ECHOLINK in Nastavitve
Zivijo! Male tezave za velike ljudi.
Firewall Test Results: FAIL
The test successfully connected to the EchoLink server on TCP port 5200. This means that your system's TCP configuration is correct for use with EchoLink.
The tester was unable to communicate over UDP. If you have Internet security software installed, be sure it is configured to allow EchoLink to access the Internet. If you have a router or firewall, be sure it is not blocking UDP ports.
There appears to be a router between this computer and the Internet. A router normally requires special configuration for use with EchoLink.
For more information, click the Help button above, or see the Firewall Solutions page on the EchoLink Web site.
Echo link je uspesno registriran in bi naj vse delalo.
Doma uporabljam Optiko od T-2 in domaci router, na katerega je ta PC priklopjen, ki pa ni nic zblokiran oziroma da bi imel vklopljen pozarni zid.
Kaka ideja?
Lp Egon
Kaka ideja?
Lp Egon
