SAQ 17.2kHz - sprejem oddajnika SAQ Grimeton
OdgovorNapisal/-a S56FC » 08 Jul 2010, 06:02
Jožetov prispevek o sprejemu oddajnika SAQ Grimeton (Alexsanderson alternator)
objavlja http://www.southgatearc.org:
SAQ 17.2kHz transmission video
Joze S52AB reports having received very good signals during Sunday's SAQ transmission, and has produced a YouTube video showing the results.
73 Jurij, S56FC
S56FC
Prispevkov: 20
Pridružen: 29 Maj 2007, 19:04
Kraj: LJUBLJANA
Re: SAQ 17.2kHz - sprejem oddajnika SAQ Grimeton
OdgovorNapisal/-a S52AS » 24 Jun 2014, 08:51
SAQ TRANSMISSIONS ON JUNE 29TH, 2014 AND JULY 2ND, 2014
1. ALEXANDERSON DAY, JUNE 29TH, 2014
The annual transmission on "Alexanderson Day" with the Alexanderson alternator on VLF 17.2 kHz will take place Sunday, June 29th, 2014 at 09:00 UTC (tuning up from about 08:30 UTC) and will be repeated at 12:00 UTC (tuning up from about 11:30 UTC).
There will be activity on amateur radio frequencies with the call "SK6SAQ" from about 08:00 to about 14:00 UTC, except during SAQ transmissions.
Any of following frequencies:
- 14.035 kHz CW
- 14.215 kHz SSB
- 3.535 kHz CW
QSL for SK6SAQ via SK6DK or bureau. The station will be open to visitors 08:00 to14:00 UTC.
QSL-reports on SAQ are kindly received:
- E-mail to: info@alexander.n.se
- or via: SM bureau
- or direct by mail to: Alexander - Grimeton Veteranradios Vaenner,
Radiostationen, Grimeton 72, SE-432 98 GRIMETON SWEDEN
http://www.youtube.com/watch?v=s1bWRTR6qlE
S52AS
Prispevkov: 60
Pridružen: 20 Jul 2005, 06:54
OdgovorNapisal/-a S52AS » 29 Jun 2014, 11:22
Danes so bili zelo dobri pogoji za sprejem SAQja.
Sprejemal sem z novo verzijo baterijske MiniWhip antene, ki porabi samo 10mA in direktno na zvočno kartico.
(148.45 KiB) Še ni prenešeno
S52AS
Prispevkov: 60
OdgovorNapisal/-a S59ZB » 29 Jun 2014, 18:05
35m žice in Perseus.
73 Zvone, s59zb
ex. yu3azb
S59ZB
Prispevkov: 148
Pridružen: 06 Okt 2009, 23:10
Kraj: Maribor
OdgovorNapisal/-a S52AS » 29 Jun 2014, 20:24
10 YEARS SINCE GRIMETON RADIO/SAQ BECAME A UNESCO WORLD HERITAGE, JULY 2ND, 2014
There will also be a transmission on, Wednesday, July 2nd, 2014, at 14:30 UTC (tuning up from about 14:00 UTC) due to 10 years since SAQ was appointed a World Heritage site.
There will be activity on amateur radio frequencies with the call "SK6SAQ" from about 08:00 UTC to about 15:00 UTC, except during SAQ transmission.
- 14.035 kHz CW
- 14.215 kHz SSB
- 3.535 kHz CW
We do not require any QSL-reports on this SAQ transmission and will not verify.
The station will be open to visitors 08:00 to 15:00 UTC.
Also read our web site: www.alexander.n.se
Yours Lars Kalland SM6NM
S52AS
Prispevkov: 60
OdgovorNapisal/-a S52AS » 02 Jul 2014, 10:55
Tako se je SAQ slišal 29.06.2014 http://www.youtube.com/watch?v=b8J7KP8N9GA
S52AS
Prispevkov: 60
OdgovorNapisal/-a S52AS » 17 Okt 2014, 08:19
GRIMETON RADIO/SAQ TRANSMISSION
There will hopefully be a transmission with the Alexanderson alternator on 17,2 kHz on “United Nations Day” October 24, 2014 at 10:00 UTC. Start up and tuning from about 11:30 UTC.
There will be a message written by students in Denmark.
We are not hundred percent sure we have access to the antenna this day because of other organization using it.
This time we do not require any QSL-reports and will not verify.
Regards.
Lars/SM6NM
P.S. We intend to continue with our annual transmission on Christmas Eve (morning), Dec 24, at 08:00 UTC with tuning up from 07:30 UTC. D.S.
S52AS
Prispevkov: 60
OdgovorNapisal/-a S52AS » 15 Jun 2015, 19:15
We will remind you of the Grimeton Radio/SAQ transmission on VLF frequency 17.2 kHz, CW, with the Alexanderson 200 kW alternator on “ALEXANDERSON DAY”, Sunday, June 28th, at 09:00 UTC and 12:00 UTC (11:00 and 14:00 SVT).
We will start tuning up some 30 minutes before the message.
There will be activity on amateur radio frequencies during the day with the call SK6SAQ.
- 7,035 CW or 14,035 CW
- 3,755 SSB
- 145,700/145,100 VHF FM repeater (R-4/RV-56)
S52AS
Prispevkov: 60
OdgovorNapisal/-a s51da » 28 Jun 2015, 11:39
SAQ transmission Update 2015-06-28 - 09:08 UTC
Technical problems with the antenna resulted in no transmission 09:00 UTC. We will try again at 12:00 UTC
Slišalo se ga je okrog 8:45UTC za kakšno minuto, potem pa tišina.......
Upam, da bo ob 12:00UTC bolje.
73 de s51da
s51da
Prispevkov: 136
Pridružen: 21 Okt 2001, 02:00
Kraj: Bohinj
OdgovorNapisal/-a S52AS » 03 Jul 2015, 12:33
Imeli so težavo, ker jim je prebil izolator http://alexander.n.se/technical-difficu ... 5/?lang=en
Ob 12utc pa jim je delalo brez težav.
Pri meni na portabl lokaciji z 10m vertikalno anteno, konverter SO42P na 14MHz od S52AB in RU20 (Prc515) snemano z ročnim snemalnikom zvoka se je slišalo tako https://www.youtube.com/watch?v=Nt4JJZ20Kks
S52AS
Prispevkov: 60
OdgovorNapisal/-a S52AS » 04 Jul 2020, 11:07
The annual transmission on Alexanderson Day with the Alexanderson Alternator
on VLF 17.2 kHz with the call sign SAQ will take place Sunday, July 5th, 2020.
Two transmissions are scheduled as follows:
Startup and tuning at 10:30 (08:30 UTC) with a transmission of a message at 11:00 (09:00 UTC).
Live Video Stream on https://www.youtube.com/watch?v=I47HNbxNQcw
Startup and tuning at 13:30 (11:30 UTC) with a transmission of a message at 14:00 (12:00 UTC)
Live Video Stream on https://www.youtube.com/watch?v=vU91iLrkrDM
S52AS
Prispevkov: 60
OdgovorNapisal/-a S52AS » 03 Jun 2021, 13:34
Oddajanje na Aleksandersonov dan z Alexandersonovim alternatorjem iz leta 1924,
na VLF 17,2 kHz CW s klicnim znakom SAQ,
je predviden za nedeljo, 4. julija 2021.
1. Startup and tuning at 10:30 CET (08:30 UTC) with a transmission of a message at 11:00 CET (09:00 UTC)
2. Startup and tuning at 13:30 CET (11:30 UTC) with a transmission of a message at 14:00 CET (12:00 UTC)
https://alexander.n.se/?lang=en
S52AS
Prispevkov: 60
OdgovorNapisal/-a S52AS » 11 Dec 2021, 17:12
S52AS
Prispevkov: 60
OdgovorNapisal/-a s54mtb » 12 Dec 2021, 00:23
Za tiste, ki nimate tako nizko sprejemnika...
Poskusno sem dodal na SDR tudi LF področje. Trenutno je antena odklopljena, bo pa v nekaj dneh spet nazaj:
https://sdr.v4.si/#freq=1800000,mod=lsb,sql=-150
Pridružen: 01 Apr 2014, 19:25
Po forumu brska: 0 registriranih uporabnikov in 21 gostov
