Danes je 22 Apr 2019, 23:06
 Naslov prispevka: FT8 V2.0rc4 je tu.
OdgovorObjavljeno: 13 Nov 2018, 17:48
Pridružen: 18 Maj 2001, 01:00
Prispevkov: 83
Kraj: yes
K1JT je ravno objavil ze-skoraj-zares WSJTX V2.0. ( Candidate release WSJT-X 2.0.0-rc4)
Ta verzija naj bi ze bila skoraj uporabna, cez en mesec pricakujemo V2.0.0 brez rc značke.
Glavna novost: ni več podpore za "stari" FT8: nova verzija podpira samo novi 77 bitni FT8.
Priporočilo: kar na običajnih FT8 QRG klofajmo, malce zmede bo, dokler ne bomo vsi na verziji 2.0.
No, na prvo pritožbo: "nič ne dekodira" je odgovor: seveda ne, če si prvi z V2.0 in vsi ostali na stari verziji.
In podpriporocilo: klicite 77 bitni FT8 CQ nad 2 kHz.
Skratka, kak mesec ali dva bo zmeda, ker se bosta prekrivala novi in stari FT8 protokol: Program za novi ne bo razumel starega,
stari ne bo razumel novega.
Sam bom poganjal vzporedno oba, vsakega v svojem direktoriju in s svojimi nastavitvami.
73 Iztok, s52d
Originalna najava:
A fourth candidate release ("RC4") of WSJT-X 2.0 is now available for
download and use by beta testers.
Changes in RC4 relative to RC3 include the following:
- Fix the "cannot open file fort.81" bug
- Avoid too many redirect loops related to openSSL support
- Fix the auto-generated messages for nonstandard callsigns
- Remove all support for the legacy FT8 protocol
- Disallow selecting MSK144 with RTTY or Field Day messages active
- Correct and expand support for color highlighting decoded messages
- ESC key aborts a QSO, clears DX Call, and selects Tx6
- Disable "nextCall" procedure for RTTY contest; it still needs work
- Correct a flaw in handling MSK144 Sh messages
- Prevent Fox from inadvertently toggling Tx 1st/Even
- Re-organize the Fox/Hound/Contest selection boxes
- Improve the validators for contest exchange boxes
- Disable Tx after 5 minutes of no mouse movement
- Remove end-of-line AP info when using contest messages
- Fix the Sent and Rcvd exchanges sent to N1MM+ and ADIF log
- Don't auto-log a QSO with incomplete exchange info
- Fix two sequencing flaws after double-clicks on a decoded msg
- New facilities for Contest and Fox-mode logging
Be sure to invoke "Settings | General | Colors | Reset Highlighting"
on your first program start with this version.
The "Quick-Start Guide to WSJT-X 2.0" has been revised and extended. If
Be sure to read this entire guide before using RC4:
http://physics.princeton.edu/pulsar/k1jt/Quick_Start_WSJT-X_2.0.pdf
As described in the Quick-Start Guide, at this time we recommend moving
MSK144 activity back to the standard 6-meter working frequencies: 50.360
MHz in IARU Region 1, 50.260 in Regions 2 and 3. We recommend also
starting to use the v2.0 FT8 protocol in the conventional FT8 sub-bands
? for example, dial frequencies 7.074 and 14.074 MHz on 40 and 20
meters. Inevitably this will cause some initial confusion: users of
v1.9.1 and earlier will be unable to decode transmissions from users of
v2.0.0-rc4, and vice-versa. To minimize this cross-protocol interference
we suggest initially using the RC4 release at audio Tx frequencies 2000
Hz and higher. As more users upgrade their software to RC4 or later,
activity can gradually move downward in audio frequency. By December 10
or very soon afterward, everyone should upgrade to the full WSJT-X 2.0
general availability (GA) release.
Download links for RC4 on Windows, Linux, and macOS can be found on the
WSJT-X web page http://physics.princeton.edu/pulsar/k1jt/wsjtx.html
A one-hour "FT8 mock contest" will be held next week: November 20,
0200-0300 UTC (that's Monday evening, Nov 19, NA time). Watch for a
separate announcement with more details.
We look forward to your feedback on WSJT-X 2.0-rc4. Reports should be
sent to the wsjt-devel email list, wsjt-devel@lists.sourceforge.net. You
must subscribe to the list in order to post there.
-- 73, Joe, K1JT (for the WSJT Development Group)
 Naslov prispevka: Re: FT8 V2.0rc4 je tu.
OdgovorObjavljeno: 14 Nov 2018, 08:03
Prispevkov: 83
Kraj: yes
Prve izkušnje z WSJTX 2.0.0-rc4 so lepe.
Vecja zoprnija je, da ne deluje pravilno seznam ze delanih postaj.
Manjsa je, da je ob zagonu programa avtomatika izklopljena.
Kar nekaj postaj je QRV z novim FT8 protokolom, ponavadi nad 2 kHz, seveda se jih najde povsod.
Koncno tudi posebni znaki.
No, decembra bomo vsi nadgradili in delali samo z novim 77-bitnim FT8.
Januarja bo prvi kontest, kjer se bodo stele FT8 zveze, to bo zanimivo.
73 cu
Iztok, s52d
OdgovorObjavljeno: 14 Nov 2018, 20:41
Pridružen: 02 Maj 2013, 21:03
Prispevkov: 163
Meni zadnja vezija nič ne dekodira. Reset barv sem naredil. Ostalo nisem nič spreminjal. Db meter miga, CAT dela, PTT dela. Uro sem tudi sinhroniziral ali ne? Imam program "atomic time".
OdgovorObjavljeno: 14 Nov 2018, 23:24
Prispevkov: 83
Kraj: yes
Verjetno nic ne dekodira, ker ni nikogar, ki bi oddajal s 77 bitno verzijo.
Probaj se kak drug band.
Kako pa kaj slap? Oziroma spektrogram? Stari FT8 moras videti.
Iztok
s51un napisal/-a:
OdgovorObjavljeno: 15 Nov 2018, 12:28
Pridružen: 09 Feb 2007, 01:22
Prispevkov: 109
Kraj: SEŽANA
Pozdrav Iztok !
Citiram:
Ali spadajo sem tudi , n.pr.: YL100 x in se nekaj podobnih,
vedno so prikazani kot YL/100x, ti pa so zame enigma.
Nikakor jih nemorem spravit v okno, razen
po daljši poti , copy-paste, je pa nerodna in neuporabna.
Je kakšna bolj elegantna resitev ?
ZA info uporabljam JTDX v 18.1.100 zadnja verzija.
LP!
73 de Slavko !
OdgovorObjavljeno: 15 Nov 2018, 18:25
Prispevkov: 83
Kraj: yes
Do nove, 77-bitne verzije je bil WSJTX omejen samo na obicajne znake.
Novi FT8 dovoli malce vecji razpon, recimo
DF1000ZEIL sem mirno poklofal brez kakih bliznjic.
Za taksne znake uporabla posebne kode, ki si jih program shani.
Dokler ne ve, kdo se skriva za kako kodo, je znak oznacen z <...>.
Zaenkrat ni mozna zveza med dvema posebnima znakoma: OG55W je ostal brez QSO z DF1000ZEIL.
73 gl
Iztok
s57yx napisal/-a:
Pozdrav Iztok !
Citiram:
Koncno tudi posebni znaki.DF1000ZEIL
LP!
OdgovorObjavljeno: 15 Nov 2018, 21:12
Prispevkov: 163
No ja sem si kar mislil, da ni združljivosti za nazaj. Do sedaj sem naredil 3. QSO. 73 vsem, ki so not padli :-).
