Delo na 50 MHz
Delo na 50 MHz
OdgovorNapisal/-a S51U » 04 Avg 2006, 13:31
Pozdravljeni !
Glede na to, da imamo med seboj veliko strokovnjakov pričakujem, da bi namesto v medsebojno obtoževanje kdo porabil to energijo in delil te male skrivnosti velikih mojstrov, kot je recimo delo na 50 MHz ( veščine, triki .... ), delo na drugih obsegih, specifike le teh, kaj paziti - skratka neke poučne teme.
Prosil pa bi, če nekdo napiše nasvet, naj ga nato ne spluva 10. Vsi vemo vse in le tako pridemo do nekaterih zaključkov.
V temi "operatorska tehnika" sem pričakoval veliko več pobud in nasvetov kot pa 238731 prispevkov na temo QRZ ?...
Saj poznate tisto o oslovi senci.
Lepo vas vse pozdravljam.
S51U
Prispevkov: 371
Pridružen: 12 Jul 2006, 13:50
Kraj: JN75GX
OdgovorNapisal/-a s55o » 04 Avg 2006, 16:04
Čao!
Moje izkušnje na delu med I ctesti 6m. Med tekmovanji I postaje ne smejo delati pod 50.150, temveč samo višje (SSB) oz med 50.080-50.100, torej če nekdo kliče CQ ctest pod 50.150 oknom ne bo dobil veliko I zvez.
Torej tudi med npr Maratonom ZRS boste redko dobili I hama, ki vam bo odgovoril izven teh oken.
Še dodatek iz njihovih pravil:
Meeting "Contest" 1998; Rome 26/9/98
After the reunion done in Rome the 26th Semptember 1998, it is been decided, in order to don’ t cause disturbs to the normal DX traffic during the 50 MHz contests, organized in Italy, to adopt in definitive way, beginning from the 1.1.1999, the following way of regulametation:
It's strictly forbidden, for the competition, the execution of qso in the window of frequencies under 50150. Either in call or in answer and independently if they take place with stations of the same continent or not. (Update for the year 2000: For CW ONLY will be used also the band of 50080-50090)
The reports to pass, in all the competitions, they will be, like least requisite:
- the complete locator (6 digit);
- the progressive number.
It’s left to discretion of the organizers the capability to consider valid also qsos with incomplete locator (four digit) and the capability to add other groups of "reports" that they could be useful like multipliers.
The NOT ITALIAN stations are prayed, in the case that they must compare contraries behaviors to as communicated, to report the irregularity to the contest committee of the interested competition.
The foreigners stations, that want to participate to the competitions organized in Italy, they will should follow the same rules.
All the rules of the contests organized in Italy could be founded on the Six Italy internet web site at:
http://www.sixitalia.org
With the occasion, it is suggested, to the purpose of protect the DX traffic, that also other countries adopt the interdiction of the "Contest traffic" (to any level) in the band under 50150 MHz.
We hope that, an attempt of "good education" proposed from the Italian OMs, often criticized for their behavior, it finds collaboration and support in the interest of the activity on the band of the 50 MHz.
Prispevkov: 2599
50 MHz
OdgovorNapisal/-a s52ab » 04 Avg 2006, 20:58
Pozdravljeni
Moje izkušnje:
Pravzaprav nekih skrivnosti niti ni. Ko sem se "spravil" na obdelavo
50MHz področja, je bil to apsolutno prioritetni band, živel sem z njim.
Seveda je treba zadostiti osnovnim pogojem, da se sploh pojaviš na
tej frekvenci, vendar to danes sploh ni težko. Pri meni je bilo razen
FT7B, vse drugo, domače izdelave.
Pričel sem s cca 700mW (S52B), do končnih 30W (10W v anteni) HB9CV,
potrjeni vsi kontinenti, prek sto delanih DXCC (spisek na moji web strani)
mogoče koga to vspodbudi.
Že nekaj let nisem aktiven na tej frekvenci, to nedeljo pa mi je Roman
S52AS, prinesel FT817 in žični dipol (h.m.) sva raztegnila na brajdi pred
kletjo (1.8m up hi), pa poglejmo kaj se sliši :) :wink: :G, LA, SM, OH,
OH0, ES, LY, SP, DL, EA,S5,9A,....in to v cca 20minutah.. :) :D
Torej, kar korajžno na "magičnem" bandu :) :) :wink:
s52ab
Pridružen: 12 Mar 2006, 22:13
OdgovorNapisal/-a S57S » 05 Avg 2006, 08:18
Verjetno je Mario, ki ne bere rad prispevkov na temo QRZ, mislil opis 50 MHz banda nekako takole:
- specifike dela na TROPO, AU, FAI, MS, JT6, EME, robni pogoji DX dela,
- sezonska DX odpiranja, dvojni, trojni E-sporadiki, TEP,...
- potrebne antene in moč za resno delo na posameznih vrstah dela
- smotrnost stekiranja anten, potrebna ojačanja le-teh za dosego željenega cilja, ...
- problematika TV broadcasting QRM-a, omilitev le tega, kako, kdaj
- potreba po kvalitetnih sprejemnikih, koliko in do kam ...
Takšne stvari torej.
Manj pa, kako doklicati TO7C, medtem, ko ga kliče cela Evropa, pa še
Severna Amerika. Čeprav je naslov ''podforuma'' - Operaterska tehnika. To že znamo!
Na plano, strokovnjaki, torej ...
73, Aleksander, S57S
S57S
Prispevkov: 435
Pridružen: 10 Jan 2002, 02:00
Kraj: Golisce
OdgovorNapisal/-a S51U » 05 Avg 2006, 10:17
S57S napisal/-a:Verjetno je Mario, ki ne bere rad prispevkov na temo QRZ, mislil opis 50 MHz banda nekako takole:
Točno to Sandi - si kar lepo zadel vse točke ...
Upam na konstruktivne odgovore.
Zaenkrat 5 elementov in nekaj W, zveze pa bolj slabo :oops:
S51U
Prispevkov: 371
Kraj: JN75GX
moja skromnost...
OdgovorNapisal/-a s52ab » 06 Avg 2006, 15:19
Živijo...
Ja, vidim da nisem "na liniji" :)
Po mojih izkušnjah sodeč, je to tematika za OMse , ki so prešli 150
DXCC na 50MHz. Vsekakor pa zelo zanimiv poziv strokovnjakom,
da povedo kaj o tem kar pričakujeta 8) Da bo le podkrepljeno z
prakso in izkušnjami. Z zanimanjem spremljam nadaljevanje....
In še moj predlog: odprite posebno stran na forumu na temo 50MHz...
to področje je pod "Operatersko tehniko", nekako prikrito...
s52ab
Re: moja skromnost...
OdgovorNapisal/-a S51U » 06 Avg 2006, 21:35
s52ab napisal/-a:Živijo...
Bravo Jože ! ! !
Točno to sem hotel sprovocirati !!!!
Fantje, mi vsi vemo vse - znanje je potrebno deliti z ostalimi.
Saj nimamo kaj skrivati.
73 !
S51U
Prispevkov: 371
Kraj: JN75GX
66 tips
OdgovorNapisal/-a s52ab » 25 Avg 2006, 21:54
Pa naj bo za začetek, ko ni domačih strokovnjakov :wink:
http://vk2six.com/66_tips_for_6.pdf
http://vk3six.com/gpage4.html
Upam, da je z linki OK... 8)
s52ab
OdgovorNapisal/-a S51U » 26 Avg 2006, 09:28
Hvala Jože !
Prvi link je v redu, drugi pa ne dela...
Hvala za 66 nasvetov !
S51U
Prispevkov: 371
Kraj: JN75GX
Link
OdgovorNapisal/-a s52ab » 26 Avg 2006, 21:38
Da, res je, sem verjetno kaj narobe prepisal... :)
No, ne bi smelo biti težav, greš na Google, pa VK3SIX h.p....etc
Se splača pogledat. Tudi sam sem veliko delal na tem za različne
smeri antene. Po nasvetu S57A in S57U : na geodetsko upravo, pa
zemljevidi, TA....ja, veliko dela (!), vendar se na koncu splača, če si
pedanten pri vnosu podatkov...
Poglej si pri njem (VK3SIX), tudi jaz sem si izdelal nekaj takega....
vendar je projekt "50MHz" pri meni, že pred nekaj leti končan...
s52ab
Re: Link
OdgovorNapisal/-a S57XX » 13 Jul 2007, 07:56
Morda bo v povezavi z delom na 50MHz koga zanimalo tole:
http://www.uksmg.org
Še posebno pa tole:
http://www.uksmg.org/archive.htm
Nekaj praktičnih nasvetov za antene pa tule:
http://www.mydarc.de/dk7zb/start1.htm
OdgovorNapisal/-a S57Q » 13 Jul 2007, 11:41
Pozdrav vsem ljubiteljem "magičnega" obsega !
Zakaj sploh pišem ?
Včeraj sem po "nesreči" naredil QSO z Sandijem, S57S, ki se je aktiviral tudi na 6 m. Ko sem gledal dnevnik nazaj, sem opazil, da so bile zadnje 4 zveze (USA) narejene 11.7. lansko leto. Imam, bi rekel maksimalno dobro opremljeno lokacijo za 6 m delo, ni pa pravega časa še za ta obseg.
Vendar, ko smo dobili ta obseg, sem nabavil transverter (5 W) in ga priključil na IC-202. Najhitrejša nabava antene je bila 3 el. yagi, TV ANT za drugi kanal (v Prekmurju jih je kmalu zmanjkalo v trgovinah). Vse skupaj sem priključil in poklofal vse kar se je dalo - evidenc ne vodim (čakam penzijo). Brez clustrov, chatov....izkušenj pa tako ni imel še nihče tedaj. Izkušnje so kar kmalu prišle z delom na bandu.
Hočem povedati, da sem z ubogim set-upom naredil veliko več, kot sedaj z dobro tehniko, informacijah na clustru, chatu.....
Enostavno, treba se je pojavit s tistim kar imaš, pa čeprav samo pol antene - bolje špila kot ugasnjena postaja, kaj kmalu pa postane jasno, zakaj je 6m "magic band".
Do poslušanja !
Lep pozdrav, Tone - S57Q
S57Q
Prispevkov: 266
Pridružen: 11 Maj 2003, 09:01
50 MHz
OdgovorNapisal/-a s52ab » 29 Jul 2007, 22:23
Seveda, Tone
treba se je pojavit in delat...
Pred slabim letom sem nekaj preprostega napisal o tem,
na to temo,vendar, kot sem razumel odgovor - "to že znamo"...!
Mogoče sem pa napačno razumel...!??...mogoče...
Sam s primitivno opremo, malimi močmi, brez clustra...etc - preko
100 DXCC v dokaj kratkem času...seveda upoštevajoč marsikaj,
vendar se to pridobi z delom in ne samo z razpravo...(glej mojo
www - 50 MHz....hi..!) :)
Osebno bi me zanimalo, koliko je kdo uspel narediti v S5 na 50 MHz,
in s kakšno opremo...Postoje o tem kakšne evidence ?
s52ab
OdgovorNapisal/-a s55o » 29 Jul 2007, 23:40
Poskusi za kaj je delano pogledati na www.slovhf.net oz bolj točno na http://www.slovhf.net/rang.php?band=50%20MHz
Tam dobiš liste večinoma koliko je kdo naredil česa in podobno.
6m je pač tak band...treba je bit tam in to je to.
Prispevkov: 2599
50 MHz evidence
OdgovorNapisal/-a s52ab » 30 Jul 2007, 11:27
Ja, odlično urejeno !!
Hvala Boštjan !
Registracija pa ni uspela...!?... hi...
s52ab
