is posted at the
top of this page.
More directly the URL is as follows: www.discoveryreflector.ca:8000/listen.pls
The audio on the Internet is typically delayed by about two minutes.
73 de Dieter kx4y
Dieter K. Schliemann, kx4y - zs6bbh - hs0zcn
ARISS EchoLink audio feed team member
1803 Roseberry Drive, Scottsboro, AL 35769-3960, USA
Home Phone - (256) 259-3900
Cell Phone - (256) 599-0581 (only on when away from home)
IRLP node 4713, EchoLink node 47135
Skype user ID: zs6bbh
73 Ian G3ZHI
Why not link your local repeater to the internet?
http://www.qsl.net/g3zhi - many ham radio links
http://www.ukirlp.co.uk
G4NJI IRLP 5200 Echolink 135909
Rotherham simplex 145.2875mhz
Skype g3zhiian
VoiP 642109
Mobile 07876 234 674
Prenešeno s foruma yahoo groups echolink!
Vrni se na ECHOLINK
