Uporaba DXclustra v WW
OdgovorNapisal/-a s52w » 12 Dec 2007, 17:10
Hudi časi prihajajo v WW tekmovanjih. Še dobro, da obstoja assisted kategorija :)
http://lists.contesting.com/_cq-contest ... 00208.html
73 Damjan S52W
Prispevkov: 542
Pridružen: 07 Nov 2004, 16:38
OdgovorNapisal/-a S51AY » 12 Dec 2007, 17:33
Dobro je to. To so dobri časi za poštene in hudi za goljufe... :D
OdgovorNapisal/-a S54O » 12 Dec 2007, 19:02
Še ena zelo zanimiva analiza od K1TTT. Vredna branja!
73 de Boris S54O
P.S. "Popolni zločin" ne obstaja :-)
WOW! I knew we were getting LOTS of spots this weekend, but this is even above what I expected. Last year in CQWW SSB I recorded 48k spots. This year it was up to 54317 spots in the database. And during much of this time my node had over 200 users, 230+ at one point, last year i think i was topped out at about 120 or so. Much of the weekend there were over 1000 spots/hr, peaking over 1600 spots/hr Sunday.
Most spotted stations:
DX Count
V26B 569
C50C 542
1A3A 537
HC8N 531
6Y1V 420
TS6A 369
PJ4E 353
AO8A 344
J3A 332
CQ9K 296
WP2Z 295
FY5KE 286
DR1A 271
VP5T 261
T70A 260
PJ2T 260
Busiest spotters:
Spotter count
AA3B 1479
S52W 604
NQ4I 459
W1NT 417
RK3DZB 408
KS0T 389
K4MM 385
N2RM 370
RL3A 352
DJ1AA 340
W3LPL-4 334
K3CT 325
Cheerleader report
spotter dx Spots Total Pct
BY1DX BY1DX 73 73 100
KA2AEV V26B 68 68 100
4Z5NU 4X0V 47 50 94
BG7IEU BG7IEU 34 35 97
EA5CHA EG5CMC 30 30 100
G0GFQ G2B 28 28 100
MI3CMR MI0JZZ 22 29 75
VE3KF VE2Z 21 21 100
DO7GG DR5A 20 27 74
DL0NG CT9L 20 20 100
Single spotter spots:
DX Total All DXSummit
1A3A 537 36(6%) 16(2%)
C50C 542 34(6%) 14(2%)
PA1WLB 46 31(67%) 31(67%) more below!
HC8N 531 27(5%) 3(0%)
HP1AVS 60 25(41%) 25(41%) more below!
TS6A 369 19(5%) 8(2%)
EA7RU 59 18(30%) 17(28%) more below!
F5KKD 46 15(32%) 4(8%)
CX9DX 34 15(44%) 15(44%) more below!
RK3QWW 39 14(35%) 13(33%) more below!
CC0Y 95 14(14%) 4(4%)
3DA0WW 202 13(6%) 5(2%)
Remember on this part that a high percentage of spots by 'single spotters' for non-rare expeditions is often a sign that the spotter callsigns are being faked in some way. Big expeditions to really rare places often get high percentages of dx hunters who only spot them to brag that they worked them, then turn off their radio... High percentages for expeditions or really rare stations are normally in the 20-30% range.
Now what is interesting about this is that I do the statistics above and the search for suspicious looking patterns below separately... it just happens that both searchs turned up the same 5 stations above by different methods. Then, as a 3rd input I also search the DXSummit spot inputs separately, and find more on the same stations.... so here we go.
Unfortunately this is WAY too big to show all the details here. So I am going to summarize here more than usual and you can download the raw data from my web site later. It seems that either there is a new batch of spotting cheaters or the ones that have been out there have forgotten what showed up last year. What you can do to help is to put pressure on those who use these obvious attempts to cheat and get them to play nicer with others.
PA1WLB (as an example of the data I'll leave this one complete and summarize the rest)
Spotter Freq Comment
KB4RTY 14306.5 TEST STRONG 59
OK1WSD 14267.5 TNX WW TEST
PA7JWC 14306
NY2N 14277 CONTEST 59
YO7HJK 14254 59 strong CONTEST
RK6DF 14308.5 contest ww
WB4DF 14306.5 TEST
W3ER 14291 N4RJ-@: 59 CONTEST
KB4FG 14286.5 strong in NA
YO7AAS 14254 STRONG COPY CONTEST
N2MD 14306.5
KB4JKL 14277 59 CONTEST
KB4ON 14277 TNX CONTEST 59
KI4RF 14306.5 59 oppy in NA
WB1SD 14306.5 BIG SIG CONTEST
RX9HG 14306 tnx test ww ssb
N2FG 14286.5 59 contest
W3YSD 14254 tnx TEST
N2ER 14254 59 CONTEST
RK6YT 14286.5 59 contest strong
KB4WS 14268 STRONG SIG CONTEST
KB4RF 514254.7 CONTEST CQ CQ
IV3SDF 14306 Contest 59
K2HE 14306.5 59 tnx cont
N2DS 14268 TNX 59 14
JA3FDG 14306 59 ww ssb contest
K9HJ 14286.5 59 TEST
V21S 14259 contest
EA8BNM 14254 tnx TEST
RW9TY 14254 CQ CQ CONTEST
K2DS 14254 59 test ww
Observations: lots of similar comments. Lots of integer or '.5' frequencies, obviously not a common pattern on spots.
Call spot checks:
KB4RTY - tech plus, whats he doing on 20m
WB4DF - not issued
KB4FG - NOT ISSUED
KB4ON - NOT ISSUED
WB1SD - NOT ISSUED
W3YSD - NOT ISSUED
KB4RF - NOT ISSUED (SURE LIKES KB4 PREFIXES DOESN'T HE?)
In this case there is not much info on dxsummit for these spots. They may have been entered directly into the #cqdx irc channel, or from some other source that dumped them into dxsummit or #cqdx.
HP1AVS (ok, i'll leave this one full size also since there is dxsummit data for him)
LV5V 28430 cq ww
W0ETT 28463
J37T 28463
W5OM 28463
CQ9K 28463
XE1VY 28463
EA8AAJ 28463
CA1UGE 28463
AA1K 28463
CE1KR 28463
ZX2B 28500
LS2D 28434 CQWW
HK3TU 28462
VP8NO 28462
PY2ZY 28460 GOOD SIGNAL
KD5ZAT 28463
PU1CCC 28500
8P6EX 28463
PY2DXX 28500
CE3P 28500
CX2DDP 28490
LO7D 28460
HC8N 28463
C50C 28463
LR2F 28460
Observations: ALL integer frequencies! VERY strange. Almost no comments, not unusual during a contest. Lots of well known calls in this list of spotters, including some rare dx and expeditions, now that is strange.
This is a group of spots for him from DXSummit, note the same IP address for all the spots from different spotters around the world!
LO7D 28460 190.32.217.79
CX2DDP 28490 190.32.217.79
CE3P 28500 190.32.217.79
PY2DXX 28500 190.32.217.79
PY5WH 28500 190.32.217.79
PU2MJU 28500 190.32.217.79
ZX2B 28500 190.32.217.79
PU1CCC 28500 190.32.217.79
PY2ZY 28460 GOOD SIGNAL 190.32.217.79
CE1WNA 28480 signal 5-9 190.32.217.79
LV5V 28430 cq ww 190.32.217.79
LS2D 28434 CQWW 190.32.217.79
LR2F 28460 190.32.217.79
HK3TU 28462 190.32.217.79
OA4AHW 28462 190.32.217.79
VP8NO 28462 190.32.217.79
HC8N 28463 190.32.217.79
NP2B 28463 190.32.217.79
HK3Y 28463 190.32.217.79
V26B 28463 190.32.217.79
C50C 28463 190.32.217.79
WD0M 28463 190.32.217.79
J3A 28463 190.32.217.79
W5ZO 28463 190.32.217.79
CA1UGE 28463 190.32.217.79
8P6EX 28463 190.32.217.79
KD5ZAT 28463 190.32.217.79
N0KE 28463 190.32.217.79
W0ETT 28463 190.32.217.79
J37T 28463 190.32.217.79
W5OM 28463 190.32.217.79
KC2PCR 28463 190.32.217.79
XE1VY 28463 190.32.217.79
CQ9K 28463 190.32.217.79
CE1KR 28463 190.32.217.79
EA8AAJ 28463 190.32.217.79
VO1MP 28463 190.32.217.79
VE3BDN 28463 190.32.217.79
VE2Z 28463 190.32.217.79
AA1K 28463 190.32.217.79
and if there is any question left, that ip comes back to:
owner: Cable & Wireless Panamaownerid: PA-CWPA1-LACNICresponsible: Networks Operationsaddress: Via España, Torre Bco. Nacional, 1, address: 083400659 - Panama - country: PA
EA7RU
Single spotter spots were kind of ordinary looking. Though split spots all used a similar 3 digit frequency without 'qsx' which for computer loggers is rather odd these days.
DXSummit spots from:
EC7ADZ,EA7HZ,EA7CTE,EA7CPL,EA7HZ,EC7DXU,K1WAC,K3RE,F5OLT,IK0HJU,JA1CTE
DL1KQ,UR5FLT,EA7HZ,KA1GF,WP4SF,AA2C,KA4RE,WA3OP,K2PE,KI2L
all came from 85.57.0.192
address: Parque Empresarial La Finca
address: Edificio 9
address: Paseo del Club Deportivo, 1
address: 28223 Pozuelo de Alarcon
address: Madrid, Spain
F5KKD
most spots came from F5MZN-3 node, including users k5ya,w8zr,ja2pac,jr5vhu,gm3tt,w4is,ua4lw,hg1s, and n5au. ALL had comments, mostly saying zone 14 or 'cqww', both of which are rarely used by real spotters.
Spots from DXSummit:
F2MA 21252.5 cq ww 82.121.64.136
W4JI 21214.5 Booming NA 82.121.64.136
N4DL 14330 Booming NA 82.121.64.136
W7WA 14330 zone 14 82.121.64.136
which of course is from
address: FRANCE TELECOM/SCR
address: 48 rue Camille Desmoulins
address: 92791 ISSY LES MOULINEAUX CEDEX 9
address: FR
CX9DX
Another one with all integer frequencies. The only comment from 3 different spotters was "CONTES".
DXSummit spots from
DL1H,W1ZT,DR5T,CO8U,CX2ABP,PY2AA,DL1Q,W3ED,W6KM,NE0DX
NONY,WA3KKM,N3YA,K3CT,W7SW,NA3D,AB2DE,N7ON,KQ3F,K5TR
GT6Y,EB5TR,JH7RTO,D40HP
All came from IP: 190.132.128.158
owner: Administracion Nacional de Telecomunicacionesownerid: UY-ANTA-LACNICresponsible: ANTELDATA ANTEL URUGUAYaddress: Treinta y Tres, 1418, P.3address: 11000 - Montevideo - country: UY
RK3QWW
Lots of "CQ WW" comments. Comments included with almost all spots including saying what antenna he was using and direction he was beaming at the time. Got spotted by P51AC which was interesting.
DXSummit spots from around the world from IP 83.149.24.107
address: Oleg A. Yurlov
address: 115035 30, Kadashevskaya emb.
address: Moscow, Russian Federation
3B8GT
Why?? Not rare enough to start with? All integer frequencies... "59" comments on several spots from different spotters.
must have been a dialup number as the DXSummit ip address kept changing, but they all came back to:
OrgName: African Network Information Center
OrgID: AFRINIC
Address: 03B3 - 3rd Floor - Ebene Cyber Tower
Address: Cyber City
Address: Ebene
Address: Mauritius
A52AM and also A52AN
WHY??? Most spots in this small group had comments "ww".
OK2MD,JH6FGT,W6GFT,W7HG,OM5EW,JH6FRT,W6GFT,UA3DER,OH2DR
came from IP 202.55.191.40
netname: SKYCC
descr: SKYCC, VoIP and ISP, Ulaanbaatar, Mongolia
country: MN
Others:
Why do these relatively rare places think they need to fake spots for themselves???? Just call cq and with all the spotters out there you will get spotted many more times by them without breaking rules or wasting time playing on the internet!
A61HH - Again, this one hd most comments saying "CQWW" or "CQ WW", or one just "WW".. all upper case as opposed to others that are often mixed case. IP address comes back to:
org-name: Emirates Telecommunications Corporation
org-type: LIR
address: Emirates Telecommunications Corporation - Etisalat
P.O. Box 1150
Dubai
United Arab Emirates
There was a spotting competition in China from the looks of it, all of these had suspicious groups of spots:
B7M, BA4T, BX5AA
Others with similar patterns that were obviously fake include:
CV5D, F4FLQ, I4ABF, IZ2DPX, IZ5ICH, RX1CQ, XE1CQ
I expect the log checkers will ask for the data again this year like they have the last couple years. If you want to do your own analysis or see if you have been flagged by any of my checks and just didn't make the hit parade listed here you can download the excel and access files, as well as the raw data for this summary at:
http://www.k1ttt.net/logs/2007cqwwssb_spots.zip
Just please don't ask me to explain it all to you, if you don't know how to use complex access queris or excel or how to trace ip addresses I don't have time to explain it all to the world.
S54O
Prispevkov: 227
Pridružen: 02 Jun 2003, 13:35
Vrni se na Tekmovanja KV
