Vprašanje oz i.pomoč
Pozdravljeni vsi.
Imam namreč eno težavo,namreč ko hočem pogledati na spletni strani Ken Lab Kenwood zastopnik za SLO.pod opcijo radioamaterske postaje-Professionalne postaje-Kenwood digital,mi namreč odpre stran na kateri dobim tole :
Server Error in '/' Application.
The requested operation could not be completed due to a file system limitation
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.IOException: The requested operation could not be completed due to a file system limitation
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[IOException: The requested operation could not be completed due to a file system limitation
System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) +7717004
System.IO.FileStream.WriteCore(Byte[] buffer, Int32 offset, Int32 count) +7478543
System.IO.FileStream.FlushWrite(Boolean calledFromFinalizer) +33
System.IO.FileStream.Dispose(Boolean disposing) +86
System.IO.Stream.Close() +17
System.IO.StreamWriter.Dispose(Boolean disposing) +149
System.IO.StreamWriter.Close() +17
CMS.Logger.PublishException(Exception ex) +637
CMS.inc.CategoryView.Page_Load(Object sender, EventArgs e) +243
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Control.LoadRecursive() +141
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.5448; ASP.NET Version:2.0.50727.5456
upam,da vam to kaj pomaga.To se mi dogaja na 3 računalnikih,ki majo različne win,in konfiguracija,pregledal sem defragmen,netframework 2.0. pa različni brskalniki.
Upam,da bo tudi za koga prav prišlo odgovor.
Source Error:
Stack Trace:
