USA phone novosti
OdgovorObjavljeno: 11 Okt 2006, 22:44
Napisal/-a S50U
Oj
Govora je bilo da bi Amerikanci lahko letošnje CQWW SSB tekmovanje delali že po novih pravilih to je na razširjenih področjih od 3600-4000 in 7125-7300 KHz vendar se to ne bo zgodilo pred nekje sredi Novembra. Vseeno si je tole dobro zapomniti. :wink:
CUL Danilo, S50U
http://hraunfoss.fcc.gov/edocs_public/a ... -149A1.doc
Sent: Wednesday, October 11, 2006
Usually stuff from Federal agencies gets published 4 to 5 business days after release. So, with an release date of yesterday, I would expect to see it on Monday - maybe Tuesday at the latest. So, November 15 is probably a good target date, which means interesting things for the Sweepstakes phone. 73 Rich NN3W
Re: USA phone novosti
OdgovorObjavljeno: 12 Okt 2006, 14:30
Napisal/-a S50U
S50U napisal/-a:Vseeno si je tole dobro zapomniti. :wink:
Še ARRL-ova objava USA ham novosti od danes 12-Oktober :
SB QST @ ARL $ARLB019
ARLB019 FCC releases long-awaited ''Omnibus'' Amateur Radio Report and Order
ZCZC AG19
QST de W1AW
ARRL Bulletin 19 ARLB019
From ARRL Headquarters
Newington CT October 12, 2006
To all radio amateurs
SB QST ARL ARLB019
Ending a protracted waiting period, the FCC's Report and Order in
the so-called ''Omnibus'' Amateur Radio proceeding, WT Docket 04-140,
was adopted October 4 and released October 10, 2006. In it, the FCC
adopted nearly all of the proposed changes in the Notice of Proposed
Rulemaking released back in 2004. The FCC has:
+ expanded the phone subbands in the 75 and 40 meter bands;
+ permitted auxiliary stations to transmit on portions of the 2
meter band;
+ permitted the use of spread spectrum on 222-225 MHz;
+ permitted amateurs to retransmit communications from the
International Space Station;
+ permitted amateur licensees to designate a specific Amateur Radio
club to receive their call sign in memoriam;
+ prohibited an applicant from filing more than one application for
a specific vanity call sign;
+ eliminated certain restrictions on equipment manufacturers;
+ permitted Amateur Radio stations in Alaska and surrounding waters
more flexibility in providing emergency communications;
+ clarified that ''amateur stations may, at all times and on all
frequencies authorized to the control operator, make transmissions
necessary to meet essential communication needs and to facilitate
relief actions'';
+ deleted the frequency bands and segments specified for RACES
stations;
and
+ deleted the requirement for public announcement of test locations
and times.
In addition, the FCC took several other miscellaneous actions.
In ''refarming'' the frequencies currently authorized to Novice and
Technician Plus licensees, the Commission increased the voice
segments for General, Advanced and Amateur Extra licensees.
On 75 meters, Generals will be able to use voice from 3800-4000 kHz,
an increase of 50 kHz. Advanced class licensees will be able to use
voice from 3700-4000, an increase of 75 kHz, and Amateur Extras will
be able to use voice from 3600 to 4000 kHz, a generous increase of
150 kHz.
On 40 meters, Advanced and Extra Class licensees will be able to use
voice from 7125-7300 kHz, an increase of 25 kHz. General class
licensees will be able to use voice on 7175-7300 kHz, an increase of
50 kHz.
On 15 meters, General class operators will have phone privileges on
21275-21450 kHz, an increase of 25 kHz.
ARRL President Joel Harrison, W5ZN, expressed the ARRL's gratitude
to the FCC Commissioners in a letter dated October 11: ''On behalf of
the ARRL and the Commission's licensees in the Amateur Radio Service
I want to express appreciation for your release yesterday of the
Report and Order in WT Docket 04-140 (FCC 06-149) amending Part 97
of the Commission's Rules. The Commission's action in clearing this
pending proceeding will assist the Amateur Radio Service in meeting
its objectives, particularly with regard to providing emergency and
public service communications.''
The changes will go into effect 30 days after the R&O is published
in the Federal Register.
