Echolink 2.0.908 in požarni zid (firewall)
Moderator: S56CT
OdgovorNapisal/-a S56CT » 15 Sep 2007, 07:34
Končno so tudi avtorji programa echolink naredili korak naprej in omogočili lažje in prijaznejše instaliranje programa:
An important update to the EchoLink software is now available!
EchoLink Version 2.0.908 is available as a free download from the EchoLink Web site. We encourage you to upgrade to this version for your EchoLink Sysop node.
One of the important reasons to upgrade is a recent change to the EchoLink system that makes it more "firewall-friendly". In many cases, users operating behind Internet routers are now able to use EchoLink without having to make special changes to their router's configuration.
However, the "firewall-friendly" feature requires that Version 2.0 or above of the EchoLink software be running at both ends of the connection. If you upgrade your node to 2.0, more EchoLink users will be able to connect to your node without firewall problems, and vice versa.
To download and install Version 2.0.908, go to www.echolink.org and click "Download" at the left.
For more information about the Firewall Friendly feature, please see:
http://www.echolink.org/firewall-friendly.htm
Please do not reply to this message, as this mailbox is not monitored. For information about Support, please see the EchoLink Web site.
Thanks and 73
EchoLink.org
OdgovorNapisal/-a s55o » 16 Sep 2007, 04:05
Echolink iz šol, služb, vojašnic, zaporov ?
ni ovir :)
Prispevkov: 2596
OdgovorNapisal/-a S56CT » 16 Sep 2007, 10:13
Delo iz vseh navedenih lokacij je že prej omogočal proxy. Sicer malo zakomplicirano a vseeno je zadeva brezhibno delovala oziroma pri meni še vedno deluje, ker uporabljam dva echolinka z istega zunanjega IP-ja. Seveda je ta verzija programa odpravila kar nekaj težav pri tistih, ki se z usmerjevalnikom prvič srečajo.
Ovira torej še vedno ostaja licenca oziroma pri nas CEPT. To je osnovni pogoj, ki omogoča registracijo echolink prehoda ali uporabnika.
P.S: Pa menda ja ne misliš ponovno v šolo ali imaš namen iti v vojsko morda celo arest? No ja vsekakor se bomo slišali, če ne drugače prek proxy-a :D
Problem v Echolink
OdgovorNapisal/-a S56VGL » 08 Feb 2008, 22:28
Pozdrav vsem.,
Inštaliral sem si Echolink in vnesel porte v požarni zid in tudi pri T-2 so mi dali na nižjo varnosto.dprti vsi porti.imam naslednji problem.
Ko zaženem Firewall test mi napiše TCP ok,UDP 5198 in UDP 5199 failed,drugič v istem mi napiše da sta tadva UDP porta ok.
Včasih se lahko povežem na repetitor recimo Mrzlica,test server ali pa ker drugi echolink node.V mes imam ruter in tudi v njemu imam iste porte vnešene.
Lep pozdrav.
Tel.preko e-mail ali ZS.
Član Radiokluba S53APR
S56VGL
Prispevkov: 459
Pridružen: 11 Jul 2003, 13:58
OdgovorNapisal/-a S56CT » 08 Feb 2008, 22:50
Pozdravljen Luka!
Predvidevam, da imaš v lokalni mreži povezana dva ali več računalnikov in na routerju nastavljen DHCP - avtomatsko dodeljevanje lokalnih IP naslovov?
Ker si porte odprl/preusmeril točno za določen IP v lokalni mreži, moraš biti vedno kadar uporabljaš echolink povezan na router prek tega IP-ja, kar pa se očitno včasih ne zgodi, saj lahko DHCP server ta IP, za katerega so preusmerjeni porti, dodeli drugemu računalniku v mreži.
Tako ti test portov izpiše: "failed".
Vrni se na REPETITORJI
