Danes je 13 Avg 2020, 18:36
 Naslov prispevka: 2m band v nevarnosti ?
OdgovorObjavljeno: 17 Jun 2019, 11:33
Pridružen: 18 Nov 2001, 01:00
Prispevkov: 84
Kraj: Lucija
Francozi (Thales) predlagajo primarno uporabo za letalske komunikacije... :evil:
http://www.southgatearc.org/news/2019/j ... QdrMogzaUk
https://cept.org/Documents/cpg-pt-a/519 ... plications
https://www.f4fxl.org/2m-amateur-radio-band-endangered/
https://cept.org/Documents/cpg-pt-a/519 ... nfr-on-vhf
73, de Gregor, s53ra
 Naslov prispevka: Re: 2m band v nevarnosti ?
OdgovorObjavljeno: 17 Jun 2019, 13:08
Prispevkov: 84
Kraj: Lucija
Stališče IARU:
https://www.iaru-r1.org/index.php/88-ne ... enda-items
OdgovorObjavljeno: 25 Jun 2019, 12:29
Prispevkov: 84
Kraj: Lucija
https://www.iaru-r1.org/index.php/174-n ... o2qW5G91As
Regarding new aeronautical frequencies (including 144-146 MHz), the proposal was not strongly opposed by administrations and has been carried forward to the higher level CEPT Conference Preparatory Group (CPG) meeting in August for final adoption.
OdgovorObjavljeno: 03 Jul 2019, 04:03
Pridružen: 06 Avg 2010, 14:18
Prispevkov: 194
Kraj: JN75
The 2 Meter Amateur Radio Band (144-146MHz) is under Threat due to a
proposal from France during the World Radio Conference 2019 meeting that
the 2 Meter band should be allocated as a Aeronautical Band.
Sign the petition to CEPT and ITU:
http://chng.it/MJD4hqN88y
73 Allard PE1NWL
73 GS
OdgovorObjavljeno: 12 Jul 2019, 16:06
Pridružen: 12 Jul 2004, 06:57
Prispevkov: 91
Hej hoj!
Ali poteka kakšna komunikacija ZRS-APEK na to temo? Na uradni ZRS strani ni niti besede o tem. Ostale zveze, vsaj kakor lahko spremljam po spletu, so kar aktivne. Bomo spet ponižno čakali kaj nam bodo gospodarji namenili?
OdgovorObjavljeno: 30 Avg 2019, 12:18
Pridružen: 25 Maj 2006, 10:42
Prispevkov: 5
Danes je bila zaključena CEPT CGP konferenca v Ankari in na srečo je bil francoski predlog glede 2m področja zavrnjen. Za sedaj 2m band ni več v nevarnosti. Sicer pa ne pomeni, da ne bo še kakšen poizkus v prihodnje. Moremo se pač borit za bande, ki jih imamo.
Čestitke IARU za odlično delo na konferenci in pred njo.
Za videt še kakšna bo odločitev glede 23cm banda zaradi "motenj", ki naj bi radioamaterji povzročali pri sprejemu Galileo RNSS. Glede tega je tudi IARU aktiven. V današnjem sklepu je napisano, da ni nikakršnega namena, da se nam vzame področje, ampak je potrebno najti rešitev na nivoju CEPT-a za sobivanje...
73 in veliko zvez na bandih!
Andrej - S57RW
OdgovorObjavljeno: 30 Avg 2019, 20:14
Prispevkov: 472
Hoj.
Na žalost je problem je pri nas samih. Bandi od 2m navzgor so praktično prazni razen ob tekmovanjih. Pred 30. leti je bilo vse živo tudi na 1,2Ghz sedaj pa še v tekmovanjih narediš samo še nekaj zvez pa še to so v glavnem Hami stari preko 50. :( :(
Z takšno aktivnostjo bandov ne bomo obdržali,če bo na drugi strani interes kapitala.!
PS. Tudi na KV ni dosti bolje, izjema je 7Mhz in aktivnost na FT8. :roll:
OdgovorObjavljeno: 15 Jan 2020, 19:20
Pridružen: 17 Jul 2019, 09:17
Prispevkov: 2
Nimam pojma, zakaj bi želeli 2 m področje za letalstvo. V Evropi je od začetka leta 2018 (ponekod od 2019) itak obvezna uporaba radijskih postaj z razmikom med kanali 8,33 kHz (prej je bil razmik 25 kHz). To v teoriji pomeni potrojitev števila kanalov...pa tudi ob tem so mnogi zatrdili, da ni potrebe po tolikšnem številu kanalov.
Res pa je, kar trdi predhodni komentar. Če se sami ne bomo borili za svoje pravice, nam bodo te počasi odvzete. Velja za vsako področje, ne le za radioamaterstvo. In ko enkrat prepustiš del pravic, se bo njihovo krčenje le še nadaljevalo.
73 DE Matjaž, S53MZ
Locator JN76DI
