VK9DWX, Willis Is.
Moderator: S55DX
VK9DWX, Willis Is.
OdgovorNapisal/-a S50U » 05 Sep 2008, 22:55
S5 mladinci dejte se prijavit za tole VK9DWX veliko reč, zadnji rok za prijavo je 15 september. GL Danilo, S50U
The crew of VK9DWX invites two young amateur radio operators who have a passion for DXing and contesting to take part in the DXpedition to Willis Island (http://www.vk9dwx.de/): the first one from 6 to 19 October, and the second one from 15 to 28 October. They can reside in any country in the world and must (1) hold a valid amateur radio licence in their country, (2) have some experience in working pile-ups and (3) be between 18 and 29 years of age. For qualification send an e-mail to contact@vk9dwx.de which must include an essay of 500 words minimum (in English) describing how you got started in ham radio, who your Elmer was and why you should be selected for this DXpedition opportunity. Please include also you full name, callsign and home address. The VK9DWX crew will pay for all expenses except your flight from your home to Cairns, Queensland, Australia. The deadline for applications is 15 September.
https://s50clx.si
S50U
Prispevkov: 578
Pridružen: 08 Avg 2002, 00:05
Kraj: Cíerkna
Re: VK9DWX, Willis Is.
OdgovorNapisal/-a S50U » 26 Sep 2008, 12:22
S50U napisal/-a:S5 mladinci dejte se prijavit za tole VK9DWX veliko reč
22 prijav, škoda da med izbranimi ni nobenega iz S5 :cry: Zraven gresta Josh W4WJF & Rhy ZS6DXB. CUL Danilo, S50U
Twenty-two applications were received and the selection has been made. The two young amateur radio operators who will join the VK9DWX DXpedition to Willis Island are William Joshua (Josh) Fischer, W4WJF (21 years old) on 6-19 October and Rhynhardt (Rhy) Louw, ZS6DXB (25 years old) on 15-28 October. Meanwhile, the preparations are entering the final stage and a four-men vanguard is flying to Cairns to take care of all necessary work. Further details, including information on how contribute to the expedition, can be found at http://www.vk9dwx.de/
https://s50clx.si
S50U
Prispevkov: 578
Kraj: Cíerkna
OdgovorNapisal/-a S50DX » 27 Sep 2008, 13:33
Škoda, da sem nekaj let prestar in nekaj k€ premalo v denarnici... :roll:
Prispevkov: 468
Pridružen: 23 Apr 2003, 14:46
OdgovorNapisal/-a s55o » 30 Sep 2008, 22:54
Zanimiva zadeva, ampak karta do VK je draga...
OdgovorNapisal/-a S51AY » 09 Okt 2008, 13:27
Ampak kljub temu so danes začeli s klofanjem. GL pri "streljanju" !
OdgovorNapisal/-a S58F » 16 Okt 2008, 07:53
S51AY napisal/-a:Ampak kljub temu so danes začeli s klofanjem. GL pri "streljanju" !
Včeraj cca. 45 min pred mojim *sunset* sem jih z *muko* odklofal na 80m/SSB...poslusali so skoraj preko celega DX okna (3790.0 - 3800.0)..najbolj sovrazim pa tako imenovane *HAM policaje*ki non-stop nekaj komentirajo na simplex freq...ko nekdo začne ni konca ne kraja!!
GL S58F
"LIFE IS TO SHORT TO BE QRP"
EX-S57LWE
S58F
Prispevkov: 222
Pridružen: 14 Mar 2003, 23:24
Kraj: GOČE-VIPAVA
OdgovorNapisal/-a s52w » 16 Okt 2008, 09:20
Sicer me ne briga, ampak vseeno.
Ne razumem zakaj morajo poslušati ravno med 3790 in 3800 ? Je to v redu ?
73 Damjan S52W
Prispevkov: 542
Pridružen: 07 Nov 2004, 16:38
OdgovorNapisal/-a S51AY » 16 Okt 2008, 09:29
Ja veš Erik, to nekateri samo malo izgubijo živce, ko morajo stalno nekoga opozarjati, naj kliče UP. Dokler enemu to dopovejo, DX-a predvsem na nižjih bandih nimaš šanse slišati. No, ko tisti "izgubljeni" končno skuži in se umakne s TX UP, je nekaj sekund možno delati, potem se pojavijo spet trije novi "padalci" in spet gre vse znova in znova... Potem kateri izgubi živce, pa je "veselica". Vsakemu se zgodi, da pozabi stisniti Split tipko, takim je dovolj le kratko opozorilo, ki je koristno tako zanj kot za ostale. Problem so tisti, ki mislijo, da "split" pomeni mesto pri Dubrovniku, o splitu še niso nikoli slišali, ampak "kaj si nor, takega DX-a je treba poklofati !". Problem ni v policajih, ampak v nepoučenih "padalcih" in namernih sfrustriranih motilcih. Tudi to prinese liberalizacija radioamaterskih izpitov, nekaj je pa tudi v glavah...
Na 80m sem imel srečo, da sem ga pričakal, ko se je pojavil. Takrat je bila situacija ŠE mirna, pa je šlo na drugi poziv. Prve 4 dni sem pustil, da se duhovi malo pomirijo, zdaj pa juhuhu, imam ga na 5 bandih (80/40/30/20/15)...
OdgovorNapisal/-a S50U » 25 Okt 2008, 16:17
S50U napisal/-a:tole VK9DWX veliko reč
V ponedeljek pričakujejo poslabšanje vremena z močnejšimi vetrovi, zato bodo kamp začeli pospravljati danes sobota 25. oktobra okoli 22 GMT torej nekaj prej od predvidenega. Par ur je še da jih ulovite na kakšnem bandu z tremi postajami delajo v WW SSB tekmovanju ter eno na WARC-ih. GL Danilo, S50U
The Willis Islands Group, Mid Isl. Thursday, October, 25th
Due to heavier winds to be expected on Monday we have to take down the complete camp tomorrow on Sunday October 26th and transport all equipment to the Floreat. That means that we will stop radio operation latest on October 25th at about 22:00z. We want to have a controlled shutdown and a secure trip back to Australia mainland for all members and all of the equipment. Therefore we have to leave earlier as planned. We will take part in the CQWW SSB Contest for the first 24 hours with three stations. The remaining stations will be still available for WARC operation. We did the last onlinelog update for now. This includes all QSOs till 25.10.2008 00:00z (before the contest). We will put all QSOs to the online log when we are back home. More information will be available after our return to Australia. Vy 73s VK9DWX team
https://s50clx.si
S50U
Prispevkov: 578
Kraj: Cíerkna
OdgovorNapisal/-a S55DX » 11 Feb 2009, 13:25
Kot kaže, smo le nekoliko bližje karticam. 4.2.2009 so dobili sporočilo od tiskarja, da jim je poslal kartice. Prispele naj bi že pred minulim vikendom, tako da jih bodo lahko začeli nemudoma pošiljati.
Today we got the message that the printer has sent the QSL cards to us! They should arrive before the weekend so we can immediately start with sending them!
73s VK9DWX team (04.02.2009)
73 de Milan, S 5 5 D X
S55DX
Prispevkov: 615
Pridružen: 08 Jan 2003, 20:56
Kraj: Jezero (JN75fx)
OdgovorNapisal/-a s55s » 11 Feb 2009, 17:17
Tako je OM Damjan S52W, napisal.
Nekoč, ko smo bili ''C'' klasniki, sploh nismo smeli povohat na 3500-3510 in 3790-3800 MHz. Je bil pač DX band.
Sedaj smo pa vsi enaki kot v ''prakomunizmu'' (Marx).
de Dan
http://www.qrz.com/db/s55s
Member of S59GCD Lasko
s55s
Prispevkov: 483
Pridružen: 08 Sep 2006, 14:42
Kraj: JURKLOŠTER JN76QC34DK
OdgovorNapisal/-a S55DX » 13 Feb 2009, 15:49
Kartica je bila danes v poštnem nabiralniku. Vsaka čast!
S55DX
Prispevkov: 615
Vrni se na Ekspedicije in DX
Po forumu brska: 0 registriranih uporabnikov in 64 gostov
