Nova verzija LOGGER32 3.26
Moderator: s52aa
OdgovorNapisal/-a s50v » 15 Maj 2010, 08:36
Objavljena je nova verzija 3.26
Spremembe:
Release change notes for Ver 3.26.0 as of....... 10 May 2010
Important Notes:-
A) As some menu items have been added/moved a new language dll file is required .
1) As requested, PgUp and PgDn keys have been reassigned for Speed up and speed down.
Left Arrow and Right Arrow keys now shift focus between the text pane and the callsign pane.
2) Changes made to improve both the LoTW and eQSL file export internal coding.
3) FT-980 removed from supported radios list.
4) Change made to retain the user set status of the QSL Flags in ADD QSO facility
5) When regional settings are other than English, the IOTA activity window does not
sort by start date correctly. Change made to internally convert the start date to the
ISO-8601 ("YYYY-MM-DD") standard.
6) A minor bug on spot announcements if the reporting station had an "/" in the call
sign has been cleared.
7) Introduction of SO2V working - Sub receiver Mode Polling added. It is a
prerequisite that any radio that is an SO2V candidate have the physical capability to
output stereo audio - one channel for the main VFO and one for the sub VFO. To date
the following radios are supported FT-2000/D, FT-1000mp/mk5, K3, FT1000D. It is
understood that the FTDX9000 also functions ok..
8) Changes made to the radio debug window as a result of SO2V
9) Winkey2 lead and lag delays corrected. Values set in the CW.ii file were being
multiplied by a factor of 10.
10) Previously, DxSpot partial callsign filtering, by using the * wildcard, applied
to the DX Station callsign only. Change made so that wildcard partial filtering also
applies to the DX Spot Originator callsign.
11) An additional tab has been added to the Cluster/Telnet window labelled "Local
Host". The intent is to add a simple TCP Socket to allow the user to connect to
127.00.00.01 on the local machine for connection to a VE7CC Cluster, CW Skimmer, or
whatever may come along. Also, by simply changing the IP address and port number,
the user could establish a second Telnet connection. OPERATIONAL NOTE: I notice two
things about CW Skimmer when I downloaded the test version:
a) Because CW Skimmer takes so long to load, it is impossible to have Logger32
auto-start CW Skimmer and then auto-connect, also,
b) for some unknown reason Logger32 cannot stop CWSkimmer on shutdown.
12) New QSL (paper) synchronisation option added. See new item under the FILE menu
Ver. 3.26.000 Countries/Prefixes Database updates:
1. Recent massive changes to Russian prefixes incorporated. Some resulting changes
include:
* The major prefix for European Russian (RA) is now (R).
* UA5 and UA7 are like UA6, European Russia
* UA8 is like UA9, Asiatic Russia
* RI1AN is Antarctica, CE9
* RI1FJ is Franz Josef Land, R1FJ
* RI1MV is Malyj Vysotskij, R1MV
2. Specific call signs added:
* <4U10NPT> = OE
* <GB8RUM> = GM
* <GB0GGR> = GM
* <GB0SBG> = GI
* <TO2R> = FR
3. Prefix changes:
* SY1 prefix deleted from SV/A (Mount Athos); it is the same as SV1 (Greece).
* Alaska changed from KL7 to KL.
Thanks to UA1AKE, AD1C, SV1HKD.
Bud, W2RU
https://www.vezist.si/
s50v
Prispevkov: 264
Pridružen: 25 Feb 2009, 14:43
Kraj: LJ/SG
Re: Nova verzija LOGGER32 3.26
OdgovorNapisal/-a s50v » 15 Maj 2010, 20:21
Na netu je že NOVA verzija ... 3.26.1 ...
Popravljen slider na desni strani ...
s50v
Prispevkov: 264
Kraj: LJ/SG
OdgovorNapisal/-a s57u » 20 Maj 2010, 13:09
Pred nekaj minutami sem VU2PTT poslal prevod menijev za verzijo 3.26, ki jo lahko poberete na Logger32 WEB strani. Pričakujem, da bo objavljena v dnevu ali dveh. Če pa kdo želi prevod nemudoma naj se mi javi na ZS!
Polde, S57U
s57u
Prispevkov: 125
Pridružen: 13 Feb 2006, 23:08
Re: Logger za windows vista
OdgovorNapisal/-a s57sr » 24 Jul 2010, 18:05
Pozdrav vsem.
Ali mi lahko kdo pomaga, rad bi si naložil Logger vendar na Visto ne gre oziroma trokira. kaj naj naredim...
Za vsak odgovor se zahvaljujem..
S57SR Roman
lep 73 !
s57sr
Prispevkov: 127
Pridružen: 22 Feb 2006, 09:38
Kraj: mozirje
OdgovorNapisal/-a S50U » 24 Jul 2010, 22:47
s57sr napisal/-a:rad bi si naložil Logger vendar na Visto ne gre oziroma trokira. kaj naj naredim...
Logger32 runs under Windows 95/98, Windows 2000, Windows ME, Windows NT and Windows XP (these program names are all copyright by Microsoft Corporation). Some users have had some success in running Logger32 on Vista but some of the features will/may not run correctly. The Logger32/Vista combination is not supported at this time. At the present time, Logger32 is free.
V izogib težavam greš na enega od podprtih OS ali pa greš na drug free logger recimo WinLog32. GL Danilo, S50U
https://s50clx.si
S50U
Prispevkov: 578
Pridružen: 08 Avg 2002, 00:05
Kraj: Cíerkna
OdgovorNapisal/-a s55z » 25 Jul 2010, 07:26
Ali pa narediš virtualni stroj z VMWare-om, nanj zmontiraš XPje in poganjaš Logger32 v znanem domačem okolju, hi... Opazil sem, da je pri veliko programih, še posebno če uporabljajo MS SQL, problem delovanje v 64-bitnem okolju. Tako sem za računovodski program v 64-bitnih Windows7 uporabil VMWare virtualni stroj s temi istimi Windowsi7, vendar v 32-bitni verziji (v paketu itak dobiš obe verziji) in zadeva je tekla brez opazne razlike v hitrosti medtem, ko sem normalno uporabljal recimo zelo zahteven Photoshop v 64-bitnem načinu. Seveda pa se priporoča čim več RAM-a, core.ov, megahercov, itd, HI
Vrni se na HamSoft
