S59DJR - M.E.P.T. beacon group
OdgovorNapisal/-a s52ab » 07 Apr 2013, 16:28
... trenutno smo aktivni (tudi) na tem področju:
http://lea.hamradio.si/~s52ab/10140khz_ ... _group.htm
s52ab
Pridružen: 12 Mar 2006, 22:13
Re: S59DJR - M.E.P.T. beacon group
OdgovorNapisal/-a s52ab » 17 Apr 2013, 11:05
100mW in neuglašen balkonski dipol:
http://lea.hamradio.si/~s52ab/hf_beacon ... 0utc-1.jpg
http://lea.hamradio.si/~s52ab/10140khz_ ... dipole.jpg
Nemogoča "moč" v sodelovanju z nemogočo anteno... :roll:
Kljub temu, prvič viden v USA 8)
s52ab
OdgovorNapisal/-a s51da » 17 Apr 2013, 13:52
Hoj
Kakšne ogromne moči... :) :)
Sicer je WSPR ampak vseeno :
2013-03-27 06:12 S51DA 14.097153 -23 0 JN66xg 0.01 VK2DDI QF55hf 16190 86
2013-03-27 06:10 S51DA 14.097153 -24 0 JN66xg 0.01 VK2DDI QF55hf 16190 86
2013-03-27 06:02 S51DA 14.097153 -22 0 JN66xg 0.01 VK2DDI QF55hf 16190 86
2013-03-27 06:00 S51DA 14.097153 -20 0 JN66xg 0.01 VK2DDI QF55hf 16190 86
2013-03-27 05:58 S51DA 14.097153 -21 0 JN66xg 0.01 VK2DDI QF55hf 16190 86
2013-03-27 05:52 S51DA 14.097165 -23 0 JN66xg 0.01 LA9JO JP99gb 2547 4
2013-03-27 05:52 S51DA 14.097146 -21 3 JN66xg 0.01 4Z4TJ KM71jf 2448 126
2013-03-27 05:50 S51DA 14.097153 -22 0 JN66xg 0.01 VK2DDI QF55hf 16190 86
2013-03-27 05:48 S51DA 14.097153 -20 0 JN66xg 0.01 VK2DDI QF55hf 16190 86
2013-03-27 05:48 S51DA 14.097133 -19 4 JN66xg 0.01 4Z4TJ KM71jf 2448 126
2013-03-27 05:46 S51DA 14.097153 -22 0 JN66xg 0.01 VK2DDI QF55hf 16190 86
2013-03-27 05:42 S51DA 14.097153 -21 0 JN66xg 0.01 VK2DDI QF55hf 16190 86
2013-03-27 05:40 S51DA 14.097153 -27 0 JN66xg 0.01 VK2DDI QF55hf 16190 86
10mW (WsprryPi) in CobWebb dipol.
Je veselo, ko vidiš kaj se vse da v pravih pogojih...
73 de s51da
s51da
Prispevkov: 136
Pridružen: 21 Okt 2001, 02:00
Kraj: Bohinj
OdgovorNapisal/-a s52ab » 17 Apr 2013, 20:36
Seveda, WSPR je še "hujši". Tudi do tega še pridemo. Gremo po vrsti...
Čestitke David ! :)
s52ab
OdgovorNapisal/-a s52st » 20 Apr 2013, 21:10
se en signal cez luzo... to noc 20.04. ob 04:50 na QRSS graberju W4HBK viden S52ST (po lok. karti 8499.1 km)...
QRRS svetilnik S52ST, QTH JN75ov, 80mW, antena koaks dipol postavljen na postresju, dolzine 2 x 4,15m (http://digilander.libero.it/i2ndt/antenna/Dipolo.htm)
73 S52ST
s52st
Prispevkov: 40
Pridružen: 31 Mar 2004, 10:55
OdgovorNapisal/-a s52ab » 28 Avg 2013, 11:58
Pogoji za USA, se na 30m. izboljšujejo. S52AB FSKCW QRSS signal zopet jasno viden na W4HBK graberju (EM60kj), od 04:21 do 04:32 GMT. Ob 04:26do28GMT - "audible"
V tem času edini iz Evrope.
TX: 100mW in balkonski dipol - spodnji brlog.
Dipol uglašen z GDM na točki napajanja.
s52ab
OdgovorNapisal/-a s52ab » 30 Avg 2013, 20:28
Da bi se dalo odčitat razliko(!) nivoja signala pri raznih poizkusih za ta FSKCW bejkn, sem se namenil narediti neki indikator nivoja RF polja iz materiala, ki sem ga imel. Kupoval ne bom nič, ker je raznorazne krame že tako preveč.
Poizkuse sem začel na zgornji lokaciji. Izkoristil sem obstoječi preselektor z predojačevalcem, ki sem ga imel: http://lea.hamradio.si/~s52ab/albumi/me ... 13mhz.html
Priključil sem instrument in zadeva je delovala solidno (3600kHz) pri moči od 10 (40 dBm)do 100W (50 dBm), vendar instrument ni deloval, če sem signal na instrument poslal prek predojačevalca - kazalec ni niti trznil. To sem intuitivno rešil z transformatorjem v svoji izvedbi. Zadevica je s predojačevalcem postala seveda bistveno občutljivejša.Indikator polja je deloval v območju moči od kakega wata navzgor na razdalji cca 15m od antene s polnim odklonom instrumenta.
Ko sem zadevo prinesel v dolino in jo postavil kake 3 metre od antene, so se začele težave. Odklona skoraj ni bilo. Pač, 100mW (20 dBm) naj bi bilo, vendar še to dvomim, da je. Poiskusil sem na kake tri vrste instrumentov. Pri obstoječi izvedbi s tem trafotom, se je najbolje izkazal stari iskrin instrument, ki sem ga snel iz LF SWR metra, izdelanega v lastni izvedbi. 40 in 60mikro instrumenta sta se odrezala bistveno slabše. Rabita pač drugačne prilagoditve.
Vendar so se problemi nadaljevali in pri nadalnji telovadbi sem prišel tudi v situacijo, da je preselektor deloval kot noč filter recimo. Odstranil sem preselektor in poizkušal razne vrste predojačevalcev, izdelanih do sedaj v kombinaciji s tem mojim trafotom in prekljapljanjem z odcepi. Na A priključku je bilo kak meter drata. Za večjo razdaljo, je bilo potrebno seveda več drata.
Za sedaj sem se nekako zadovoljil z varianto, prikazano na sliki:
Regulacija nivoja se vrši z menjavo odcepov tako instrumenta, kot A priključka, če se meri nivo, ki ga da recimo neki dipol, vertikalka etc, glede na moč TXa, na samem kraju meritve.
Seveda bi bilo za te običajne moči, ki se uporabljajo v ham praksi - 100W (50dBm), bolje uporabiti varianto z oklopljenim preselektorjem in atenuacijo pri samem instrumentu. Torej selektivni merilec polja, ki bi deloval z možnostjo odčitka nekoliko dlje od antene. Takega se kasneje lahko tudi umeri in priredi za nekoliko natančnejše meritve.
Tudi v kovačnici včasih kaj uspe ... :wink:
s52ab
OdgovorNapisal/-a s52ab » 01 Sep 2013, 20:33
S52AB - 01.september ob 05:00 UTC: QRSS FSK CW signal na meji slišnosti v ZL. Edini jasno čitljiv iz Evrope
Danes opravili kontrolo moči TXa s power senzorjem na HP435 pri S52ED; "moč" oddajnika uporabljana do sedaj je bila 60mW in ne 100mW.
Moč je od danes dvignjena na "kilovat", oziroma 100mW... :wink:
Antena po starem: balkonski dipol
Za ostale smeri danes zjutraj, vključno z Evropo - več ali manj, tema...
s52ab
OdgovorNapisal/-a s52ab » 06 Sep 2013, 12:01
Možnost spremljanja pogojev razprostiranja za določeno smer v danem obdobju. Primer: ZL2IK graber - tri urno spremljanje signalov na Petrovi lokaciji - RF74ci
S52AB signal je razločen od cca 04:30 do 06:15UTC ali 06:30 do 08:15 po našem času. Maksimum doseže od nekje 04:45 do 05:15UTC
RIG: 100mW in balkonski dipol 6m nad zemljo in kraji dipola na cca 2.5m od zemlje, med drevesi in stavbo.
Peter ZL2IK, mi je na mojo prošnjo glede njegovih naprav, navedel sledeče:
RX:
My Station consists of an Icom IC R75 receiver, fitted with a 500Hz CW filter, the receiver and Spectrum Lab software combination is calibrated using a home built DDS as an adjustable signal source. The frequency of which is calibrated against a HP5316B Counter clocked by a GPS disciplined 10.00MHz Oscillator. The counter has a worst case effective accuracy of 1 part in 1E-08 + 1 count, which is 1 part 100MHz using this combination.
When I first setup my Grabber I used the receiver of my Icom IC756 pro3 Transceiver, which was really a waste of resources so I purchased the IC R75 to take over the role as Grabber receiver. I have not regretted doing that as the ICR75 behaves very much like the 756pro3 receiver did.
Software:
Spectrum Lab software gives total flexibility when used as a spectrum display.
The time on the Grabber (from my Computer) is locked to the UTC second by a home brew “Ultimate Clock” which is a GPS and Arduino board with a 2 line readout of time and date, and the GPS generated 1PPS signal fed to the computer Clock via Meinberg NTP Time Server software.
ANT:
My antenna is a λ/2 copper wire dipole strung up between 2 trees in my driveway. The driveway has a bend in it, and is an avenue of trees around 15 metres tall. The dipole is strung up along the drive between the trees, from the corner of the driveway. It is 8 metres above ground at the western end and 4 metres high at the eastern end, best radiation is I guess approximately north/south. I have a low power Guanella type current Balun (1:1) at the feed point and this is fed by exactly 1 electrical wavelength of RG58AU coaxial cable. The feeder therefore repeats the antenna impedance at the receiver end. The whole antenna system was tuned up using an MFJ269B Antenna analyser for best return loss at 10.140MHz.
... in seveda primerna lokacija:
Part of my success must be put down to my location which is 18km out of town in a remote country area, which is quite low noise and free of nearby TV sets, and other noise makers.
I am looking at running the Grabber in a remote location if I can source a cheap way of getting it onto the internet as it is now. I am looking at my Gliding Club airstrip (I fly Gliders), which is 25km from my QTH to set it up initially. However getting onto the internet there involves a Cell phone 3G connection, which is very expensive here...
Peter je obiskal tudi te kraje:
Incidentally I have been to Slovenia, my wife and I spent a few days in Koper on the Adriatic Coast with friends (from Krakow in Poland). We went down to Rijeka in Croatia and went flying at an ex military airstrip at a place called Podhum just outside Rijeka. We were on our way to the UK via Sicily, Italy, Slovenia, Austria, Slovakia, Germany, and the Netherlands. Part of a 3 month motoring trip through Europe, which we thoroughly enjoyed.
Info - ZL2IK:
http://www.qrz.com/db/ZL2IK
s52ab
OdgovorNapisal/-a s52ab » 15 Sep 2013, 09:44
15.september 2013
ZL2IK (Peter) graber, RF74ci
W4HBK (Bill) graber, Pensacola, Florida - EM60kj
W4HBK - Bill, info:
http://www.qrz.com/db/W4HBK
s52ab
OdgovorNapisal/-a s52ab » 18 Nov 2013, 21:24
S52AS
17.november 2013
Frekvenca: 7000.81 kHz
Mode: FSK CW QRSS6
TX: 100 mW
ANT: koaksialni dipol za 7 MHz, podstrešni (indoor) - skrajšani dipol-bazuka, cca 3-4m nad nivojem zemlje, v gozdu
W4HBK grabber: signal prisoten od 00:30 do 07:30 UTC
s52ab
OdgovorNapisal/-a s52ab » 04 Feb 2014, 15:13
Tudi v pogojih - led na anteni, 100 mW gre:
Polovico antene v ledu; na oddajni frekvenci: SWR 1:2.9 ; Zmag 33 ; XS -25 ... etc; merjeno 03.februarja 2014 dopoldne:
pa saj ni tako slabo :-?
"Zakopana" antena :
Na področju večine evropskih graberjev, seveda, ni problema. Zapis signala je skozi ves dan soliden tudi v teh pogojih.
s52ab
OdgovorNapisal/-a s52ab » 09 Feb 2014, 00:17
Siniša je z "indoor" bazuke dipola, preklopil na vindomko FD4. Na oodaji ima izpod 100 mW na 10140 kHz. Parametri na tej frekvenci, za FD4 (ni dodatka za WARC bande), niso ravno najboljši:
SWR 1 : 3.9 ; Zmag 18 ; Xs -11.7 ...
Da bi tole izgledalo lepše, brez nekih običajnih kuplerjev, je zadevo rešil takole:
Sedaj analajzer pred kondičem (iz starega radia), kaže idealno sliko:
SWR 1 . 1,0 ; Zmag 50.0 ; Xs 0.7 ; Rl -42 ...
Seveda sistem izza kondenzatorja, dela pod prejšnjimi parametri. Čakamo, da se signal pojavi na ZL2IK ... VE1VDM .. graberju :wink:
Pri Billu W4HBK na Floridi in seveda EU, ni problema.
s52ab
Po forumu brska: Baidu [Spider] in 2 gostov
